V4L2采集—X264编码H264视频实例
编码与解码
55人已加入
前几天在网上买个罗技的C270摄像头,它支持YUYV(YUV422)和JPEG数据输出。它规格书上写的是支持HD720P(1280*720像素),在实际的调试过程中,我使用该分辨率会导致数据采集过慢。这里需要注意一下,罗技的摄像头C270在有些虚拟机上使用是有异常的,有些是不能映射到虚拟机上,有些是映射过去操作非常缓慢。因为之前在自己的开发板上调试过YUV420的摄像头,在此基础上改为YUYV数据格式,调试的时候还是遇到不少的问题。
在PC上编译X264,可以直接执行下面三条命令:
./configure --enable-shared
make
make install
下面贴出x264部分的代码:
#     FileName: h264encoder.c
#         Desc: this program aim to get image from USB camera,
#               used the V4L2 interface.
#       Author: licaibiao
#      Version:
#   LastChange: 2017-02-21
#include
#include
#include
#include "./include/h264encoder.h"
int WIDTH = 640;
int HEIGHT = 480;
void compress_begin(Encoder *en, int width, int height) {
en->param = (x264_param_t *) malloc(sizeof(x264_param_t));
en->picture = (x264_picture_t *) malloc(sizeof(x264_picture_t));
x264_param_default(en->param); //set default param
//en->param->rc.i_rc_method = X264_RC_CQP;
// en->param->i_log_level = X264_LOG_NONE;
en->param->i_threads  = X264_SYNC_LOOKAHEAD_AUTO;
en->param->i_width = width; //set frame width
en->param->i_height = height; //set frame height
WIDTH = width;
HEIGHT = height;
//en->param->i_frame_total = 0;
//en->param->i_keyint_max = 10;
en->param->rc.i_lookahead = 0;
//en->param->i_bframe = 5;
//en->param->b_open_gop = 0;
//en->param->i_bframe_pyramid = 0;
//en->param->i_bframe_adaptive = X264_B_ADAPT_TRELLIS;
//en->param->rc.i_bitrate = 1024 * 10;//rate 10 kbps
en->param->i_fps_num = 30;
en->param->i_fps_den = 1;
en->param->i_csp = X264_CSP_I422;
x264_param_apply_profile(en->param, x264_profile_names[4]);
if ((en->handle = x264_encoder_open(en->param)) == 0) {
return;
/* Create a new pic */
x264_picture_alloc(en->picture, X264_CSP_I422, en->param->i_width,
en->param->i_height);
int compress_frame(Encoder *en, int type, uint8_t *in, uint8_t *out) {
x264_picture_t pic_out;
int index_y, index_u, index_v;
int num;
int nNal = -1;
int result = 0;
int i = 0;
static long int pts = 0;
uint8_t *p_out = out;
charchar *y = en->picture->img.plane[0];
charchar *u = en->picture->img.plane[1];
charchar *v = en->picture->img.plane[2];
charchar * ptr;
index_y = 0;
index_u = 0;
index_v = 0;
num = WIDTH * HEIGHT * 2 - 4  ;
for(i=0; i4)
*(y + (index_y++)) = *(in + i);
*(u + (index_u++)) = *(in + i + 1);
*(y + (index_y++)) = *(in + i + 2);
*(v + (index_v++)) = *(in + i + 3);
switch (type) {
case 0:
en->picture->i_type = X264_TYPE_P;
break;
case 1:
en->picture->i_type = X264_TYPE_IDR;
break;
case 2:
en->picture->i_type = X264_TYPE_I;
break;
default:
en->picture->i_type = X264_TYPE_AUTO;
break;
en->picture->i_pts = pts++;
if (x264_encoder_encode(en->handle, &(en->nal), &nNal, en->picture,
&pic_out) < 0) {
return -1;
for (i = 0; i < nNal; i++) {
memcpy(p_out, en->nal[i].p_payload, en->nal[i].i_payload);
p_out += en->nal[i].i_payload;
result += en->nal[i].i_payload;
return result;
void compress_end(Encoder *en) {
if (en->handle) {
x264_encoder_close(en->handle);
if (en->picture) {
x264_picture_clean(en->picture);
free(en->picture);
en->picture = 0;
if (en->param) {
free(en->param);
en->param = 0;
上面的代码是配置x264编码器的,有下面几个地方需要特别注意:
(1)CSP参数的配置
[objc] view plain
在X264中默认的i_csp值是3,也就是X264_CSP_NV12 的值,如果采用YUYV(422)输入格式,这个值一定需要重新设置,不然会出现错误提示:x264 [error]: Invalid input colorspace 。这是因为在x264内核中他会把输入格式装换为下面三种中的一种:X264_CSP_NV12,X264_CSP_NV16,X264_CSP_I444.转换如下:
[objc] view plain
static int x264_frame_internal_csp( int external_csp )
switch( external_csp & X264_CSP_MASK )
case X264_CSP_NV12:
case X264_CSP_NV21:
case X264_CSP_I420:
case X264_CSP_YV12:
return X264_CSP_NV12;
case X264_CSP_NV16:
case X264_CSP_I422:
case X264_CSP_YV16:
case X264_CSP_V210:
return X264_CSP_NV16;
case X264_CSP_I444:
case X264_CSP_YV24:
case X264_CSP_BGR:
case X264_CSP_BGRA:
case X264_CSP_RGB:
return X264_CSP_I444;
default:
return X264_CSP_NONE;
(2)profile类型设置
[objc] view plain
在YUV422中,它不支持baseline,默认设置会提示:x264 [error]: baseline profile doesn't support 4:2:2 可以设置下面的其他参数:
[objc] view plain
x264_profile_names[] = { "baseline", "main", "high", "high10", "high422", "high444", 0 };
(3)图片内存分配
[objc] view plain
这里的第二个参数一定要与你的输入格式先对应,不然的话会出现内存溢出的错误。因为默认的分配图片内存大小是YUV420的。以640*480 分辨率来举例,YUV420 分配一帧图像的内存是450K,而我们YUV422的数据量是600K。
(4)Y,U,V 数据需要分离
[objc] view plain
for(i=0; i4)
    YUYV的数据是交错存储的,因此需要把他们分离出来单独存储,如果这里不做处理,图像就会出现异常。
(5)i_pts 参数需要递增
[objc] view plain
    i_pts = pts的参数是需要递增的,不让回出现警告:x264 [warning]: non-strictly-monotonic PTS
完整的编译运行结果如下:
[objc] view plain
[root@redhat test]# ls
h264encoder.c  include  lib  main.c  Makefile  out
[root@redhat test]# make
gcc -g    -c -o main.o main.c
gcc -g    -c -o h264encoder.o h264encoder.c
gcc -g -o x264_test main.o  h264encoder.o -lpthread -lx264 -lm
h264encoder.c  h264encoder.o  include  lib  main.c  main.o  Makefile  out  x264_test
[root@redhat test]# ./x264_test
camera driver name is : uvcvideo
camera device name is : UVC Camera (046d:0825)
camera bus information: usb-0000:00:1a.0-1.1
n_buffer = 4
x264 [warning]: lookaheadless mb-tree requires intra refresh or infinite keyint
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
x264 [info]: profile High 4:2:2, level 3.0, 4:2:2 8-bit
spend time 85.082031 s
x264 [info]: frame I:8     Avg QP:20.27  size: 21592
x264 [info]: frame P:503   Avg QP:21.18  size:  3119
x264 [info]: frame B:1485  Avg QP:22.03  size:   952
x264 [info]: consecutive B-frames:  0.8%  0.0%  0.0% 99.2%
x264 [info]: mb I  I16..4: 11.9% 55.2% 32.9%
x264 [info]: mb P  I16..4:  0.4%  0.2%  0.1%  P16..4: 44.8%  7.9%  8.5%  0.0%  0.0%    skip:38.2%
x264 [info]: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8: 25.9%  0.6%  0.1%  direct: 1.7%  skip:71.7%  L0:51.6% L1:47.0% BI: 1.4%
x264 [info]: 8x8 transform intra:46.7% inter:95.7%
x264 [info]: coded y,uvDC,uvAC intra: 60.5% 87.6% 59.7% inter: 5.7% 23.2% 0.9%
x264 [info]: i16 v,h,dc,p:  4%  8%  1% 87%
x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 39% 12%  3%  5%  4% 10%  4%  7%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 24% 41%  8%  3%  4%  3%  8%  3%  4%
x264 [info]: i8c dc,h,v,p: 50% 22% 21%  6%
x264 [info]: Weighted P-Frames: Y:0.2% UV:0.0%
x264 [info]: ref P L0: 40.2%  4.8% 39.3% 15.7%
x264 [info]: ref B L0: 65.6% 20.4% 14.0%
x264 [info]: ref B L1: 91.2%  8.8%
x264 [info]: kb/s:379.47
[root@redhat test]#
    这里设置的分辨率是640*480 ,这样采集数据比较快。我编码2000帧数据需要的是大约85s,帧率大约在23fps 。也不知道具体是什么原因导致耗时这么长时间。
视频运行如下:
