HP3245A信号发生器
HP3245A聚惠优品HP3245A信号发生器HP3245A/李S158-8930-0966
深圳佳捷伦电子仪器有限公司
联系人:欧阳/李S
手机:13510500080/15889300966
电话:0755-83761992
传真:0755-83761992
Q Q:  2355633959
邮箱:Cgilent@126.com
网站:www.cgilent.com
全国免费热线800-900-9128
全国免长途通话费400-996-9128
地址:深圳市龙岗区平新北路163号广弘星座B栋12楼
Agilent HP 3245A. 0 - 1MHz, Func Generators & Waveform Synthesizer The 3245A universal source combines precision dc capabilities with versatile ac performance, including arbitrary waveform generation. This creates versatility on the bench and may be all the source you ever need. The 3245A can also fit into your computer-aided test system, providing the capabilities of ac, dc, Arbitrary, and second channel options in a single 3 1/2-inch tall instrument. 3245A Performance Characteristics Form Factor Benchtop Number of Channels 1 ch Waveforms (Sine, Square, etc
Hewlett Packard 3245A Function Generator / Universal Source
HP 3245A universal source combines precision dc capabilities with versatile ac performance, including arbitrary waveform generation. This creates versatility on the bench and may be all the source you ever need. The 3245A can also fit into your computer-aided test system, providing the capabilities of ac, dc, Arbitrary, and second channel options in a single 3 1/2-inch tall instrument.
Precision DC
Precision DC outputs of both voltage and current. In the high-resolution mode, you get 24-bit resolution with 60-ppm, 90-day accuracy. The low-resolution mode provides 12-bit resolution with 100ms settling times. This type of precision means you can test A/D converters, Voltage to Frequency converters, VCO‘s, transducers, and other equipment needing highly-accurate dc voltage or current. There are two output ranges in the high-resolution mode: ±1 volt and ±10 volts. In the low-resolution mode, there are seven ranges. In current, there are four ranges of output, from 0.1mA to 100mA. Output impedance is selectable as either zero or Ω 50Ω.
备注:
我们的优势:
品种齐全,货源充足,存库雄厚,服务快捷,维修能力强。
欢迎来电!上门看货!价格好商量!您的满意是我们的追求!^_^
我公司对销售的仪器仪表均负责保修一年.
本公司长期供应/租赁/维修二手进口仪器B
  • 相关推荐
  • 热点推荐
