wandboard 用户手册
消耗积分:0 | 格式:rar | 大小:2.39 MB | 2017-10-24
分享资料个
  These design materials referred to in this document are *NOT
  SUPPORTED* and DO NOT constitute a reference design. Only
  “community” support is allowed via resources at Wandboard.org forums.THERE IS NO WARRANTY FOR THE DESIGN MATERIALS, TO THE EXTENT
  PERMITTED BY APPLICABLE LAW. EXCEPT WHEN OTHERWISE STATED IN
  WRITING THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES PROVIDE THE DESIGN MATERIALS “AS IS” WITHOUT WARRANTY OF ANY KIND,
  EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE
  IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
  PARTICULAR PURPOSE. THE ENTIRE RISK AS TO THE QUALITY AND
  PERFORMANCE OF THE DESIGN MATERIALS IS WITH YOU. SHOULD THE
  DESIGN MATERIALS PROVE DEFECTIVE, YOU ASSUME THE COST OF ALL
  NECESSARY SERVICING, REPAIR OR CORRECTION.This board was designed as an evaluation and development tool. It was
  not designed with any other application in mind. As such, these design
  materials may or may not be suitable for any other purposes. If used, the
  design material becomes your responsibility as to whether or not it meets
  your specific needs or your specific applications and may require changes
  to meet your requirement
评论(0)
发评论
下载排行榜
