基于树莓派python编程的游戏程序
电子常识
2651人已加入
  Raspberry Pi(中文名为“树莓派”,简写为RPi,(或者RasPi / RPI)是为学习计算机编程教育而设计,只有信用卡大小的微型电脑,其系统基于Linux。随着Windows 10 IoT的发布,我们也将可以用上运行Windows的树莓派。
  自问世以来,受众多计算机发烧友和创客的追捧,曾经一“派”难求。别看其外表“娇小”,内“心”却很强大,视频、音频等功能通通皆有,可谓是“麻雀虽小,五脏俱全”。本文主要就是说明基于树莓派python编程的游戏程序,一起来了解一下。
  Raspbian的系统中包含了python的编程环境IDE,方便了我们对于python的学习。个人觉得还是游戏程序能够更好的激发我们的潜力所以,话不多说下面就来使用python编写我们简单的游戏程序吧。
  储备知识
  ①import 模块:time时间模块、random随机数模块
  ②列表:[ ] #[]中放入值,与数组很像,但是不同
  ③def:定义函数
  ④python的缩进是编程格式的一种,if等都不需要{}括起来,关键看缩进区分
  ⑤if,while,def函数都要以 “:”开始
  游戏概述
  一进入游戏,主人公就会随机获取一个游戏已经设定的道具。最开始,主人公站在丛林的边缘,只有左右可选,左边是个洞穴,右边是沙滩。
  选择左边,则开始可以获得手电筒,但是在洞穴中会碰到蛇hp-20,继续向下会到一个未知空间,游戏结束。
  选择右边,会到沙滩 获得凉爽的水hp+70,但是由于没有游泳装备,如果继续选择游泳,会遇到海啸而死亡。
  代码
  #Python Adventure Game
  import time
  import random
  #define variable health point
  hp = 30
  #define variable object_ to show what the adventurer has
  object_=[]
  #define variable what the game sets
  tools = [“Torch”,“Rope”,“Spanner”,“50HP”,“10HP”]
  #set two acceptable answers ,select any one to end loop
  def get_input(prompt,accepted):
  while True:
  value = input(prompt).lower()
  if value in accepted:
  return value
  else :
  print(“That is not a recognised answer,must be one of”,accepted)
  def handle_room(location) :
  global hp
  if location== “start”:
  print(“You are stading on a path at the edge of a jungle.There is a cave to your left and a beach to your right.”)
  object_.append(random.choice(tools))
  print(“Lucky,you have gained”,object_[-1])
  use_tools(object_)
  direction = get_input(“Do you want to go left or right?”,[“left”,“right”])
  if direction == “left”:
  return “cave”
  elif direction == “right”:
  return “beach”
  elif location == “cave”:
  print(“On the entrance of cave,you find a torch!!!”)
  object_.append(“Torch”)
  print(“You walk to the cave and notice there is an opening.”)
  print(“A small snake bites you,and you lose 20 health points.”)
  hp-=20
  answer = get_input(“Do you want to go deeper?(y/n)”,[“y”,“n”])
  if answer == “y”:
  return “deep_cave”
  elif answer == “n”:
  return “start”
  elif location == “beach”:
  print(“You walk to the beach but remember you do not have any swimwming equipment.”)
  print(“The cool water revitalizes you.You have never felt more alive,gain 70 health points.”)
  hp+=70
  answer = get_input(“Do you want to go swimming?(y/n)”,[“y”,“n”])
  if answer == “y”:
  return “sea”
  elif answer == “n”:
  return “start”
  elif location == “sea”:
  print(“Suddenly there was a tsunami,you can‘t escape.”)
  hp=0
  return “end”
  else :
  print(“Programmer error,room”,location,“is unknown”)
  return “end”
  #define the function to use the tools of HP
  def use_tools(tool):
  global hp
  length = len(tool)
  for i in range(0,length):
  if tool[i]==“50HP”:
  hp+=50
  tool.pop(i)
  print(“You have use the tool of 50HP”)
  j+=1
  elif tool[i]==“10HP”:
  hp+=10
  tool.pop(i)
  print(“You have use the tool of 10HP”)
  j+=1
  #The begin of the program.
  location = “start”
  #Loop until we reach the special “end” location
  while location!=“end”:
  location = handle_room(location)
  #Check we are not dead each return
  print(“You now have”,hp,“health points.”)
  if hp《=0:
  print(“You are dead.\nGame Over!!!”)
  break
  print(“Your adventure has ended,bye~”)
  函数功能块简析
  get_input(prompt,accepted) //(输入提示,可接受字符串)
  handle_room(location) //通过位置的判断给出不同场景的设定和人物的走向
  use_tools(tool) //人物若随机获得了HP类物品则立即使用,其他则无任何操作
  运行截图
  树莓派
