Zynq 7015 linux跑起来之SD分区并放入对应的文件介绍
现在所要的文件基本上已都有了,怎么样来放到SD卡里来让系统运行起来呢?这里主要介绍Linux下面的方法,Windows下面用工具分就不说了。
sudo fdisk /dev/sdx(这里根据实情情况来) fdisk 的使用在网上找。这里主要是建立两个分区。
  然后进行格式化,一个FAT32格式,一个EXT4格式。
  U-Boot 2016.07 (Dec 16 2016 - 15:04:03 +0800)
  Model: Zynq PicoZed Board
  Board: Xilinx Zynq
  DRAM: ECC disabled 1 GiB
  MMC: sdhci@e0100000: 0
  Using default environment
  In: serial@e0001000
  Out: serial@e0001000
  Err: serial@e0001000
  Board: Xilinx Zynq
  Net: ZYNQ GEM: e000b000, phyaddr 0, interface rgmii-id
  PHY is not detected
  GEM PHY init failed
  No ethernet found.
  Hit any key to stop autoboot: 0
  Device: sdhci@e0100000
  Manufacturer ID: 3
  OEM: 5344
  Tran Speed: 50000000
  Rd Block Len: 512
  SD version 3.0
  High Capacity: Yes
  Capacity: 3.7 GiB
  Bus Width: 4-bit
  Erase Group Size: 512 Bytes
  reading uEnv.txt
  ** Unable to read file uEnv.txt **
  Copying Linux from SD to RAM.。。
  reading uImage
  3448056 bytes read in 617 ms (5.3 MiB/s)
  reading devicetree.dtb
  9660 bytes read in 19 ms (496.1 KiB/s)
  reading uramdisk.image.gz
  3694108 bytes read in 674 ms (5.2 MiB/s)
  ## Booting kernel from Legacy Image at 02080000 。。.
  Image Name: Linux-3.18.0-xilinx
  Image Type: ARM Linux Kernel Image (uncompressed)
  Data Size: 3447992 Bytes = 3.3 MiB
  Load Address: 02080000
  Entry Point: 02080000
  Verifying Checksum 。。. OK
  Wrong Ramdisk Image Format
  Ramdisk image is corrupt or invalid
  这里用的文件系统是直接用的zedboard里面带的,直接用是用不了的,简单改名也行不能,那么怎么办呢?
  gavin@zynq# print
  baudrate=115200
  bitstream_image=system.bit.bin
  boot_image=BOOT.bin
  boot_size=0xF00000
  bootcmd=run $modeboot
  bootdelay=2
  bootenv=uEnv.txt
  devicetree_image=devicetree.dtb
  devicetree_load_address=0x2000000
  devicetree_size=0x20000
  dfu_mmc=run dfu_mmc_info && dfu 0 mmc 0
  dfu_mmc_info=set dfu_alt_info ${kernel_image} fat 0 1\;${devicetree_image} fat 0 1\;${ramdisk_image} fat 0 1
  dfu_ram=run dfu_ram_info && dfu 0 ram 0
  dfu_ram_info=set dfu_alt_info ${kernel_image} ram 0x3000000 0x500000\;${devicetree_image} ram 0x2A00000 0x20000\;0
  ethaddr=00:0a:35:00:01:22
  fdt_high=0x20000000
  fdtcontroladdr=3ff95c10
  fileaddr=4000000
  filesize=385e1c
  importbootenv=echo Importing environment from SD 。。.; env import -t ${loadbootenv_addr} $filesize
  initrd_high=0x20000000
  jtagboot=echo TFTPing Linux to RAM.。。 && tftpboot ${kernel_load_address} ${kernel_image} && tftpboot ${devicetree_l}
  kernel_image=uImage
  kernel_load_address=0x2080000
  kernel_size=0x500000
  loadbit_addr=0x100000
  loadbootenv=load mmc 0 ${loadbootenv_addr} ${bootenv}
  loadbootenv_addr=0x2000000
  mmc_loadbit=echo Loading bitstream from SD/MMC/eMMC to RAM.。 && mmcinfo && load mmc 0 ${loadbit_addr} ${bitstream_i}
  modeboot=sdboot
  nandboot=echo Copying Linux from NAND flash to RAM.。。 && nand read ${kernel_load_address} 0x100000 ${kernel_size} &}
  norboot=echo Copying Linux from NOR flash to RAM.。。 && cp.b 0xE2100000 ${kernel_load_address} ${kernel_size} && cp.}
  preboot=if test $modeboot = sdboot && env run sd_uEnvtxt_existence_test; then if env run loadbootenv; then env run
  qspiboot=echo Copying Linux from QSPI flash to RAM.。。 && sf probe 0 0 0 && sf read ${kernel_load_address} 0x100000 }
  ramdisk_image=uramdisk.image.gz
  ramdisk_load_address=0x4000000
  ramdisk_size=0x5E0000
  rsa_jtagboot=echo TFTPing Image to RAM.。。 && tftpboot 0x100000 ${boot_image} && zynqrsa 0x100000 && bootm ${kernel_}
  rsa_nandboot=echo Copying Image from NAND flash to RAM.。。 && nand read 0x100000 0x0 ${boot_size} && zynqrsa 0x10000}
  rsa_norboot=echo Copying Image from NOR flash to RAM.。。 && cp.b 0xE2100000 0x100000 ${boot_size} && zynqrsa 0x10000}
  rsa_qspiboot=echo Copying Image from QSPI flash to RAM.。。 && sf probe 0 0 0 && sf read 0x100000 0x0 ${boot_size} &&}
  rsa_sdboot=echo Copying Image from SD to RAM.。。 && load mmc 0 0x100000 ${boot_image} && zynqrsa 0x100000 && bootm $}
  sd_uEnvtxt_existence_test=test -e mmc 0 /uEnv.txt
  sdboot=if mmcinfo; then run uenvboot; echo Copying Linux from SD to RAM.。。 && load mmc 0 ${kernel_load_address} ${ki
  stderr=serial@e0001000
  stdin=serial@e0001000
  stdout=serial@e0001000
  thor_mmc=run dfu_mmc_info && thordown 0 mmc 0
  thor_ram=run dfu_ram_info && thordown 0 ram 0
  uenvboot=if run loadbootenv; then echo Loaded environment from ${bootenv}; run importbootenv; fi; if test -n $uenvci
  usbboot=if usb start; then run uenvboot; echo Copying Linux from USB to RAM.。。 && load usb 0 ${kernel_load_address}i
  Environment size: 4851/131068 bytes
  这是直接在之前的文件系统基础上面改的。
  gunzip ramdisk8M.image.gz
  mkimage -n ‘uboot ext2 ramdisk’ -A arm -O linux -T ramdisk -C gzip -d ramdisk8M.image uramdisk.image.gz
  Board: Xilinx Zynq
  In: serial@e0001000
  Board: Xilinx Zynq
  PHY is not detected
  GEM PHY init failed
  No ethernet found.
  Manufacturer ID: 3
  OEM: 5344
  Rd Block Len: 512
  SD version 3.0
  High Capacity: Yes
  Capacity: 3.7 GiB
  Bus Width: 4-bit
  reading uEnv.txt
  reading uImage
  3448056 bytes read in 618 ms (5.3 MiB/s)
  9660 bytes read in 18 ms (523.4 KiB/s)
  8388672 bytes read in 1505 ms (5.3 MiB/s)
  ## Loading init Ramdisk from Legacy Image at 04000000 。。.
  Image Name: uboot ext2 ramdisk
  Image Type: ARM Linux RAMDisk Image (gzip compressed)
  Data Size: 8388608 Bytes = 8 MiB
  Load Address: 00000000
  Entry Point: 00000000
  ## Flattened Device Tree blob at 02000000
  Booting using the fdt blob at 0x2000000
  Loading Kernel Image 。。. OK
  Loading Ramdisk to 1f800000, end 20000000 。。. OK
  Loading Device Tree to 1f7fa000, end 1f7ff5bb 。。. OK
  Starting kernel 。。.
  到这一步,基本上就离成功不远了,我就不一一分析了 ,但直觉告诉我,应该是串口没有设对。所以我直接去到内核源码中,修改dts文件,直接将串口1改为0,然后 重新生成devcietree.dtb文件,然后替换掉SD卡里面的就OK了。下面是完整的打印信息。
  Board: Xilinx Zynq
  In: serial@e0001000
  Board: Xilinx Zynq
  PHY is not detected
  GEM PHY init failed
  No ethernet found.
  Manufacturer ID: 3
  OEM: 5344
  Rd Block Len: 512
  SD version 3.0
  High Capacity: Yes
  Capacity: 3.7 GiB
  Bus Width: 4-bit
  reading uEnv.txt
  reading uImage
  9133 bytes read in 24 ms (371.1 KiB/s)
  8388672 bytes read in 1504 ms (5.3 MiB/s)
  Loading Device Tree to 1f7fa000, end 1f7ff3ac 。。. OK
  Starting kernel 。。.
  Booting Linux on physical CPU 0x0
  Linux version 3.18.0-xilinx (gavin@oscom) (gcc version 4.9.2 (Sourcery CodeBench Lite 2015.05-17) ) #1 SMP PREEMPT 6
  CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
  CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
  Machine model: Zynq PicoZed Board
  cma: Reserved 16 MiB at 0x3f000000
  Memory policy: Data cache writealloc
  PERCPU: Embedded 10 pages/cpu @7e7d1000 s8768 r8192 d24000 u40960
  Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
  Kernel command line: console=ttyPS0,115200 root=http://xilinx.eetrend.com/dev/ram rw earlyprintk
  PID hash table entries: 4096 (order: 2, 16384 bytes)
  Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
  Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
  Memory: 1007836K/1048576K available (4646K kernel code, 258K rwdata, 1616K rodata, 216K init, 219K bss, 40740K rese)
  Virtual kernel memory layout:
  vector : 0xffff0000 - 0xffff1000 ( 4 kB)
  fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
  vmalloc : 0x80800000 - 0xff000000 (2024 MB)
  lowmem : 0x40000000 - 0x80000000 (1024 MB)
  pkmap : 0x3fe00000 - 0x40000000 ( 2 MB)
  modules : 0x3f000000 - 0x3fe00000 ( 14 MB)
  .text : 0x40008000 - 0x40625b04 (6263 kB)
  .init : 0x40626000 - 0x4065c000 ( 216 kB)
  .data : 0x4065c000 - 0x4069cb60 ( 259 kB)
  .bss : 0x4069cb60 - 0x406d3a78 ( 220 kB)
  Preemptible hierarchical RCU implementation.
  Dump stacks of tasks blocking RCU-preempt GP.
  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
  RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
  NR_IRQS:16 nr_irqs:16 16
  L2C-310 erratum 769419 enabled
  L2C-310 enabling early BRESP for Cortex-A9
  L2C-310 full line of zeros enabled for Cortex-A9
  L2C-310 ID prefetch enabled, offset 1 lines
  L2C-310 dynamic clock gating enabled, standby mode enabled
  L2C-310 cache controller enabled, 8 ways, 512 kB
  L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76360001
  slcr mapped to 80804000
  zynq_clock_init: clkc starts at 80804100
  Zynq clock init
  sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 3298534883328ns
  timer #0 at 80806000, irq=43
  Console: colour dummy device 80x30
  Calibrating delay loop.。。 1332.01 BogoMIPS (lpj=6660096)
  pid_max: default: 32768 minimum: 301
  Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
  Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
  CPU: Testing write buffer coherency: ok
  CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
  Setting up static identity map for 0x466698 - 0x4666f0
  CPU1: Booted secondary processor
  CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
  Brought up 2 CPUs
  SMP: Total of 2 processors activated.
  CPU: All CPU(s) started in SVC mode.
  devtmpfs: initialized
  VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
  regulator-dummy: no parameters
  NET: Registered protocol family 16
  DMA: preallocated 256 KiB pool for atomic coherent allocations
  cpuidle: using governor ladder
  cpuidle: using governor menu
  hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
  hw-breakpoint: maximum watchpoint size is 4 bytes.
  zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0x80880000
  VCCPINT: 1000 mV
  vgaarb: loaded
  SCSI subsystem initialized
  usbcore: registered new interface driver usbfs
  usbcore: registered new interface driver hub
  usbcore: registered new device driver usb
  media: Linux media interface: v0.10
  Linux video capture interface: v2.00
  pps_core: LinuxPPS API ver. 1 registered
  pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
  PTP clock support registered
  EDAC MC: Ver: 3.0.0
  Advanced Linux Sound Architecture Driver Initialized.
  Switched to clocksource arm_global_timer
  NET: Registered protocol family 2
  TCP established hash table entries: 8192 (order: 3, 32768 bytes)
  TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
  TCP: Hash tables configured (established 8192 bind 8192)
  TCP: reno registered
  UDP hash table entries: 512 (order: 2, 16384 bytes)
  UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
  RPC: Registered named UNIX socket transport module.
  RPC: Registered udp transport module.
  RPC: Registered tcp transport module.
  RPC: Registered tcp NFSv4.1 backchannel transport module.
  Trying to unpack rootfs image as initramfs.。。
  rootfs image is not initramfs (junk in compressed archive); looks like an initrd
  Freeing initrd memory: 8192K (5f800000 - 60000000)
  hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
  futex hash table entries: 512 (order: 3, 32768 bytes)
  jffs2: version 2.2. (NAND) (SUMMARY) ?© 2001-2006 Red Hat, Inc.
  msgmni has been set to 2016
  io scheduler noop registered
  io scheduler deadline registered
  io scheduler cfq registered (default)
  dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
  dma-pl330 f8003000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
  xuartps e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 82, base_baud = 3125000) is a xuartps
  console [ttyPS0] enabled
  xdevcfg f8007000.devcfg: ioremap 0xf8007000 to 8086c000
  [drm] Initialized drm 1.1.0 20060810
  brd: module loaded
  loop: module loaded
  m25p80 spi0.0: found s25fl256s1, expected n25q128a11
  m25p80 spi0.0: s25fl256s1 (32768 Kbytes)
  5 ofpart partitions found on MTD device spi0.0
  Creating 5 MTD partitions on “spi0.0”:
  0x000000000000-0x000000100000 : “qspi-fsbl-uboot”
  0x000000100000-0x000000600000 : “qspi-linux”
  0x000000600000-0x000000620000 : “qspi-device-tree”
  0x000000620000-0x000000c00000 : “qspi-rootfs”
  0x000000c00000-0x000001000000 : “qspi-bitstream”
  CAN device driver interface
  e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
  e1000e: Copyright(c) 1999 - 2014 Intel Corporation.
  libphy: XEMACPS mii bus: probed
  xemacps e000b000.ethernet: pdev-》id -1, baseaddr 0xe000b000, irq 54
  ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
  ehci-pci: EHCI PCI platform driver
  zynq-dr e0002000.usb: Unable to init USB phy, missing?
  usbcore: registered new interface driver usb-storage
  mousedev: PS/2 mouse device common for all mice
  i2c /dev entries driver
  zynq-edac f8006000.memory-controller: ecc not enabled
  Xilinx Zynq CpuIdle Driver started
  sdhci: Secure Digital Host Controller Interface driver
  sdhci: Copyright(c) Pierre Ossman
  sdhci-pltfm: SDHCI platform and OF driver helper
  sdhci-arasan e0100000.sdhci: No vmmc regulator found
  sdhci-arasan e0100000.sdhci: No vqmmc regulator found
  mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
  ledtrig-cpu: registered to indicate activity on CPUs
  usbcore: registered new interface driver usbhid
  usbhid: USB HID core driver
  TCP: cubic registered
  NET: Registered protocol family 17
  can: controller area network core (rev 20120528 abi 9)
  NET: Registered protocol family 29
  can: raw protocol (rev 20120528)
  can: broadcast manager protocol (rev 20120528 t)
  can: netlink gateway (rev 20130117) max_hops=1
  Registering SWP/SWPB emulation handler
  drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
  ALSA device list:
  No soundcards found.
  RAMDISK: ext2 filesystem found at block 0
  RAMDISK: Loading 8192KiB [1 disk] into ram disk.。。 -
  mmc0: new high speed SDHC card at address aaaa
  mmcblk0: mmc0:aaaa SU04G 3.69 GiB
  mmcblk0: p1 p2
  done.
  EXT2-fs (ram0): warning: mounting unchecked fs, running e2fsck is recommended
  VFS: Mounted root (ext2 filesystem) on device 1:0.
  devtmpfs: mounted
  Freeing unused kernel memory: 216K (40626000 - 4065c000)
  Starting rcS.。。
  ++ Mounting filesystem
  ++ Setting up mdev
  ++ Configure static IP 192.168.1.10
  xemacps e000b000.ethernet: eth0: no PHY found
  xemacps e000b000.ethernet: XEMACPS mii bus mii_probe fail.
  ifconfig: SIOCSIFFLAGS: No such device or address
  ++ Starting telnet daemon
  ++ Starting http daemon
  ++ Starting ftp daemon
  ++ Starting dropbear (ssh) daemon
  random: dropbear urandom read with 1 bits of entropy available
  ++ Starting OLED Display
  insmod: can‘t read ’/lib/modules/3.18.0-xilinx/pmodoled-gpio.ko‘: No such file or directory
  ++ Exporting LEDs & SWs
  /etc/init.d/rcS: line 46: can’t create /sys/class/gpio/gpio61/direction: nonexistent directory
  /etc/init.d/rcS: line 46: can‘t create /sys/class/gpio/gpio62/direction: nonexistent directory
  /etc/init.d/rcS: line 46: can’t create /sys/class/gpio/gpio63/direction: nonexistent directory
  /etc/init.d/rcS: line 46: can‘t create /sys/class/gpio/gpio64/direction: nonexistent directory
  /etc/init.d/rcS: line 46: can’t create /sys/class/gpio/gpio65/direction: nonexistent directory
  /etc/init.d/rcS: line 46: can‘t create /sys/class/gpio/gpio66/direction: nonexistent directory
  /etc/init.d/rcS: line 46: can’t create /sys/class/gpio/gpio67/direction: nonexistent directory
  /etc/init.d/rcS: line 46: can‘t create /sys/class/gpio/gpio68/direction: nonexistent directory
  rcS Complete
  zynq》
