开发者的福音:PyTorch 2.5现已支持英特尔独立显卡训练
[《PyTorch 2.5重磅更新:性能优化+新特性》]中的一个新特性就是:正式支持在英特尔^®^独立显卡上训练模型!
PyTorch 2.5
独立显卡类型
Intel^®^数据中心GPU Max系列
Intel^®^Arc™系列
本文将在Intel^®^Core™ Ultra 7 155H自带的Arc™集成显卡上展示使用Pytorch2.5搭建并训练AI模型的全流程。
搭建开发环境
首先,请安装显卡驱动,参考指南:
https://dgpu-docs.intel.com/driver/client/overview.html
然后,**请下载并安装Anaconda,**链接↓↓
https://www.anaconda.com/download
并用下面的命令创建并激活名为pytorch_arc的虚拟环境:
conda create -n pytorch_arc python=3.11    #创建虚拟环境
conda activate pytorch_arc                 #激活虚拟环境
python -m pip install --upgrade pip        #升级pip到最新版本
接着,安装Pytorch XPU版;
pip install --pre torch torchvision torchaudio --index-url https://download.pytorch.org/whl/nightly/xpu
滑动查看更多
最后,执行命令,验证安装。看到返回结果为“True”,证明环境搭建成功!
 > > > import torch
 > > > torch.xpu.is_available()
训练ResNet模型
执行下载的训练代码,实现在Intel^®^ Arc™集成显卡上训练ResNet50模型。代码下载链接:
https://gitee.com/Pauntech/Pytorch-2.5
import torch
import torchvision
LR = 0.001
DOWNLOAD = True
DATA = "datasets/cifar10/"
transform = torchvision.transforms.Compose(
        torchvision.transforms.Resize((224, 224)),
        torchvision.transforms.ToTensor(),
        torchvision.transforms.Normalize((0.5, 0.5, 0.5), (0.5, 0.5, 0.5)),
train_dataset = torchvision.datasets.CIFAR10(
    root=DATA,
    train=True,
    transform=transform,
    download=DOWNLOAD,
train_loader = torch.utils.data.DataLoader(dataset=train_dataset, batch_size=128)
train_len = len(train_loader)
model = torchvision.models.resnet50()
criterion = torch.nn.CrossEntropyLoss()
optimizer = torch.optim.SGD(model.parameters(), lr=LR, momentum=0.9)
model.train()
model = model.to("xpu")
criterion = criterion.to("xpu")
print(f"Initiating training")
for batch_idx, (data, target) in enumerate(train_loader):
    data = data.to("xpu")
    target = target.to("xpu")
    optimizer.zero_grad()
    output = model(data)
    loss = criterion(output, target)
    loss.backward()
    optimizer.step()
    if (batch_idx + 1) % 10 == 0:
         iteration_loss = loss.item()
         print(f"Iteration [{batch_idx+1}/{train_len}], Loss: {iteration_loss:.4f}")
torch.save(
        "model_state_dict": model.state_dict(),
        "optimizer_state_dict": optimizer.state_dict(),
    "checkpoint.pth",
print("Execution finished")
总结
使用[PyTorch]在英特尔独立显卡上训练模型将为AI行业新增计算硬件选择!
