LoRa终端通信设计中应该考虑的协议灵活性
物联网
787人已加入
通信设计中考虑协议的灵活性,经常把协议设计成“不定长度”。一个实例如下图:锐米LoRa终端的通信协议帧。
LoRa
如果一个系统接收上述“不定长度”的协议帧,将会有一个挑战--如何高效接收与解析。
为简化系统设计,我们强烈建议您采用“状态机”来解析UART数据帧,并且把解析工作放在ISR(中断服务程序)完成,仅当接收到最后一个字节(0x0D)时,再将整个数据帧提交给进程处理。该解析状态机的原理如下图所示:
LoRa
那么ISR处理这个状态机来得及吗?答案是:so easy!因为它只有3个动作,运算量十分小:
比较接收数据 -》 更新状态变量 -》 存储接收数据,C语言仅3条语句,翻译成机器指令也不超过10条。
代码清单如下:
* @brief Status of received communication frame
typedef enum
STATUS_IDLE = (uint8_t)0,
STATUS_HEAD, /* Rx Head=0x3C */
STATUS_TYPE, /* Rx Type */
STATUS_DATA, /* Data filed */
STATUS_TAIL, /* Tail=0x0D */
STATUS_END, /* End of this frame */
} COMM_TRM_STATUS_TypeDef;
* @brief Data object for received communication frame
typedef struct
uint8_t byCnt; /* Count of 1 field */
uint8_t byDataLen; /* Length of data field */
uint8_t byFrameLen; /* Length of frame */
COMM_TRM_STATUS_TypeDef eRxStatus;
uint8_t a_byRxBuf[MAX_LEN_COMM_TRM_DATA];
} COMM_TRM_DATA;
* @brief Data object for received communication frame.
* @note Prevent race condition that accessed by both ISR and process.
static COMM_TRM_DATA s_stComm2TrmData;
* @brief Put a data that received by UART into buffer.
* @note Prevent race condition this called by ISR.
* @param uint8_t byData: the data received by UART.
* @retval None
void comm2trm_RxUartData(uint8_t byData)
/* Update status according to the received data */
switch (s_stComm2TrmData.eRxStatus)
case STATUS_IDLE:
if (COMM_TRM_HEAD == byData) /* Is Head */
s_stComm2TrmData.eRxStatus = STATUS_HEAD;
else
goto rx_exception;
break;
case STATUS_HEAD:
if (TYPE_INVALID_MIN 《 byData && byData 《 TYPE_INVALID_MAX) /* Valid type */
s_stComm2TrmData.eRxStatus = STATUS_TYPE;
else
goto rx_exception;
break;
case STATUS_TYPE:
if (byData 《= MAX_LEN_UART_FRAME_DATA) /* Valid data size */
s_stComm2TrmData.eRxStatus = STATUS_DATA;
s_stComm2TrmData.byDataLen = byData;
else
goto rx_exception;
break;
case STATUS_DATA:
if (s_stComm2TrmData.byCnt 《 s_stComm2TrmData.byDataLen)
++s_stComm2TrmData.byCnt;
else
s_stComm2TrmData.eRxStatus = STATUS_TAIL;
break;
case STATUS_TAIL:
if (COMM_TRM_TAIL == byData)
/* We received a frame of data, now tell process to deal with it! */
process_poll(&Comm2TrmProcess);
else
goto rx_exception;
break;
default:
ASSERT(!“Error: Bad status of comm2trm_RxUartData()。\r\n”);
break;
/* Save the received data */
s_stComm2TrmData.a_byRxBuf[s_stComm2TrmData.byFrameLen++] = byData;
return;
rx_exception:
ClearCommFrame();
return;
