ment that the manufacturer provides telling you • the typical device performance • minimum and maximum requirements and characteristics • what you can do to the device without harming it • suggested uses and hints Manufacturers want you, the designer, to have a successful experience with their device. They are trying to be helpful. They don’t always succeed. The datasheet on the following pages is a relatively good datasheet. It tries to concisely tell you everything you need to know about the device
