基于LCD字符++KEY按键显示程序
控制/MCU
1933人已加入
 Function : LCD字符显示+KEY按键处理示例程序 *
HT48R50A
; MICroProcessor : HT48R50A-1/28SKDIP-A      *
; Author:                      *
; Crystal :       4MHz                       *
#INCLUDE                HT48R50A-1.INC
LCD_DATA                EQU     PC
LCD_DATA_CTRL           EQU     PCC
LCD_CTRL                EQU     PB
LCD_CTRL_CTRL           EQU     PBC
E                       EQU     1
RS                      EQU     0
DATA    .SECTION        AT 60H  ’DATA’
DELAY_COUNTER_1         DB      ?       ;[60H]
DELAY_COUNTER_2         DB      ?       ;[61H]
DELAY_COUNTER_3         DB      ?       ;[62H]
DATA                    DB      ?       ;[63H]
COUNTER                 DB      ?       ;[64H]
CODE    .SECTION        AT 00H  ’CODE’
                ORG     00H
                JMP     START
                ORG     0CH
                JMP     TIMER1
                ORG     20H
START:
                 MOV      A,01111111B
                 MOV      PAC,A
                CALL    LCD_RESET
                 MOV      A,OFFSET LCD_MESSAGE_1
                 MOV      TBLP,A
                CALL    LCD_DISPLAY
                 MOV      A,09H
                 MOV      INTC,A
                 MOV      A,80H
                 MOV      TMR1C,A
FIRST_TIME:
                 MOV      A,PA
                AND     A,00010000B
                SUB     A,00010000B
                SZ      ACC
                JMP     FIRST_TIME
PRESS_ANY_KEY:
                 MOV      A,OFFSET LCD_MESSAGE_2
                 MOV      TBLP,A
                CALL    LCD_DISPLAY
ANY_KEY:
                 MOV      A,PA
                AND     A,00010000B
                SUB     A,00010000B
                SZ      ACC
                JMP     ANY_KEY
                 MOV      A,PA
                AND     A,00001111B
                 MOV      DATA,A
                SUB     A,09H
                SZ      ACC
                JMP     NEXT_CHECK
                JMP     START
NEXT_CHECK:
                 MOV      A,DATA
                SUB     A,08H
                SZ      ACC
                JMP     PLAY_MONOTONY
                JMP     PLAY_A_SONG
PLAY_MONOTONY:
                CALL    MONOTONY
                JMP     ANY_KEY
PLAY_A_SONG:
                 MOV      A,OFFSET LCD_MESSAGE_3
                 MOV      TBLP,A
                CALL    LCD_DISPLAY
                CLR     COUNTER
PLAY_LOOP:
                 MOV      A,OFFSET SONG_DATA
                ADD     A,COUNTER
                 MOV      TBLP,A
                TABRDL  DATA
                DEC     DATA
                CALL    MONOTONY
                INC     COUNTER
                 MOV      A,COUNTER
                SUB     A,4BH
                SZ      ACC
                JMP     PLAY_LOOP
                JMP     PRESS_ANY_KEY
                RET
TIMER1:
                CPL     PA
                RETI
MONOTONY        PROC
                 MOV      A,OFFSET MUSIC_DATA
                ADD     A,DATA
                 MOV      TBLP,A
                TABRDL  DATA
                 MOV      A,DATA
                 MOV      TMR1L,A
                 MOV      A,TBLP
                ADD     A,08H
                 MOV      TBLP,A
                TABRDL  DATA
                 MOV      A,DATA
                 MOV      TMR1H,A
                SET     TMR1C.4
                CALL    DELAY_LONG
                CLR     TMR1C.4
                RET
MONOTONY        ENDP
LCD_RESET       PROC
                CLR     LCD_DATA_CTRL
                CLR     LCD_CTRL_CTRL
                CLR     LCD_DATA
                CLR     LCD_CTRL
                 MOV      A,00110011B     ;STEP 0
                 MOV      DATA,A          ;LCD RESET
                CALL    TRANSFER        ;
                 MOV      A,00110010B     ;SETP 1
                 MOV      DATA,A          ;FUNCTION SET
                CALL    TRANSFER        ;
                 MOV      A,00001100B     ;STEP 2
                 MOV      DATA,A          ;DISPLAY TURN ON
                CALL    TRANSFER        ;
                 MOV      A,00000001B     ;STEP 3
                 MOV      DATA,A          ;DISPLAY CLEAN
                CALL    TRANSFER        ;
                CALL    DELAY           ;DELAY SOME TIME
                 MOV      A,00000110B     ;STEP 4
                 MOV      DATA,A          ;ENTRY MODE SET
                CALL    TRANSFER        ;
                RET
LCD_RESET       ENDP
LCD_DISPLAY     PROC
                 MOV      A,10000000B     ;STEP 1
                 MOV      DATA,A          ;DD RAM ADDRESS SET
                CALL    TRANSFER        ;FIRST LINE
                 MOV      A,10H           ;STEP 2-1
                 MOV      COUNTER,A       ;WRITE DATA TO DD RAM
FIRST_LINE:
                CLR     LCD_CTRL.RS
                 MOV      A,00011100B     ;STEP 2-2
                 MOV      DATA,A          ;DISPLAY/CURSOR
                CALL    TRANSFER        ;SHIFT
                SET     LCD_CTRL.RS
                TABRDL  DATA
                CALL    TRANSFER
                CALL    DELAY
                INC     TBLP
                SDZ     COUNTER
                JMP     FIRST_LINE
                CLR     LCD_CTRL.RS
                 MOV      A,11000000B     ;STEP 3
                CALL    TRANSFER        ;SECOND LINE
                 MOV      A,10H           ;STEP 4-1
SECOND_LINE:
                CLR     LCD_CTRL.RS
                 MOV      A,00011000B     ;STEP 4-2
                SET     LCD_CTRL.RS
                TABRDL  DATA
                CALL    TRANSFER
                CALL    DELAY
                INC     TBLP
                SDZ     COUNTER
                JMP     SECOND_LINE
                CLR     LCD_CTRL.RS
                RET
LCD_DISPLAY     ENDP
TRANSFER        PROC
                SWAP    DATA
                 MOV      A,DATA
                 MOV      PC,A
                CALL    WRITE
                SWAP    DATA
                 MOV      A,DATA
                 MOV      PC,A
                CALL    WRITE
                RET
TRANSFER        ENDP
WRITE           PROC
                SET     LCD_CTRL.E
                CLR     LCD_CTRL.E
                 MOV      A,0FFH
                 MOV      DELAY_COUNTER_1,A
WRITE_WAIT:
                SDZ     DELAY_COUNTER_1
                JMP     WRITE_WAIT
                RET
WRITE           ENDP
DELAY           PROC
                 MOV      A,0A0H
                 MOV      DELAY_COUNTER_2,A
DELAY_WAIT:
                SDZ     DELAY_COUNTER_2
                JMP     DELAY_WAIT
                SDZ     DELAY_COUNTER_1
                JMP     DELAY_WAIT
                RET
DELAY           ENDP
DELAY_LONG      PROC
                 MOV      A,003H
                 MOV      DELAY_COUNTER_3,A
DELAY_LONG_WAIT:
                SDZ     DELAY_COUNTER_3
                JMP     DELAY_LONG_WAIT
                SDZ     DELAY_COUNTER_2
                JMP     DELAY_LONG_WAIT
                SDZ     DELAY_COUNTER_1
                JMP     DELAY_LONG_WAIT
                RET
DELAY_LONG      ENDP
                ORG     0F00H
LCD_MESSAGE_1:          ;[LCD 4 BITS DATA ]
                        ;[TRANSFER TEST OK]
                DC      4CH,43H,44H,20H,34H,20H,42H,49H
                DC      54H,53H,20H,44H,41H,54H,41H,20H
                DC      54H,52H,41H,4EH,53H,46H,45H,52H
                DC      20H,54H,45H,53H,54H,20H,4FH,4BH
LCD_MESSAGE_2:          ;[   MINI PIANO   ]
                        ;[ PRESS ANY KEY! ]
                DC      20H,20H,20H,4DH,49H,4EH,49H,20H
                DC      50H,49H,41H,4EH,4FH,20H,20H,20H
                DC      20H,50H,52H,45H,53H,53H,20H,41H
                DC      4EH,59H,20H,4BH,45H,59H,21H,20H
LCD_MESSAGE_3:          ;[   PLAY MUSIC   ]
                        ;[ JUST A MOMENT! ]
                DC      20H,20H,20H,50H,4CH,41H,59H,20H
                DC      4DH,55H,53H,49H,43H,20H,20H,20H
                DC      20H,4AH,55H,53H,54H,20H,41H,20H
                DC      4DH,4FH,4DH,45H,4EH,54H,21H,20H
MUSIC_DATA:
                DC      043H,0B1H,009H,033H
                DC      083H,0C7H,005H,023H
                DC      0FCH,0FCH,0FDH,0FDH
                DC      0FDH,0FDH,0FEH,0FEH
SONG_DATA:
                DC      06H,06H,05H,06H,05H,03H
                DC      05H,03H,03H,02H,03H,03H
                DC      02H,02H,01H,02H,02H,05H
                DC      04H,04H,04H,03H,02H,03H,03H
                DC      05H,05H,05H,05H,05H,07H
                DC      06H,06H,06H,06H,05H,06H,06H
                DC      08H,08H,08H,07H,05H
                DC      06H,06H,06H,06H,05H,06H,05H,03H
                END
