基于TIDA-03027的USB Type-C多端口适配器电源参考设计
1.3w人已加入
TI公司的TIDA-03027是USB Type-C和供电多端口适配器电源参考设计,包括USB Type-C全特性的插座,可即时连接USB Type-C充电器(高达20V/3A)或设备。也可连接到HDMI 2.0和USB3.0 Type-A接口,主要用在笔记本电脑,平板电脑和带USB Type-C接口的电话系统。本文介绍了参考设计TIDA-03027主要特性,生态系统图和框图,电路图,材料清单和PCB设计图。
The TIDA-03027 reference design offers a multiportadapter solution that enables products with a USBType-C™ interface to connect to HDMI 2.0 and USB3.0 Type-A interfaces. The design also includes anadditional USB Type-C full-feature receptacle, whichallows the user to simultaneously connect USB Type-C chargers (up to 20 V, 3 A) or devices. This featureset is particularly useful as a peripheral to notebook,tablet, and phone systems with a single USB Type-Cinterface.
The TIDA-03027 reference design showcases a Type-C plug that allows a notebook, tablet, or phone tosimultaneously interface with HDMI 2.0, USB 3.0 Type-A, and USB Type-C systems (chargers anddevices)。 Thus, the board serves as a multiport adapter for USB Type-C hosts. This board features USB3.0 data, video, and charging (up to 20 V, 3 A) over a single, USB Type-C plug connection.
The USB Type-C plug and receptacle both interface with a TPS65983B device, which handles powerdelivery negotiations and controls the primary power field-effect transistors (FETs)。 Two SuperSpeedlanes (SSTX/RX2) are routed directly to a DisplayPort (DP) to HDMI converter. The other SuperSpeedlanes (SSTX/RX1) are routed to the HD3SS3212, which demuxes the signals between the DP-to-HDMIconverter and the TUSB8041 USB 3.0 HUB. This routing allows the TPS65983B device to controlbetween four-lanes of DP-to-HDMI and two-lanes of DP-to-HDMI + USB3.0 (for Type-A and Type-C dataconnections)。
The TUSB8041 is a USB 3.0 HUB, which receives high-speed and SuperSpeed signals from the upstreamUSB Type-C plug. This device expands the USB Type-C host signals to four ports, which allowssimultaneous USB 3.0 or USB 2.0 enumeration at the Type-C and Type-A receptacle ports. This devicealso enables the USB Type-C plug to utilize the USB 2.0 low-speed endpoint feature of the TPS65983B.
The power path between the USB Type-C plug and receptacle ports is controlled by the LM3489 variableDC-DC converter. The TPS65983B device controls the output voltage of the LM3489 device, dependingon the power contract that is negotiated with the USB Type-C host. This feature is particularly useful whenthere is a mismatch in power contracts between a USB Type-C host and charger.
Both USB Type-C interfaces utilize the TPS83S00 and TPD1E01B04 electrostatic discharge (ESD)devices for signal input-output (I/O) protection. The USB Type-A interface uses single-bit ESD(TPD1E01B04) for I/O protection. The HDMI interface is protected using the TPD13S523, which is anintegrated 13-channel ESD and current-limiting device.
参考设计TIDA-03027主要特性:
• USB Type-C and PD Full-Feature Plug
• Bi-Directional Power (up to 20 V, 3 A)
• Fast Role-Swap Capable
• Video (up to 4K) Through HDMI 2.0
• USB 3.0 Through USB Type-A or USB Type-C™Receptacle
• Aardvark Connector for Debug and Flash Update
• Flash Update Over USB Type-C™ Through USB2.0 Endpoint
参考设计TIDA-03027应用:
• Evaluation of USB Type-C Multiport Adapter andDongle Solutions With Video, Charging, and DataCapabilities
u
图1.参考设计TIDA-03027外形图
u
图2.参考设计TIDA-03027生态系统图
u
图3.参考设计TIDA-03027框图
u
图4.参考设计TIDA-03027电路图(1)
u
图5.参考设计TIDA-03027电路图(2)
u
图6.参考设计TIDA-03027电路图(3)
u
图7.参考设计TIDA-03027电路图(4)
u
图8.参考设计TIDA-03027电路图(5)
u
图9.参考设计TIDA-03027电路图(6)
u
图10.参考设计TIDA-03027电路图(7)
u
图11.参考设计TIDA-03027电路图(8)
u
图12.参考设计TIDA-03027电路图(9)
u
图13.参考设计TIDA-03027电路图(10)
u
图14.参考设计TIDA-03027电路图(11)
u
图15.参考设计TIDA-03027电路图(12)
参考设计TIDA-03027材料清单(BOM):
u
u
u
u
u
图16.参考设计TIDA-03027 PCB设计图(1)
u
图17.参考设计TIDA-03027 PCB设计图(2)
u
图18.参考设计TIDA-03027 PCB设计图(3)
u
图19.参考设计TIDA-03027 PCB设计图(4)
u
图20.参考设计TIDA-03027 PCB设计图(5)
u
图21.参考设计TIDA-03027 PCB设计图(6)
u
图22.参考设计TIDA-03027 PCB设计图(7)
u
图23.参考设计TIDA-03027 PCB设计图(8)
  • 相关推荐
  • u
  • t
