MSP430单片机按键中断程序
#include "IRRemote.h"
void main(void)
    //初始化
    Initialize();
//死循环
    while(1)
        unsigned int transmit;
        //初始化变量
        transmit = ENDTRANSMIT;
        //等待按键按下
        SetForPress();
        //进入LPM4模式
        LPM4;
        Debounce();
        //扫描键盘
        KeySCAN();
        //键盘处理
        KeyLookup();
        if (Error_Flags == 0)
            //有键按下的情况
            SetupForRelease();
            do
                //传输数据(RC5码)
                Transmit();
                transmit = TestRetransmit();
                //延时
                DelayToNextTransmit();
            } while (transmit == RETRANSMIT);
void Initialize(void)
    //停止看门狗
    WDTCTL = WDTPW+WDTHOLD;
    //P2口为输出
    P2DIR = 0xFF;
    //P2.3为TA1功能管脚
    P2SEL = 0x08;
    //清除P2口的输出
    P2OUT = 0;
    //设置DCO频率为1MHz
    DCOCTL = CALDCO_1MHZ;
    BCSCTL1 = CALBC1_1MHZ;
    //使能中断
    _EINT();
void SetForPress(void)
    //P1.0和P1.1为输入
    P1DIR = 0xFC;
    //清除P1口的输出,下拉
    P1OUT = 0;
    //使能P1.0和P1.1的电阻
    P1REN |= 0x03;
    //使能键盘
    P2OUT |= 0x07;
    //低到高中断方式
    P1IES &= ~0x03;
    //清除中断标志
    P1IFG = 0;
    //使能中断
    P1IE |= 0x03;
    //清除错误标志
    Error_Flags = 0;
    //清除传输标志
    Trans_Flags = 0;
void Debounce(void)
    //SMCLK/8,清除TA
    TACTL = TASSEL1+TACLR+ID0+ID1;
    //使能CCR0中断
    TACCTL0 = CCIE;
    //设置延时的值
    TACCR0 = 5000 - 1;
    //开始UP模式
    TACTL |= MC0;
    //进入LPM0模式
    LPM0;
    //停止并清除TA
    TACTL = TACLR;
    //清除CCTL0寄存器
    TACCTL0 = 0;
void KeyScan(void)
    unsigned int i;
    //初始化行
    RowMask = 0x01;
    KeyHex = 0;
    //清除行的值
    P1OUT &= ~0x03;
    for (i=0; i
