android如何获取本机ip地址及ip归属地
# 前言 #
本篇文章主要介绍android如何获取本机ip地址及ip归属地。
# 定义 #
ip地址是指手机在连接到互联网时所获得的唯一网络地址。
ip归属地是指通过ip地址查询器对应的地理位置信息,如省市区等信息。
# 获取ip地址 #
如果只是查看本机ip,不涉及应用开发,可以依次打开手机设置-我的设备-状态信息-ip地址界面进行查看(不同品牌手机型号会有差异)。
下面开发过程中获取本机ip方法:
1.首先是要在清单文件中配置必要的权限:
2.手机在不同的网络环境下获取ip的方法:
   //获取ip
   public void getIPAddress(Context context) {
       ConnectivityManager cm = (ConnectivityManager) context.getSystemService(Context.CONNECTIVITY_SERVICE);
       NetworkInfo networkInfo = cm.getActiveNetworkInfo();
       if (networkInfo != null && networkInfo.isConnectedOrConnecting()) {
           //网络连接可用,判断网络连接类型
           if (networkInfo.getType() == ConnectivityManager.TYPE_WIFI) {
               //wifi网络
               WifiManager wifiManager = (WifiManager) context.getSystemService(Context.WIFI_SERVICE);
               WifiInfo wifiInfo = wifiManager.getConnectionInfo();
               int ipAddress = wifiInfo.getIpAddress();
               String ip = String.format("%d.%d.%d.%d",
                       (ipAddress & 0xff),
                       (ipAddress >> 8 & 0xff),
                       (ipAddress >> 16 & 0xff),
                       (ipAddress >> 24 & 0xff));
               Log.e("tag", "ip:" + ip);
           } else if (networkInfo.getType() == ConnectivityManager.TYPE_MOBILE) {
               //移动网络
               getLocalIpAddress();
       } else {
           //没有网络链接
   private void getLocalIpAddress() {
       try {
           ArrayList networkInterfaces = Collections.list(NetworkInterface.getNetworkInterfaces());
           for (NetworkInterface networkInterface : networkInterfaces) {
               ArrayList inetAddresses = Collections.list(networkInterface.getInetAddresses());
               for (InetAddress address : inetAddresses) {
                   String ip = address.getHostAddress();
                   if (!address.isLoopbackAddress() && (address instanceof Inet4Address)) {
                       Log.e("tag", "ipv4:" + ip);
                   if (!address.isLoopbackAddress() && (address instanceof Inet6Address)) {
                       Log.e("tag", "ipv6:" + ip);
       } catch (SocketException socketException) {
           Log.e("tag", socketException.getMessage());
# 获取ip归属地 #
想要获取到ip归属地,一般需要获取到ip地址后通过第三方服务来查询,下面展示一下android使用ip数据云获取ip归属地的具体方法:
 //获取ip归属地
   private Location getIpData(String ip, String key) {
       Location location = null;
       try {
           URL url = new URL("https://api.ipdatacloud.com/v2/query?ip=" + ip + "&key=+" + key);
           HttpURLConnection connection = (HttpURLConnection) url.openConnection();
           BufferedReader in = new BufferedReader(new InputStreamReader(connection.getInputStream()));
           StringBuffer sb = new StringBuffer();
           String line;
           while ((line = in.readLine()) != null) {
               sb.append(line);
           in.close();
           connection.disconnect();
           // 解析返回的JSON数据,获取IP归属地信息
           // 这里需要使用JSON解析库,例如gson、fastjson
           String jsonResult = sb.toString();
           location = new Gson().fromJson(jsonResult, Location.class);
       } catch (Exception e) {
           e.printStackTrace();
       return location;
   class Location {
       private String AreaCode;        //行政区码
       private String City;            //城市
       private String CityCode;        //城市代码
       private String Continent;       //洲
       private String Country;         //国家/地区
       private String CountryCode;     //国家/地区英文简写
       private String District;        //区县
       private String Elevation;       //海拔
       private String Ip;              //ip地址
       private String Isp;             //运营商
       private String Latitude;        //纬度
       private String Longitude;       //经度
       private Street[] MultiStreet;   //历史街道位置
       private String Province;        //省份
       private String Street;          //街道
       private String TimeZone;        //时区
       private String WeatherStation;  //气象站
       private String ZipCode;         //邮编
   class Street {
       private String Lng;             //经度
       private String Lat;             //纬度
       private String Radius;          //范围半径
       private String ZipCode;         //邮政编码
# 总结 #
本文简要总结了android获取ip地址及归属地的方法,在实际开发中还需要根据自身的实际情况进行修改。
在众多第三方服务中,ip数据云作为新一代ip地址数据服务领军者,为广大开发者提供了丰富的产品服务,具体可去官网https://www.ipdatacloud.com/?utm-source=WZJ&utm-keyword=?2826进行测试、咨询。
