系统级芯片(SoC)解决方案ARMADA® 8040主要特性和优势
嵌入式技术
1417人已加入
Marvell公司的ARMADA® 8040 (88F8040)是采用最新的ARMv8 CPU技术的完整的系统级芯片(SoC)解决方案,非常适合用在各种的SoHo, SMB以及企业经典应用.本文介绍了ARMADA® 8040主要特性和优势,框图,以及ARMADA® 8040开发板MACCHIATOBin主要特性和系统指标,框图和电路图.
The Marvell® ARMADA® 8040 (88F8040) is a complete system-on-chip (SoC) solution based on the latest ARMv8 high-performance CPU technology, ideally suited for a wide range of SoHo, SMB and Enterprise class applications. The first two products of the ARMADA® 8K Family, the Armada® 8040 and the Armada® 8020 include, respectively, a quad-core and a dual-core ARM Cortex-A72, bringing a high level of performance, integration, and efficiency, and delivers an optimal Performance-per-Watt in the embedded markets. 88F8040 built as part of Marvell’s MoChi family of products. As the MCi interface is essentially transparent to the driver, all the connected MCi will appear to the driver as though it is an integrated function in the 88F8040 itself, enabling a Virtual System-on-Chip (vSoC). The 88F8040 also supports standard high speed DDR4 interface in 32b bus widths, with optional ECC function.
ARMADA® 8040主要特性和优势:
Marvell
ARMADA® 8040目标应用:
• Control Plane Card - Paired with Marvell’s industry-leading wired networking solutions, the RMADA? 8KFamily is perfectly suited for next generation control plane cards, delivering the right CPU performance andmemory throughput, along with key features such as 64b processing and virtualization.
• Gateway - Paired with Marvell’s industry-leading wireless and wired networking solutions, the ARMADA®8K Family is perfectly suited for Enterprise and Home Gateway applications delivering the right balancebetween performance, power and price, along with key features such as security acceleration andvirtualization.
Marvell
图1.ARMADA® 8040框图
MACCHIATOBin is the Marvell ARMADA 8040 Community Board, a first-of-its-kind Cost-Effective, High Performance and Networking ARMv8 community board.
Marvell
图2.开发板MACCHIATOBin外形图
Marvell
图3.开发板MACCHIATOBin框图
开发板MACCHIATOBin系统指标:
Marvell
Marvell
图4.开发板MACCHIATOBin电路图(1)
Marvell
图5.开发板MACCHIATOBin电路图(2)
Marvell
图6.开发板MACCHIATOBin电路图(3)
Marvell
图7.开发板MACCHIATOBin电路图(4)
Marvell
图8.开发板MACCHIATOBin电路图(5)
Marvell
图9.开发板MACCHIATOBin电路图(6)
Marvell
图10.开发板MACCHIATOBin电路图(7)
