TI TIDA-01407 400W 48V汽车电源参考设计
电源/新能源
3647人已加入
TI公司的TIDA-01407是用于汽车的36V-60V输入12V输出的400W汽车电源参考设计,采用增强的相移全桥控制器实现可编延时,从而保证了各种工作条件下零电压开关(ZVS).输出采用同步整流,具有快速瞬态响应和高回路带宽.无负载待机功耗< 100-mW,主要用在HEV/EV牵引逆变器,干双离合变速箱传输,电子控制单元和HEV/EV DC/DC转换器.本文介绍了参考设计TIDA-01407主要特性,电池驱动逆变器系统框图以及参考设计TIDA-01407主要系统指标,框图,电路图,材料清单和PCB设计图.
This reference design is an automotive, 400-W, phaseshiftedfull-bridge converter which enables a 36-V to60-V DC input and 12-V output. The enhanced phaseshiftedfull-bridge controller implements programmabledelays which ensure zero voltage switching (ZVS) overa wide range of operating conditions. The outputimplements synchronous rectification, which enablesfast transient response and a high loop bandwidth.
The system regulates 12 V at no load with less than100 mW of standby power. Pseudo isolation isachieved through a transformer to prevent the 48-Vbattery from being shorted to the secondary side. Thehalf-bridge gate drivers can withstand a maximum bootvoltage of 120-V DC.
参考设计TIDA-01407主要特性:
• Phase-Shifted Full-Bridge Converter Over InputVoltage of 36-V to 60-V DC; Output Power up to400 W
• Extendable to 500 W With Heatsinking; Easy toCustomize per Customer Requirements
• Soft-Switching, Phase-Shifted Full Bridge UsingUCC28951-Q1, Grade 1
• Synchronization Achievable for Multiple PhaseOperation
• Regulated 12 V With 36-V to 60-V Input and at NoLoad With< 100-mW Standby Power
• Pseudo-Isolation Through Transformer; Load DoesNot Register 48 V if MOSFETs Short
• Synchronous Rectification for High Efficiency
• Adaptive Delay for High Efficiency Across LoadRange
参考设计TIDA-01407应用:
• HEV/EV Traction Inverter
• Dry Double-Clutch Transmission
• Electronic Control Units
• HEV/EV DC-DC Converter
48V
图1.参考设计TIDA-01407外形图
48V
图2.参考设计TIDA-0140748V电池驱动逆变器系统框图
参考设计TIDA-01407主要系统指标:
48V
48V
图3.参考设计TIDA-01407框图
48V
图4.参考设计TIDA-01407电路图(1)
48V
图5.参考设计TIDA-01407电路图(2)
参考设计TIDA-01407材料清单:
48V
48V
图6.参考设计TIDA-01407 PCB设计图(1)
48V
图7.参考设计TIDA-01407 PCB设计图(2)
48V
图8.参考设计TIDA-01407 PCB设计图(3)
48V
图9.参考设计TIDA-01407 PCB设计图(4)
48V
图10.参考设计TIDA-01407 PCB设计图(5)
48V
图11.参考设计TIDA-01407 PCB设计图(6)
48V
图12.参考设计TIDA-01407 PCB设计图(7)
48V
图13.参考设计TIDA-01407 PCB设计图(8)
48V
图14.参考设计TIDA-01407 PCB设计图(9)
48V
图15.参考设计TIDA-01407 PCB设计图(10)
