为什么说算法是一个程序和软件的灵魂
1.3w人已加入
算法是一个程序和软件的灵魂,作为一名优秀的程序员,只有对一些基础的算法有着全面的掌握,才会在设计程序和编写代码的过程中显得得心应手。本文是近百个C语言算法系列的第二篇,包括了经典的Fibonacci数列、简易计算器、回文检查、质数检查等算法。也许他们能在你的毕业设计或者面试中派上用场。
1、计算Fibonacci数列
Fibonacci数列又称斐波那契数列,又称黄金分割数列,指的是这样一个数列:1、1、2、3、5、8、13、21。
C语言实现的代码如下:
/* Displaying Fibonacci sequence up to nth term where n is entered by user. */
#include
int main()
  int count, n, t1=0, t2=1, display=0;
  printf("Enter number of terms: ");
  scanf("%d",&n);
  printf("Fibonacci Series: %d+%d+", t1, t2); /* Displaying first two terms */
  count=2;    /* count=2 because first two terms are already displayed. */
  while (count
结果输出:
Enter number of terms: 10
Fibonacci Series: 0+1+1+2+3+5+8+13+21+34+
也可以使用下面的源代码:
/* Displaying Fibonacci series up to certain number entered by user. */
#include
int main()
  int t1=0, t2=1, display=0, num;
  printf("Enter an integer: ");
  scanf("%d",&num);
  display=t1+t2;
  while(display
结果输出:
Enter an integer: 200
Fibonacci Series: 0+1+1+2+3+5+8+13+21+34+55+89+144+
2、回文检查
源代码:
/* C program to check whether a number is palindrome or not */
#include
int main()
  int n, reverse=0, rem,temp;
  scanf("%d", &n);
  temp=n;
  while(temp!=0)
     rem=temp%10;
     reverse=reverse*10+rem;
     temp/=10;
/* Checking if number entered by user and it's reverse number is equal. */
  if(reverse==n)
      printf("%d is a palindrome.",n);
  else
      printf("%d is not a palindrome.",n);
  return 0;
结果输出:
Enter an integer: 12321
12321 is a palindrome.
3、质数检查
注:1既不是质数也不是合数。
源代码:
/* C program to check whether a number is prime or not. */
#include
int main()
  int n, i, flag=0;
  printf("Enter a positive integer: ");
  scanf("%d",&n);
  for(i=2;i<=n/2;++i)
      if(n%i==0)
          flag=1;
          break;
  if (flag==0)
      printf("%d is a prime number.",n);
  else
      printf("%d is not a prime number.",n);
  return 0;
结果输出:
Enter a positive integer: 29
29 is a prime number.
4、打印金字塔和三角形
使用 * 建立三角形
源代码:
#include
int main()
    int i,j,rows;
    printf("Enter the number of rows: ");
    scanf("%d",&rows);
    for(i=1;i<=rows;++i)
        for(j=1;j<=i;++j)
           printf("* ");
        printf("\n");
    return 0;
如下图所示使用数字打印半金字塔。
1
1 2
1 2 3
1 2 3 4
1 2 3 4 5
源代码:
#include
int main()
    int i,j,rows;
    scanf("%d",&rows);
        for(j=1;j<=i;++j)
           printf("%d ",j);
        printf("\n");
    return 0;
用 * 打印半金字塔
源代码:
#include
int main()
    int i,j,rows;
    scanf("%d",&rows);
    for(i=rows;i>=1;--i)
        for(j=1;j<=i;++j)
           printf("* ");
    printf("\n");
    return 0;
用 * 打印金字塔
源代码:
#include
int main()
    int i,space,rows,k=0;
    scanf("%d",&rows);
        for(space=1;space<=rows-i;++space)
           printf("  ");
        while(k!=2*i-1)
           printf("* ");
           ++k;
        k=0;
        printf("\n");
    return 0;
用 * 打印倒金字塔
源代码:
#include
int main()
    int rows,i,j,space;
    printf("Enter number of rows: ");
    scanf("%d",&rows);
        for(space=0;space
5、简单的加减乘除计算器
源代码:
/* Source code to create a simple calculator for addition, subtraction, multiplication and division using switch...case statement in C programming. */
# include
int main()
    char o;
    float num1,num2;
    printf("Enter operator either + or - or * or divide : ");
    scanf("%c",&o);
    printf("Enter two operands: ");
    scanf("%f%f",&num1,&num2);
    switch(o) {
        case '+':
            printf("%.1f + %.1f = %.1f",num1, num2, num1+num2);
            break;
        case '-':
            printf("%.1f - %.1f = %.1f",num1, num2, num1-num2);
            break;
        case '*':
            printf("%.1f * %.1f = %.1f",num1, num2, num1*num2);
            break;
        case '/':
            printf("%.1f / %.1f = %.1f",num1, num2, num1/num2);
            break;
        default:
            /* If operator is other than +, -, * or /, error message is shown */
            printf("Error! operator is not correct");
            break;
    return 0;
结果输出:
Enter operator either + or - or * or divide : -
Enter two operands: 3.4
8.4
3.4 - 8.4 = -5.0
6、检查一个数能不能表示成两个质数之和
源代码:
#include
int prime(int n);
int main()
    int n, i, flag=0;
    scanf("%d",&n);
    for(i=2; i<=n/2; ++i)
        if (prime(i)!=0)
            if ( prime(n-i)!=0)
                printf("%d = %d + %d\n", n, i, n-i);
                flag=1;
    if (flag==0)
      printf("%d can't be expressed as sum of two prime numbers.",n);
    return 0;
int prime(int n)      /* Function to check prime number */
    int i, flag=1;
       if(n%i==0)
          flag=0;
    return flag;
结果输出:
Enter a positive integer: 34
34 = 3 + 31
34 = 5 + 29
34 = 11 + 23
34 = 17 + 17
7、用递归的方式颠倒字符串
源代码:
/* Example to reverse a sentence entered by user without using strings. */
#include
void Reverse();
int main()
    printf("Enter a sentence: ");
    Reverse();
    return 0;
void Reverse()
    char c;
    scanf("%c",&c);
    if( c != '\n')
        Reverse();
        printf("%c",c);
结果输出:
Enter a sentence: margorp emosewa
awesome program
8、实现二进制与十进制之间的相互转换
/* C programming source code to convert either binary to decimal or decimal to binary according to data entered by user. */
#include
#include
int binary_decimal(int n);
int decimal_binary(int n);
int main()
   int n;
   char c;
   printf("Instructions:\n");
   printf("1. Enter alphabet 'd' to convert binary to decimal.\n");
   printf("2. Enter alphabet 'b' to convert decimal to binary.\n");
   scanf("%c",&c);
   if (c =='d' || c == 'D')
       printf("Enter a binary number: ");
       scanf("%d", &n);
       printf("%d in binary = %d in decimal", n, binary_decimal(n));
   if (c =='b' || c == 'B')
       printf("Enter a decimal number: ");
       scanf("%d", &n);
       printf("%d in decimal = %d in binary", n, decimal_binary(n));
   return 0;
int decimal_binary(int n)  /* Function to convert decimal to binary.*/
    int rem, i=1, binary=0;
    while (n!=0)
        rem=n%2;
        n/=2;
        binary+=rem*i;
        i*=10;
    return binary;
int binary_decimal(int n) /* Function to convert binary to decimal.*/
    int decimal=0, i=0, rem;
    while (n!=0)
        rem = n%10;
        n/=10;
        decimal += rem*pow(2,i);
        ++i;
    return decimal;
结果输出:
9、使用多维数组实现两个矩阵的相加
源代码:
#include
int main(){
    int r,c,a[100][100],b[100][100],sum[100][100],i,j;
    printf("Enter number of rows (between 1 and 100): ");
    scanf("%d",&r);
    printf("Enter number of columns (between 1 and 100): ");
    scanf("%d",&c);
    printf("\nEnter elements of 1st matrix:\n");
/* Storing elements of first matrix entered by user. */
    for(i=0;i
结果输出:
10、矩阵转置
源代码:
#include
int main()
    int a[10][10], trans[10][10], r, c, i, j;
    printf("Enter rows and column of matrix: ");
    scanf("%d %d", &r, &c);
/* Storing element of matrix entered by user in array a[][]. */
    printf("\nEnter elements of matrix:\n");
    for(i=0; i
结果输出:
算法
