瑞芯微RK3568鸿蒙开发板OpenHarmony系统修改cfg文件权限方法
本文适用OpenHarmony开源鸿蒙系统,本次使用的是开源鸿蒙主板,搭载瑞芯微RK3568芯片。深圳触觉智能专注研发生产OpenHarmony开源鸿蒙硬件,包括核心板、开发板、嵌入式主板,工控整机等,提供瑞芯微RK3566、RK3568、RK3588、RK3562、RK3576等国产化嵌入式产品方案。
一、查看文件路径
首先init.rkxxx.cfg文件在系统路径
/vendor/etc/
,如下图所示:
C:\Users\industio>hdc shell # cd vendor/etc/ # ls audio fstab.rk3568 iqfil.json soc_perf battery hdfconfig iqfiles thermal_config cgroup_sched init ons distributedhardware init.rk3568.cfg param firmware init.rk3568.usb.cfg ressched"
开发板
二、文件传至本地
将需要需要修改的cfg文件从文件系统中拉下来放在本地目录,命令是:hdc file recv '系统路径' '本地文件路径',如下图所示:
​C:\Users\industio>hdc file recv /vendor/etc/init.rk3568.cfg D:\ [I][2024-07-25 10:49:35] HdcFile::TransferSummary success FileTransfer finish, Size:3581, File count = 1, time:127ms rate:28.20kB/s
开发板
三、修改文件
在cfg文件中增加权限,注意在对文件修改不要使用TAB键,复制前一行代码后再修改防止出错
{ "import" : [ "init.${ohos.boot.hardware}.usb.cfg" ], "jobs" : [{ "name" : "pre-init", "cmds" : [ "write /proc/sys/vm/min_free_kbytes 10240", "mount debugfs /sys/kernel/debug /sys/kernel/debug mode=755", "write /sys/kernel/debug/hisi_inno_phy/role peripheral" ] }, { "name" : "init", "cmds" : [ "write /proc/1/oom_score_adj -1000", "chown system system /sys/kernel/hungtask/userlist", "symlink /dev/block/platform/fe310000.sdhci/by-name /dev/block/by-name" ] }, { "name" : "boot", //在此位置添加设备权限 "cmds" : [ "write /sys/block/zram0/disksize 1024M", "mkswap /dev/block/zram0", "swapon /dev/block/zram0", "chmod 777 /dev/ttyAMA2", + "chmod 666 /dev/bus/usb/005/001" + "chmod 666 /dev/bus/usb/005/002" "chmod 775 /sys/class/rfkill/rfkill0/state", ] }, { "name" : "post-fs-data", "cmds" : [ "restorecon", "restorecon /data/updater" ] } ], "services" : [{ "name" : "ispserver", "path" : ["/vendor/bin/ispserver"], "once" : 1, "secon" : "u:r:ispserver:s0", "uid": "ispserver", "gid": [ "ispserver", "camera_host" ] } ] }
四、文件推送
当修改完成后将文件推送回去,命令如下:
hdc shell mount -o remount,rw /vendor //重新挂载设备,将设备改为可读可写 hdc file send “本地路径” “/vendor/etc/init.rkxxx.cfg” //将修改好的文件覆盖到系统当中 hdc shell reboot //将文件推送回去,系统重启
