康希通信美林美深射频前端模组KCT8526H替代SKY85712-21国产替代
亲爱的科技爱好者、无线通信领域的专家们,以及追求极致性能的设备制造商们,今天,我们满怀激动地向大家介绍一款颠覆性的产品——KCT8526H。这款高集成的射频前端集成电路(RF Front-End IC)专为IEEE 802.11a/n/ac WLAN系统设计,工作频段覆盖5.15-5.85GHz,是构建高性能、多标准支持的5GHz WLAN系统的理想选择。
Dear technology enthusiasts, wireless communication experts, and device manufacturers pursuing extreme performance, today we are excited to introduce a disruptive product - KCT8526H. Designed for IEEE 802.11a/n/ac WLAN systems, this highly integrated RF Front-End IC operates in the 5.15-5.85GHz band, making it ideal for building high-performance, multi-standard supported 5GHz WLAN systems.
在无线通信领域,射频前端组件的性能和集成度直接决定了整个系统的性能和成本效益。KCT8526H正是基于这一理念而设计的,它将关键射频功能——包括高效高线性功率放大器(PA)、带旁路的低噪声放大器(LNA)、匹配网络、LO抑制和谐波滤波器——全部集成在一个紧凑的设备中,实现了前所未有的集成度和性能提升。
In the field of wireless communication, the performance and integration of RF front-end components directly determine the performance and cost-effectiveness of the entire system. The KCT8526H is based on this philosophy and integrates key RF functions-including high-efficiency high-linear power amplifiers (PA), low-noise amplifiers (LNA) with bypass, matching networks, LO rejection, and harmonic filters-into a compact device, achieving unprecedented levels of integration and performance.
作为射频前端的核心组件,功率放大器(PA)的性能直接关系到信号的传输距离和系统的覆盖范围。KCT8526H内置的PA以其高效和高线性度著称,能够在5V供电下提供稳定的输出功率。在VHT80/MCS9模式下,当误差矢量幅度(DEVM)为-35dB时,输出功率可达+23dBm;而在HT20/MCS7模式下,当DEVM为-30dB时,输出功率更是高达+24dBm。这样的性能表现,使得KCT8526H成为构建远距离、高覆盖WLAN系统的首选。
As the core component of the RF front end, the performance of the power amplifier (PA) is directly related to the transmission distance of the signal and the coverage range of the system. The KCT8526H's built-in PA is known for its efficiency and high linearity, providing a stable output power at 5V power supply. In VHT80/MCS9 mode, when the error vector amplitude (DEVM) is -35dB, the output power can reach +23dBm; In HT20/MCS7 mode, when DEVM is -30dB, the output power is as high as +24dBm. This performance makes the KCT8526H the first choice for building long-range, high-coverage WLAN systems.
为了方便系统监控和管理,KCT8526H还内置了功率检测器。这一功能可以实时监测PA的输出功率,为系统优化和故障排查提供重要数据支持。通过精准监控输出功率,用户可以更好地了解系统的运行状态,及时调整和优化系统参数,确保系统的稳定性和可靠性。
In order to facilitate system monitoring and management, the KCT8526H also has a built-in power detector. This function can monitor the PA output power in real time, providing important data support for system optimization and troubleshooting. By accurately monitoring the output power, users can better understand the operating status of the system, adjust and optimize the system parameters in time, and ensure the stability and reliability of the system.
小巧封装,易于集成
在封装方面,KCT8526H同样表现出色。它采用了紧凑的3.0x3.0x0.55mm 16-lead QFN封装,是目前市场上同类产品中封装尺寸最小的之一。这种小巧的封装设计使得KCT8526H非常易于集成到各种小型化设备中,如智能手机、平板电脑、路由器等,为设备制造商提供了更多的设计灵活性和空间利用率。
Compact package for easy integration
In terms of packaging, the KCT8526H also performs well. It comes in a compact 3.0x3.0x0.55mm 16-lead QFN package, one of the smallest in its class on the market today. This compact package design makes the KCT8526H very easy to integrate into a variety of miniaturized devices such as smartphones, tablets, routers, etc., providing device manufacturers with more design flexibility and space utilization.
全面静电防护,保障系统安全
在电子产品的设计中,静电防护是不可忽视的一环。KCT8526H的所有引脚都通过了ESD静电防护标准,有效防止静电放电对模组造成的损害,提高了产品的可靠性和使用寿命。这一设计使得KCT8526H在恶劣的电磁环境中也能保持稳定的性能表现。
Comprehensive electrostatic protection to ensure system safety
In the design of electronic products, electrostatic protection is an important part. All the pins of KCT8526H have passed the ESD electrostatic protection standard, effectively preventing the damage caused by electrostatic discharge to the module, and improving the reliability and service life of the product. This design enables the KCT8526H to maintain stable performance even in harsh electromagnetic environments.
环保认证,绿色制造
我们深知环保的重要性,因此KCT8526H在设计和生产过程中严格遵守ROHS和REACH环保标准。这意味着该产品不含任何有害物质,对环境友好,同时也保障了用户的健康安全。
Environmental certification, green manufacturing
We understand the importance of environmental protection, which is why the KCT8526H is designed and manufactured in strict compliance with ROHS and REACH environmental standards. This means that the product does not contain any harmful substances, is friendly to the environment, and also guarantees the health and safety of users.
产品规格
集成802.11ac 5GHz PA、带旁路的LNA和T/R开关
完全匹配的输入和输出
集成功率检测器
发射增益:5V时31dB
输出功率:
+23dBm(VHT80/MCS9,DEVM=-35dB,5V)
+24dBm(HT20/MCS7,DEVM=-30dB,5V)
接收增益:5V时16.5dB
噪声系数:5V时1.7dB
所有引脚带ESD保护电路
所需外部组件极少
小封装:QFN-16L,3.0mm x 3.0mm x 0.55mm(MSL3,260℃符合JEDEC J-STD-020标准)
RoHS和REACH合规
