HDL语言及源代码
Fast Template Matching,J. P. Lewis
#-*- coding:utf-8 -*-
import numpy as np
import matplotlib.pyplot as plt
import cv2
from Integral_image import *
## read img #####
tm_path = ‘/home/wdh/pytorch-CycleGAN-and-pix2pix1_run/results/map_pix2pix/test_latest/real_B/1_AB_real_B.png’
ref_path = ‘/home/wdh/pytorch-CycleGAN-and-pix2pix1_run/results/map_pix2pix/test_latest/real_B/1_AB_real_B.png’
img_ref_bgr = cv2.imread(ref_path)
img_tm_bgr = cv2.imread(tm_path)
img_ref_gray = (cv2.cvtColor(img_ref_bgr,cv2.COLOR_BGR2GRAY))/np.float64(255.0)
img_src_gray = (cv2.cvtColor(img_tm_bgr,cv2.COLOR_BGR2GRAY))/np.float64(255.0)
[h_ref,w_ref] = img_ref_gray.shape
[h_tm,w_tm] = img_src_gray.shape
h_tm = int(h_tm/3)
w_tm = int(w_tm/3)
ex_ratio = 0
img_tm_gray_ex = np.zeros([h_ref+h_tm*ex_ratio,w_ref+w_tm*ex_ratio])
img_tm_gray = np.copy(img_src_gray[h_tm:h_tm+h_tm,w_tm:w_tm+w_tm])
img_tm_gray_ex[0:h_tm,0:w_tm] = np.copy(img_src_gray[h_tm:h_tm+h_tm,w_tm:w_tm+w_tm])
tm_sum = np.sum(img_tm_gray_ex[0:h_tm,0:w_tm])
tm_sum_sq = np.sum(img_tm_gray_ex[0:h_tm,0:w_tm]*img_tm_gray_ex[0:h_tm,0:w_tm])
img_tm_gray_ex[0:h_tm,0:w_tm] = img_tm_gray_ex[0:h_tm,0:w_tm] - tm_sum/(h_tm*w_tm) #去均值
in_ref = calcIntag(img_ref_gray)
in_ref_sq = calcIntag(img_ref_gray*img_ref_gray)
img_ref_gray_ex = np.zeros([h_ref+h_tm*ex_ratio,w_ref+w_tm*ex_ratio])
img_ref_gray_ex[0:h_ref,0:w_ref] = img_ref_gray[:,:]
# img_ref_gray_ex[0:h_ref-h_tm+1,0:w_ref-h_tm+1] = img_ref_gray_ex[0:h_ref-h_tm+1,0:w_ref-h_tm+1] #- ref_avg_mat #去均值
#傅里叶变换
F_tm = np.fft.fft2(-img_tm_gray_ex)
F_tm.real = -F_tm.real
F_ref = np.fft.fft2(img_ref_gray_ex)
F_w = F_tm * F_ref
res = np.fft.ifft2(F_w).real#/((h_tm)*(w_tm))
res_i = np.fft.ifft2(F_w).imag
print(res_i)
bg_h = 0
bg_w = 0
ref_div_sq = calcDivmat2(in_ref_sq,in_ref, h_tm, w_tm)
tm_div = tm_sum_sq - (1.0/(h_tm*w_tm))*tm_sum*tm_sum
res = res[bg_h:bg_h+h_ref-h_tm+1,bg_w:bg_w+w_ref-w_tm+1]/(np.sqrt(ref_div_sq*tm_div))
print(np.max(res),np.min(res))
print(img_ref_gray.dtype,img_tm_gray.dtype)
res2 = cv2.matchTemplate(np.float32(img_ref_gray),np.float32(img_tm_gray),method=5)
print(np.max(res2),np.min(res2))
plt.figure()
plt.subplot(221),plt.imshow(res,cmap=‘gray’)
plt.subplot(222),plt.imshow(res2,cmap=‘gray’)
plt.subplot(223),plt.imshow(in_ref,cmap=‘gray’)
plt.subplot(224),plt.imshow(in_ref_sq,cmap=‘gray’)
plt.show()
