HT82V731 pdf datasheet (Audio
消耗积分:5 | 格式:rar | 大小:444 | 2008-08-06
王超
分享资料个
General Description
HT82V731 is a 16-bit digital-to-analog converter IC utilizing
CMOS technology specially designed for stereo
audio application.
HT82V731 converts the 16 bits serial data into an analog
output voltage. The digital data is internally converted
to floating point expression whose format
consists of 10 bits mantissa and 7step exponent.
Using an R-string voltage divider, this floating point expression
data is then converted to analog voltage.
It is compatible with TDA1311. It is available in 8-pin
SOP package.
评论(0)
发评论
下载排行榜
