顺络电子sunlord美林美深MnO₂钽电容器TC212A476K006Y
钽电容,作为一种以钽金属为阳极材料制成的电容器,具有体积小、容量大、工作电压高、稳定性好等优点。与铝电解电容相比,钽电容在高频和脉冲电路中表现出更低的等效串联电阻(ESR)和更高的能量密度。因此,钽电容被广泛应用于通信、消费电子、仪器仪表、医疗电子等领域。
Tantalum capacitor, as a kind of capacitor made of tantalum metal as anode material, has the advantages of small size, large capacity, high operating voltage and good stability. Tantalum capacitors exhibit lower equivalent series resistance (ESR) and higher energy density in high frequency and pulse circuits compared to aluminum electrolytic capacitors. Therefore, tantalum capacitors are widely used in communication, consumer electronics, instrumentation, medical electronics and other fields.
TC212A476K006Y是深圳顺络电子有限公司推出的一款高性能钽电容器。从规格书可以看出,这款电容器具有多项显著特点:
TC212A476K006Y is a high performance tantalum capacitor launched by Shenzhen Shunluo Electronics Co., LTD. As can be seen from the specification, this capacitor has a number of notable features:
高可靠性:TC212A476K006Y钽电容符合或超过EIA-535BAAC标准,具有自我修复能力,能够在恶劣的工作环境中保持高稳定性。
High reliability: The TC212A476K006Y tantalum capacitor meets or exceeds the EIA-535BAAC standard, has self-healing capability, and can maintain high stability in harsh working environments.
宽广的工作温度范围:其工作温度范围达到-55°C至+125°C,适用于各种极端条件下的应用。
Wide operating temperature range: Its operating temperature range of -55°C to +125°C is suitable for applications under various extreme conditions.
高容量稳定性:在工作温度范围内,电容器的容量保持稳定,为电路提供稳定的电荷存储能力。
High capacity stability: In the operating temperature range, the capacity of the capacitor remains stable, providing a stable charge storage capacity for the circuit.
高体积效率:得益于钽金属的高能量密度,TC212A476K006Y在较小的体积内提供了较高的电容值,有利于电路的小型化和集成化。
High volume efficiency: Thanks to the high energy density of tantalum metal, TC212A476K006Y provides a high capacitance value in a small volume, which is conducive to the miniaturization and integration of the circuit.
三、详细规格
1. 产品标识与尺寸
TC212A476K006Y的产品标识中,各个字符代表了不同的含义:
TC:代表产品系列。
212:表示外部尺寸(LxW)为6.0×3.2mm的封装。
A:表示低ESR(等效串联电阻)类型。
476:表示电容器的标称容量为47μF。
K:表示电容器的容量公差为±10%。
006:表示电容器的额定电压为6.3Vdc。
此外,规格书中还详细列出了各种尺寸的电容器封装及其对应的EIA标准代码,如3216-18、3528-21等,方便工程师在设计时选择合适的封装。
1. Product identification and size
In the product identification of TC212A476K006Y, each character represents different meanings:
TC: indicates the product series.
212: represents a package with an external dimension (LxW) of 6.0×3.2mm.
A: Indicates low ESR (equivalent series resistance) type.
476: indicates that the nominal capacity of the capacitor is 47μF.
K: indicates that the capacitance tolerance of the capacitor is ±10%.
006: indicates that the rated voltage of the capacitor is 6.3Vdc.
In addition, the specification also details various sizes of capacitor packages and their corresponding EIA standard codes, such as 3216-18, 3528-21, etc., so that engineers can choose the right package when designing.
电性能参数
TC212A476K006Y的电性能参数同样出色:
容量范围:从0.15μF到680μF不等,可根据具体需求选择合适的容量。
容量公差:±10%或±20%,确保电容器在制造过程中的精度。
额定电压:提供多种额定电压选项,如4V、10V、16V、20V等,满足不同电路的需求。
工作温度范围:-55°C至+125°C,确保电容器在各种极端温度下的可靠性。
等效串联电阻(ESR):低ESR设计,有助于降低电路中的功耗和热量产生。
漏电流(DCL):在特定条件下,电容器的漏电流被控制在较小范围内,保证电路的稳定性。
Electrical property parameter
The electrical performance parameters of the TC212A476K006Y are also excellent:
Capacity range: from 0.15μF to 680μF, suitable capacity can be selected according to specific requirements.
Capacity tolerance: ±10% or ±20%, ensuring the accuracy of the capacitor in the manufacturing process.
Rated voltage: Provide a variety of rated voltage options, such as 4V, 10V, 16V, 20V, etc., to meet the needs of different circuits.
Operating temperature range: -55°C to +125°C, ensuring the reliability of the capacitor in a variety of extreme temperatures.
Equivalent Series resistance (ESR) : Low ESR design helps reduce power consumption and heat generation in the circuit.
Leakage current (DCL) : Under certain conditions, the leakage current of the capacitor is controlled within a small range to ensure the stability of the circuit.
构造与极性标识
TC212A476K006Y采用模制外壳封装,负极端为银色粘附垫片,并带有极性条纹以标识电容器的极性。内部构造包括钽阳极、二氧化锰阴极涂层、碳银漆层以及钽引线等。此外,规格书中还详细列出了电容器的标记方法,包括额定电压代码、容量代码等,方便用户在使用时进行识别和选择。
The TC212A476K006Y is packaged in a moulded housing with a silver adhesive spacer at the negative end and a polar stripe to identify the polarity of the capacitor. The internal structure includes tantalum anode, manganese dioxide cathode coating, carbon-silver coating and tantalum lead. In addition, the specification also lists in detail the marking method of the capacitor, including the rated voltage code, the capacity code, etc., to facilitate the user to identify and select when in use.
应用场景与优势
凭借其出色的性能和稳定性,TC212A476K006Y钽电容在多个领域具有广泛的应用前景:
通信领域:在移动通信、固定电话等通信设备中,TC212A476K006Y可用于滤波、去耦和储能等电路,确保信号的稳定传输和电路的高效运行。
消费电子:在智能手机、平板电脑、数码相机等消费电子产品中,TC212A476K006Y可用于电源管理、音频电路和信号处理等方面,提高产品的性能和稳定性。
仪器仪表:在精密仪器仪表中,TC212A476K006Y可用于时间延迟电路、测量电路和控制系统等,确保测量结果的准确性和可靠性。
医疗电子:在医疗设备中,TC212A476K006Y可用于起搏器、监护仪等生命支持设备中,确保设备的长期稳定运行和患者的安全。
与其他类型的电容器相比,TC212A476K006Y钽电容具有以下显著优势:
高能量密度:在相同体积下,钽电容能够提供更高的电容值,有利于电路的小型化和集成化。
低ESR:低ESR设计有助于降低电路中的功耗和热量产生,提高电路的效率和稳定性。
长寿命:钽电容具有自我修复能力,能够在一定程度上恢复其电容值,延长电容器的使用寿命。
宽广的工作温度范围:适用于各种极端温度条件下的应用,确保电路在各种环境下的可靠性。
