HDL语言及源代码
于stc自带EEPROM来说,用起来唯一不太方便的地方就是每次修改任何一个字节需要将整个扇区都擦除才能修改,所以每次修改都要讲整个扇区内容用数组全部读出缓存起来,进行擦除操作,讲需要修改的内容在相应的数组位置修改好,再讲整个数组内容重新写入到EEPROM里,头文件中我已经将接口函数都写好啦。直接调用就行,不用考虑任何问题,而且地址也直接从0开始到 USING_CHAR_NUM-1(USING_CHAR_NUM最大可到512)
#ifndef __EEPROM_H__
#define __EEPROM_H__
unsigned char EepromReadByte(unsigned char addr);
void EepromWriteByte(unsigned char addr, unsigned char dat);
#endif#include “intrins.h”
typedef unsigned char BYTE;
typedef unsigned int WORD;
sfr IAP_DATA = 0xC2; //Flash data register
sfr IAP_ADDRH = 0xC3; //Flash address HIGH
sfr IAP_ADDRL = 0xC4; //Flash address LOW
sfr IAP_CMD = 0xC5; //Flash command register
sfr IAP_TRIG = 0xC6; //Flash command trigger
sfr IAP_CONTR = 0xC7; //Flash control register
#define CMD_IDLE 0 //Stand-By
#define CMD_READ 1 //Byte-Read
#define CMD_PROGRAM 2 //Byte-Program
#define CMD_ERASE 3 //Sector-Erase
#define ENABLE_IAP 0x82 //if SYSCLK《20MHz
//Start address for STC12C5A60S2 series EEPROM
#define IAP_ADDRESS 0x0000
#define USING_CHAR_NUM 11
void IapIdle();
BYTE IapReadByte(WORD addr);
void IapProgramByte(WORD addr, BYTE dat);
void IapEraseSector(WORD addr);
return(IapReadByte(addr));
unsigned char eepromBUF[USING_CHAR_NUM];
unsigned char i;
for(i=0; i《 USING_CHAR_NUM; i++)
eepromBUF[IAP_ADDRESS+i] = IapReadByte(IAP_ADDRESS+i);
if(addr 《 USING_CHAR_NUM)
eepromBUF[IAP_ADDRESS+addr] = dat;
IapEraseSector(IAP_ADDRESS);
IapProgramByte(IAP_ADDRESS+i, eepromBUF[IAP_ADDRESS+i]);
//void EepromInit(void)
// unsigned int tmp = 0;
// _nop_();
// _nop_();
// _nop_();
// tmp = IapReadByte(IAP_ADDRESS+1);
// tmp = (tmp 《《 8) + IapReadByte(IAP_ADDRESS);
// if(0xffff == tmp)
// IapProgramByte(IAP_ADDRESS,(BYTE)0);
// IapProgramByte(IAP_ADDRESS+1,(BYTE)0);
// tmp = 0;
// tmp++;
// IapEraseSector(IAP_ADDRESS);
// IapProgramByte(IAP_ADDRESS,(BYTE)tmp );
// IapProgramByte(IAP_ADDRESS+1,(BYTE)(tmp》》8) );
void IapIdle()
IAP_CONTR = 0; //Close IAP function
IAP_CMD = 0; //Clear command to standby
IAP_TRIG = 0; //Clear trigger register
IAP_ADDRH = 0x80; //Data ptr point to non-EEPROM area
IAP_ADDRL = 0; //Clear IAP address to prevent misuse
BYTE dat; //Data buffer
IAP_CONTR = ENABLE_IAP; //Open IAP function, and set wait time
IAP_CMD = CMD_READ; //Set ISP/IAP/EEPROM READ command
IAP_ADDRL = addr; //Set ISP/IAP/EEPROM address low
IAP_ADDRH = addr 》》 8; //Set ISP/IAP/EEPROM address high
IAP_TRIG = 0x5a; //Send trigger command1 (0x5a)
IAP_TRIG = 0xa5; //Send trigger command2 (0xa5)
_nop_(); _nop_(); //MCU will hold here until ISP/IAP/EEPROM
//operation complete
dat = IAP_DATA; //Read ISP/IAP/EEPROM data
IapIdle(); //Close ISP/IAP/EEPROM function
return dat; //Return Flash data
IAP_CMD = CMD_PROGRAM; //Set ISP/IAP/EEPROM PROGRAM command
IAP_DATA = dat; //Write ISP/IAP/EEPROM data
IapIdle();
IAP_CMD = CMD_ERASE; //Set ISP/IAP/EEPROM ERASE command
IapIdle();
