云服务器Flexus X实例,Docker集成搭建Gitea私有仓库
Gitea 私有仓库是一款轻量级的自托管 Git 服务,它提供了与 Github、Gitlab 等类似的功能,但允许用户在自己的服务器上部署和运行,从而完全掌控代码的存储和访问权限
华为云端口
• 服务器放行对应端口 3000,3317
云计算
云计算
云计算
Docker 安装并配置镜像加速
1、购买华为云 Flexus X 实例
Flexus云服务器X实例-华为云 (huaweicloud.com)
2、docker 安装
yum install -y docker-ce
云计算
3、验证 Docker 是否安装成功,启动 docker 服务并设置开机自启动,且查看 docker 状态
docker --versionsystemctl enable dockersystemctl start dockersystemctl status docker
云计算
4、docker-ce 下载
wget -O /etc/yum.repos.d/docker-ce.repo https://mirrors.huaweicloud.com/docker-ce/linux/centos/docker-ce.repo
云计算
5、路径/etc/yum.repos.d 修改配置文件
[docker-ce-stable]name=Docker CE Stable - $basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/$basearch/stableenabled=1gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-stable-debuginfo]name=Docker CE Stable - Debuginfo $basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/debug-$basearch/stableenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-stable-source]name=Docker CE Stable - Sourcesbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/source/stableenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-test]name=Docker CE Test - $basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/$basearch/testenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-test-debuginfo]name=Docker CE Test - Debuginfo $basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/debug-$basearch/testenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-test-source]name=Docker CE Test - Sourcesbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/source/testenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-nightly]name=Docker CE Nightly - $basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/$basearch/nightlyenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-nightly-debuginfo]name=Docker CE Nightly - Debuginfo $basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/debug-$basearch/nightlyenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-nightly-source]name=Docker CE Nightly - Sourcesbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/source/nightlyenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg
云计算
6、清除和构建缓存
yum clean allyum makecache
云计算
7、docker 配置镜像加速(在华为云镜像中心可获取自己的镜像加速配置)
云计算
8、创建镜像加速配置文件
vim /etc/docker/daemon.json
{"registry-mirrors": [ "https://fd0cfec0ac0d446db7fd9d27e92d4a8e.mirror.swr.myhuaweicloud.com" ]}
云计算
9、重新加载配置文件,重新启动 docker,查看是否配置成功
systemctl daemon-reloadsystemctl restart docker.service
云计算
10、docker info 查看配置信息,是否配置成功镜像加速
docker info
云计算
搭建 Gitea 私有仓库
1、docker 拉取 Gitea 镜像
docker pull gitea/gitea
云计算
2、实例化一个 Gitea 容器端口 3000
云计算
3、拉取 mysql 镜像,Gitea 需要数据源,因此使用 mysql
docker pull mysql
云计算
4、实例化一个 mysql 容器端口 3317
docker run -d --name mysql -p 3317:3306 -e MYSQL_ROOT_PASSWORD=1234 mysql
云计算
5、mysql 中创建数据库为 gitea
• 进入 mysql 容器中
docker exec -it mysql bash
• 登录 mysql 数据库
mysql -u root -p
• 创建新数据库 gitea
create database if not exists `gitea`;
云计算
6、浏览器访问公网 IP:3000,如下配置完成
云计算
云计算
总结
828 华为云服务器 Flexus X 实例,Docker 集成搭建 Gitea 私有仓库,搭建自己的代码仓库服务,在自己的服务器上部署和运行,从而完全掌控代码的存储和访问权限,非常便利,如果有小伙伴需要搭建,可以和我一样购买华为云服务器,目前服务器正在大促,优惠非常多!
华为云828 Flexus X实例
