可编程片上系统如何帮助我们找到配置和性能之间的平衡
消耗积分:0 | 格式:rar | 大小:1.11 MB | 2017-10-30
分享资料个
  可编程片上系统帮助制造商找到配置和性能之间的平衡
  尽管半导体技术是所有电子产品的基础,但真正使我们的现代世界得以发展的是软件。与硬件相比,软件提供了几乎无限的灵活性,当在高性能微处理器上运行时,它可以带来惊人的结果。例如,如果没有在最新处理器上运行的软件的结合,人工智能的发展将是不可能的。
  在过去的几十年里,硬件和软件之间的平衡发生了变化。人们普遍认为,产品功能的大约70%现在是在嵌入式软件级别定义的,这几乎完全取决于它的灵活性。
  然而,随着应用程序推动性能的界限,这种不平衡成为限制因素。软件最终是以抽象的形式实现一个函数,它在执行时间方面不可避免地增加了开销。在专用硬件中实现的同一功能,在晶体管级,将总是更快地执行。这种性能增益通常是以灵活性为代价的,但是由于集成了三个关键技术:处理核心、固定功能和可重构硬件,设备性能和灵活性之间的平衡变得更加容易。
  High performance optimized solutions
  Devices that integrate all three technologies are commonly referred to as a system-on-chip, or SoC. By their nature they offer greater flexibility than a fixed function device, increased configurability over a microcontroller, and more functional diversity than an FPGA, by bringing the best of all these features together in a single platform.
  There are several reasons why this is a good mix for an application. Performance is the predominant one, which could be interpreted as either throughput or real-time response. Low power and optimized design may be another. The more functions that can be integrated on a single device, the fewer external components needed. These scenarios cover the two ‘corner points’ of SoCs, those that deliver pure performance and those that provide an optimized design.
评论(0)
发评论
下载排行榜
