瑞芯微RK3566/RK3568开发板安卓11固件ROOT教程,触觉智能Purple Pi OH演示
本文介绍RK3566/RK3568开发板Android11系统,编译ROOT权限固件的方法。触觉智能Purple Pi OH鸿蒙开发板演示,搭载了瑞芯微RK3566四核处理器,Laval鸿蒙社区推荐开发板,已适配全新OpenHarmony5.0 Release系统,SDK源码全开放!
关闭Selinux
修改以下路径文件:
adevice/rockchip/common/BoardConfig.mk
修改代码如下:
BOARD_BOOT_HEADER_VERSION ?= 2
BOARD_MKBOOTIMG_ARGS :=
BOARD_PREBUILT_DTBOIMAGE ?= $(TARGET_DEVICE_DIR)/dtbo.img
BOARD_ROCKCHIP_VIRTUAL_AB_ENABLE ?= false
-BOARD_SELINUX_ENFORCING ?= true
+BOARD_SELINUX_ENFORCING ?= false
注意:"+"号为修改内容。
注释用户组权限检测
修改以下路径文件:
system/extras/su/su.cpp
修改代码如下:
void extract_uidgids(const char* uidgids, uid_t* uid, gid_t*
gid, gid_t* gids, i
int main(int argc, char** argv) {
- uid_t current_uid = getuid();
- if (current_uid != AID_ROOT && current_uid != AID_SHELL) error(1, 0, "notallowed");
+ //uid_t current_uid = getuid();
+ //if (current_uid != AID_ROOT && current_uid != AID_SHELL) error(1, 0, "notallowed");
注意:"+"号为修改内容。
​给su文件默认授予root权限
修改以下路径文件:
system/core/libcutils/fs_config.cpp
修改代码如下:
static const struct fs_path_config android_files[] = {
// the following two files are INTENTIONALLY set-uid, but they
// are NOT included on user builds.{ 06755, AID_ROOT, AID_ROOT, 0, "system/xbin/procmem" },
- { 04750, AID_ROOT, AID_SHELL, 0, "system/xbin/su" },
+ { 06755, AID_ROOT, AID_SHELL, 0, "system/xbin/su" },
修改以下路径文件:
frameworks
/base/
core
/jni/
com_android_internal_os_Zygote.cpp
修改代码如下:
static void DropCapabilitiesBoundingSet(fail_fn_t fail_fn) {
for (int i = 0; prctl(PR_CAPBSET_READ, i, 0, 0, 0) >= 0; i++) {;
if (prctl(PR_CAPBSET_DROP, i, 0, 0, 0) == -1) {
if (errno == EINVAL) {
ALOGE("prctl(PR_CAPBSET_DROP) failed with EINVAL. Please verify
"your kernel is compiled with file capabilities support");      } else {
        fail_fn(CREATE_ERROR("prctl(PR_CAPBSET_DROP, %d) failed: %s", i, strerror(errno)));
修改以下路径文件:
kernel/security/commoncap.c
修改代码如下:
int cap_task_setnice(struct task_struct *p, int nice)
static int cap_prctl_drop(unsigned long cap){
    struct cred *new;
    if (!ns_capable(current_user_ns(), CAP_SETPCAP))
    return -EPERM;
    if (!cap_valid(cap))
    return -EINVAL;-+*/
    new = prepare_creds();
注意:"+"号为修改内容。
源码编译并测试
修改完上面三个步骤的文件后,即可在源码根目录下编译安卓源码:
# make -j4
下载Root Checker(ROOT检查工具),通过ADB命令或者U盘安装后,打开按照提示点击按钮检测ROOT,如图:
RK3566
若ROOT成功则如图所示:
RK3566
