一、linux备份
使用python脚本,要求有python3和mysqldump
#! /usr/bin/python36
# -*- coding: utf-8 -*-
import os
import re
import datetime
import subprocess
## 需要备份数据库的登录信息
mysql_host = {
'test': '10.10.3.207'
db_user = 'root'
db_passwd = 'PASSWD'
db_port = '3306'
## 备份存放的目录地址,没有回自动生成
back_dir = '/backups/mysql'
# 备份文件保存时间,单位:天,超过就删除
backup_keep_time = 30
# 此列表中的数据库将不会备份,下面是默认的基础数据库。
ignore_database = ['Database','information_schema','mysql','sys','performance_schema']
today = datetime.datetime.today().strftime('%Y%m%d%H%M')
for env in mysql_host:
cmd = '/usr/local/mysql/bin/mysql -h {} -u{} -p{} -P{} -e "show databases"'.format(mysql_host.get(env),db_user,db_passwd,db_port)
result = subprocess.check_output(cmd,shell=True,universal_newlines=True).split('
databases = [i for i in result if i and i not in ignore_database]
env_backup_dir = os.path.join(back_dir,env,today)
os.system('mkdir -p {}'.format(env_backup_dir))
for database in databases:
back_path = os.path.join(env_backup_dir,'%s_%s.sql.gz' %(database,today))
command = '/usr/local/mysql/bin/mysqldump -h {} -u{} -p{} -P{} {} --force |gzip > {}'.format(
mysql_host.get(env),db_user,db_passwd,db_port,database,back_path
os.system(command)
tmp = os.path.join(back_dir,env)
for dirname in os.listdir(tmp):
time1 = datetime.datetime.strptime(dirname,'%Y%m%d%H%M')
time_dif = datetime.datetime.today()-time1
times = time_dif.days
if times >= backup_keep_time:
for file in os.listdir(os.path.join(tmp,dirname)):
os.remove(os.path.join(tmp,dirname,file))
os.rmdir(os.path.join(tmp,dirname))
执行命令
python3 vim /usr/bin/mysql_bakup.py
会在/home/mysql下自动生成一个mysql_bak的文件夹,文件夹是以当时时间的文件夹,文件下就是数据库的备份
[root@localhost ~]# ls /backups/mysql/test/ 202211151637 [root@localhost ~]# ls /backups/mysql/test/202211151637/ nacos_202211151637.sql.gz
二、windows服务器备份mysql脚本
@echo off echo 设置MySql数据库的连接信息 set host=192.168.100.101 set port=3306 set user=root set pass=ECIDI@hc99 echo 设置要备份MySql数据库名称 set dbname1=bns_pay set dbname2=bns_qtnys set dbname3=fawkes set dbname4=fawkes_nacos set dbname5=fawkes_patrol set dbname6=qt_applet echo 获取当天的日期格式,例如:20200902231300 set hour=%time:~0,2% if "%time:~0,1%"==" " set hour=0%time:~1,1% set backup_date=%Date:~0,4%%Date:~5,2%%Date:~8,2%%hour%%Time:~3,2%%Time:~6,2% echo 设置备份文件的路径 set backupfile1=D:mysql_bak\%dbname1%-%backup_date%.sql set backupfile2=D:mysql_bak\%dbname2%-%backup_date%.sql set backupfile3=D:mysql_bak\%dbname3%-%backup_date%.sql set backupfile4=D:mysql_bak\%dbname4%-%backup_date%.sql set backupfile5=D:mysql_bak\%dbname5%-%backup_date%.sql set backupfile6=D:mysql_bak\%dbname6%-%backup_date%.sql echo 使用mysqldump对指定的MySql进行备份 echo 注意路径中有空格的要加上双引号 "D:mysql-8.0.30-winx64inmysqldump" -h%host% -P%port% -u%user% -p%pass% -c --add-drop-table %dbname1% > %backupfile1% "D:mysql-8.0.30-winx64inmysqldump" -h%host% -P%port% -u%user% -p%pass% -c --add-drop-table %dbname2% > %backupfile2% "D:mysql-8.0.30-winx64inmysqldump" -h%host% -P%port% -u%user% -p%pass% -c --add-drop-table %dbname3% > %backupfile3% "D:mysql-8.0.30-winx64inmysqldump" -h%host% -P%port% -u%user% -p%pass% -c --add-drop-table %dbname4% > %backupfile4% "D:mysql-8.0.30-winx64inmysqldump" -h%host% -P%port% -u%user% -p%pass% -c --add-drop-table %dbname5% > %backupfile5% "D:mysql-8.0.30-winx64inmysqldump" -h%host% -P%port% -u%user% -p%pass% -c --add-drop-table %dbname6% > %backupfile6% echo 删除过期文件,这里是超过30天就删除 forfiles /p D:mysql_bak /s /m *.sql /d -30 /c "cmd /c del @file /f"
链接:https://www.cnblogs.com/wangyuanguang/p/16893146.html
