安华高HCPL-J314替代群芯微驱动光电耦合器QX3150 美林美深
电气特性
输入特性:
正向电压:典型值一般在 1.2V 到 1.4V 左右,在规定的正向电流下,发光二极管的正向压降相对较低,有助于降低输入功耗。
正向电流:通常为 5mA 到 10mA,较小的输入电流即可使光耦正常工作,便于与各种低功耗的控制电路相连接。
Forward voltage: The typical value is generally about 1.2V to 1.4V, and the forward voltage drop of the LED is relatively low at the specified forward current, which helps to reduce the input power consumption.
Forward current: usually 5mA to 10mA, the smaller input current can make the optocoupler work normally, easy to connect with a variety of low-power control circuits.
输出特性:
输出类型:推挽 MOSFET 输出级,这种输出结构能够提供较强的驱动能力和快速的开关速度,可有效驱动大多数中功率 IGBT 和 MOSFET。
输出电流:具有 0.5A 的高输出电流能力,能够满足中功率 IGBT 和 MOSFET 的驱动需求,确保在高负载情况下也能稳定可靠地工作。
Output type: Push-pull MOSFET output stage, this output structure can provide strong drive capability and fast switching speed, can effectively drive most medium power IGBTs and MOSFETs.
Output current: With a high output current capacity of 0.5A, it can meet the drive requirements of medium power IGBT and MOSFET, ensuring stable and reliable operation under high load conditions.
光学特性
发光波长:内部采用镓铝砷化合物(AlGaAs)的发光二极管作为发光源,其发光波长一般在 850nm 左右,该波长的光具有较高的发光效率和较好的光电转换性能,能够有效地实现光信号的传输和耦合。
电流传输比:虽然具体数值未明确给出,但在实际应用中,其电流传输比能够满足高速信号传输和逻辑电平转换的要求,确保输入信号与输出信号之间的有效耦合和准确转换。
Luminous wavelength: the internal use of gallium, aluminum and arsenic compounds (AlGaAs) LED as a light source, its luminous wavelength is generally about 850nm, the wavelength of light has a high luminous efficiency and better photoelectric conversion performance, can effectively achieve the transmission and coupling of optical signals.
Current transmission ratio: Although the specific value is not clearly given, in practical applications, its current transmission ratio can meet the requirements of high-speed signal transmission and logic level conversion, ensuring the effective coupling and accurate conversion between the input signal and the output signal.
传输速度
数据传输速率:具有较高的数据传输速率,能够快速地传输驱动信号,满足电机控制逆变器以及高性能电力系统中对快速切换驱动功率 IGBT 和 MOSFET 的要求,确保系统的高效运行。
Data transmission rate: With a high data transmission rate, it can quickly transmit the drive signal, meet the requirements of the motor control inverter and high-performance power system for fast switching drive power IGBT and MOSFET, and ensure the efficient operation of the system.
共模抑制特性
共模抑制比:典型值较高,一般在 10kV/µs 以上,最小 CMR 也能达到 5kV/µs 左右,具有出色的共模抑制性能,能有效地抑制共模噪声和干扰信号,保证信号在传输过程中的完整性和准确性,使其在恶劣的电磁环境中仍能稳定工作。
Common mode rejection ratio: The typical value is high, generally above 10kV/µs, and the minimum CMR can also reach about 5kV/µs, with excellent common mode rejection performance, which can effectively suppress common mode noise and interference signals, ensure the integrity and accuracy of the signal during transmission, so that it can still work stably in the harsh electromagnetic environment.
工作电压与耐压
工作电压:通常具有较宽的工作电压范围,可适应不同的工作电源需求,其耐压值一般可达 5000Vrms 以上,能够在较高的电压环境下稳定工作,有效地实现输入电路与输出电路之间的电气隔离,保障系统的安全性和可靠性。
Working voltage: usually has a wide range of working voltage, can adapt to different working power needs, its voltage value can generally reach 5000Vrms or more, can work stably in a higher voltage environment, effectively realize the electrical isolation between the input circuit and the output circuit, to ensure the safety and reliability of the system.
工作温度范围
能够在 - 40℃至 + 105℃的宽温度范围内稳定工作,在不同的环境温度下,其电气特性和光学特性的变化较小,具有良好的温度稳定性,可满足各种工业、汽车电子、家电等领域的应用需求,在恶劣的温度条件下仍能保证系统的正常运行。
It can work stably in a wide temperature range of -40 ° C to + 105 ° C, under different ambient temperatures, the change of its electrical and optical characteristics is small, and it has good temperature stability, which can meet the application needs of various industries, automotive electronics, home appliances and other fields, and can still ensure the normal operation of the system under harsh temperature conditions.
封装形式
常见的封装形式为 SOP 封装或 DIP 封装,如 QX3150-CuH-M 中的 “M” 可能表示某种特定的封装形式,这种封装形式具有体积小、引脚间距小、便于安装和焊接等优点,适用于高密度电路板的设计和应用。
The common package form is SOP package or DIP package. For example, the "M" in QX3150-CuH-M may represent a specific package form, which has the advantages of small size, small pin spacing, easy installation and welding, and is suitable for the design and application of high-density circuit boards.
应用领域
电机控制领域:在电机控制系统中,QX3150 可用于驱动 IGBT 或 MOSFET,实现电机的变频调速、正反转控制等功能,其高输出电流和快速的开关速度能够确保电机的高效运行和精确控制。
光伏逆变器领域:在光伏逆变器中,QX3150 可用于驱动功率开关器件,将直流电转换为交流电并并入电网,其高耐压和良好的共模抑制性能能够保证逆变器在复杂的电网环境下稳定可靠地工作。
工业自动化领域:在工业自动化设备中,QX3150 可用于驱动各种功率器件,如继电器、接触器、电磁阀等,实现对工业设备的控制和自动化操作,其宽温度范围和高可靠性能够满足工业现场的恶劣环境要求。
汽车电子领域:群芯微拥有 AEC-Q101 车规认证,其 QX3150 产品可用于汽车的电子控制系统,如电动汽车的电机驱动系统、车载充电器、DC-DC 转换器等,满足汽车电子对可靠性、稳定性和安全性的严格要求。
Motor control field: In the motor control system, QX3150 can be used to drive IGBT or MOSFET, to achieve the motor frequency control, positive and negative rotation control and other functions, its high output current and fast switching speed can ensure the efficient operation and accurate control of the motor.
Photovoltaic inverter field: In photovoltaic inverters, QX3150 can be used to drive power switching devices, convert direct current into alternating current and into the power grid, and its high voltage resistance and good common mode rejection performance can ensure that the inverter works stably and reliably in a complex power grid environment.
Industrial automation field: In industrial automation equipment, QX3150 can be used to drive various power devices, such as relays, contactors, solenoid valves, etc., to achieve the control and automatic operation of industrial equipment, its wide temperature range and high reliability can meet the harsh environmental requirements of industrial sites.
Automotive electronics: With AEC-Q101 certification, QX3150 products can be used in automotive electronic control systems, such as electric vehicle motor drive systems, on-board chargers, DC-DC converters, etc., to meet the strict requirements of automotive electronics for reliability, stability and safety.
