PowerPC资料和开发板资料
消耗积分:10 | 格式:rar | 大小:1106 | 2010-01-11
无人岛
分享资料个
Cautionary Notes
1) Electrostatic Discharge (ESD) prevention measures should be applied whenever handling this product. ESD damage is
not a warranty repair item.
2) Axiom Manufacturing reserves the right to make changes without further notice to any products to improve reliability,
function or design. Axiom Manufacturing does not assume any liability arising out of the application or use of any
product or circuit described herein; neither does it convey any license under patent rights or the rights of others.
3) EMC Information on the CME-0555 board:
a) When indicated, this product as shipped from the factory with associated power supplies and cables, has been tested and
meets with requirements of CE and the FCC as a CLASS A product.
b) This product is designed and intended for use as a development platform for hardware or software in an educational /
professional laboratory or as a component in a larger system.
c) In a domestic environment this product may cause radio interference in which case the user may be required to take
adequate prevention measures.
d) Attaching additional wiring to this product or modifying the products operation from the factory default as shipped may
effect its performance and also cause interference with other apparatus in the immediate vicinity. If such interference is
detected, suitable mitigating measures should be taken.
评论(1)
发评论
520kk2002 2011-06-22
0 回复 举报
好东西,正需要谢了 收起回复
下载排行榜
全部1条评论
