安科瑞MID认证双向计量导轨电表
1 概述General
ADL400导轨式多功能电能表,是主要针对电力系统,工矿企业,公用设施的电能统计、管理需求而设计的一款智能仪表,产品具有精度高、体积小、安装方便等优点。集成常见电力参数测量及电能计量及考核管理,提供上48月的各类电能数据统计。具有2~31次分次谐波与总谐波含量检测。带有RS485通信接口,可选用MODBUS-RTU协议。该电力仪表可广泛应用于各种控制系统,SCADA系统和能源管理系统中。产品符合IEC62053-21认证。
ADL400 is a smart meter designed for power supply system, industrial and mining enterprises and utilities to calculate the electricity consumption and manage the electric demand. It features the high precision, small size and simple installation. It integrates the measurement of all electrical parameters with the comprehensive electricity metering and management provides various data on previous 48 months, checks the 31st harmonic content and the total harmonic content, realizes the remote communication and the remote control with switching input and relay output and boasts the alarm output. It is fitted with RS485 communication port and adapted to MODBUS-RTU .ADL400 can be used in all kinds of control systems, SCADA systems and energy management systems. The meter meet the related technical requirements of electronic meter in the IEC62053-21standards.
2 型号说明Type description
电表
3 功能列表Function description
表1 功能说明列表
Table 1 Function description list
功能Function 功能说明Function description 功能配置Function provide
电能计量Measurement of kWh 有功电能计量(正、反向)
Active kWh (positive and negative)
无功电能计量(正、反向)
Reactive kWh (positive and negative)
A、B、C分相正向有功电能
电量测量Measurement of electrical parameters U、I
P、Q、S、PF、F
谐波测量Measurement of harmonics 2~31次谐波电压电流
2~31ST Voltage and current harmonic
LCD显示
LCD Display
12位段式LCD显示、背光显示
12 bits section LCD display, background light
按键编程
Key programming
3按键可编程通信、变比等参数
3 keys to communication and set parameters
脉冲输出
Pulse output
有功脉冲输出
Active pulse output
复费率及
附带功能
Multi-tariff and functions
支持4个时区、2个时段表、
14个日时段、4个费率
Adapt 4 time zones, 2 time interval lists, 14 time interval by day and 4 tariff rates
最大需量及发生时间
Max demanded kWh and time happened
上48月、上90日历史冻结数据
Frozen data on last 48 months, last 90days
日期、时间
Date, time
通讯
Communication
RS485接口,
支持Modbus
Communication interface: RS485, Communication protocol: MODBUS-RTU
4 技术参数Technical parameter
表2 技术参数说明
Table 2 technical parameter descriptions
项目 性能参数
规格
Specification
三相四线
3 phase 4 wires
Measurement
Voltage
参比电压
Reference voltage
3×230/400V
功耗
Consumption
<10VA(单相)(Single phase)
阻抗
Impedance
>2MΩ
精度等级
Accuracy class
误差±0.2%(Error±0.2%)
Current
输入电流
Input current
0.1-10(80)A(直接接入 Direct access model)
功耗
Consumption
<1VA(单路额定电流)(Single phase rated current)
精度等级
Accuracy class
误差±0.2%(Error±0.2%)
功率Power 有功、无功、视在功率,误差±0.5℅
Active, reactive, apparent power, error±0.5℅
电网频率Frequency 45~65Hz,误差±0.2%(Error±0.2%)
 计
Measurement
电能Energy 准确度等级C级
Accuracy class:C
时钟Clock ≤0.5s/d
Digit signal
电量脉冲输出
Energy pulse output
1路有功光耦输出
One active photocoupler output
脉冲
pulse
脉冲宽度
Width of pulse
80±20ms
脉冲常数
Pulse constant
400imp/kWh(与基本电流对应)(Correspond with the basic current)
communication
接口与通信规约
Interface and communication
RS485口:Modbus RTU规约
RS485:Modbus RTU
通信地址范围
Range of communication address
Modbus RTU:1~ 254;
波特率
Baud rate
1200bps~19200bps
environment
工作环境
work environment
室内(如需在户外使用,请为电表配备防水防尘表箱)
Indoor ( If it needs to be installed outdoors, please add a dustproof and waterproof shell )
工作温度
Relative temperature
 -40℃ to +70℃(直接接入Direct access model)
相对湿度
Relative humidity
≤95℅(无凝露)(No condensation)
防护等级
IP Rating
IP51
Must be installed in a suitable IP rated enclosure
5 外形尺寸Dimension drawings
电表
注:直接接入的接线力矩应该在3-4N·m,经互感器接入的接线力矩应该在1.5-2N·m。
Note:The torque of direct connect should be 3-4N·m,and the torque of  connect via CT should be 1.5-2N·m.
6 接线与安装Wiring and installing
6.1电压电流接线示意图Wiring sample of voltage and current
电表
Fig2 Three phase four lines connect via CT
电表
电表
电表
安科瑞电气股份有限公司
吴春红18702111910
上海市嘉定区育绿路253号
