工业用射频连接器为工业高速发展注入强劲动力
近年来,在科技浪潮的推动下,5G 通信、工业自动化、智能制造等领域快速发展,工业用射频连接器市场迎来了需求的强劲增长期。针对工业领域不断迈向高端化、智能化的多元要求,中航光电推出了多系列工业用射频连接器,以卓越性能和可靠品质为工业前沿领域的高速发展注入强劲动力。
In recent years, propelled by the wave of science and technology, the fields of 5G communication, industrial automation, and intelligent manufacturing have witnessed rapid development, and the industrial RF connector market has entered a phase of robust demand growth. In view of the diversified requirements of high - end and intelligent development in the industrial field, JONHON has launched a series of industrial RF connectors, which have injected strong impetus into the rapid development of industrial frontier fields with excellent performance and reliable quality.
1
共轴混装连接器
Coaxial mixed connector
为解决煤炭、石油测井等领域中照明电源、数据传输和高清 SDI 射频信号集成连接器存在的对插操作不便及键位对正视觉受限问题,中航光电推出了能够集成多路电源和高频信号的共轴混装RF106系列连接器。
To solve the problems of inconvenient insertion operation and limited vision of key alignment in the integrated connectors of lighting power supply, data transmission and high-definition SDI radio frequency signals in the fields of coal and petroleum logging, JONHON has introduced coaxial mixed RF106 series connectors which can integrate multi-channel power supply and high-frequency signals.
产品亮点 Highlights
1. 产品可实现多通道、多种信号的360°快速盲插; The product can realize multi-channel and multi-signal 360° fast blind mating; 2. 满足175℃的高温使用要求; Meets the requirements of high temperature use at 175℃; 3. 传输电流、通道数、使用频率和安装尺寸均可定制化开发; The transmission current, number of channels, operating frequency, and installation dimensions can all be customized;
2
测试测量类射频连接器
Test and measurement RF connector
随着PCB板使用频率越来越高,其性能测试标准的精度与复杂度呈指数级攀升,为此中航光电推出了SMA、2.92mm、2.40mm、1.85mm等多种标准系列射频连接器可供客户选择。同时,中航光电依托深厚的技术沉淀与研发实力,能够针对不同客户的复杂需求,开展系统性的射频性能仿真分析,并以此为基础进行定制化开发,精准满足多样化的应用场景。
With the increasing use frequency of PCB, the accuracy and complexity of its performance test standard increase exponentially. Therefore, JONHON has introduced a variety of standard series RF connectors such as SMA, 2.92mm, 2.40mm and 1.85mm for customers to choose from. At the same time, relying on profound technical precipitation and innovative strength, JONHON can carry out systematic RF performance simulation analysis according to the complex needs of different customers, and carry out customized development on this basis to accurately meet diverse application scenarios.
产品亮点 Highlights
1. 产品频率可高达67GHz;
Product frequency reaches 67GHz;
2. 采用免焊连接方式与 PCB 板稳固适配;
Adopts a solder-free mode to connect with PCB;
3
小型化高密度卡口连接器
Miniaturized and high-density bayonet connector
中航光电精准洞察广播、娱乐、安防等领域的发展趋势,为契合产品小型化与高清传输的迫切需求,推出了HD-BNC射频连接器。 JONHON has a precise insight into the development trends in the fields of broadcasting, entertainment, security and so on. In order to meet the urgent needs of product miniaturization and high-definition transmission, HD-BNC RF connectors have been introduced.
产品亮点 Highlights
1. 产品相较于传统BNC体积大幅缩减 51%,较Mini-BNC也缩小了30%;
Compared with traditional BNC, the volume of the product is greatly reduced by 51%, and it is also reduced by 30% compared with Mini-BNC;
2. 75 Ω的稳定阻抗配合12Gbps高传输速率;
75 Ω stable impedance combines with 12Gbps high transmission rate;
3. 采用卡扣式机械连接机构;
Adopts a snap-in mechanical connection mechanism;
4. 广泛应用于数字视频、超高清和 4K 电视、广播以及仪表测试等多个领域;
Widely used in digital video, ultra-high definition and 4K TV, broadcasting, instrument testing and other fields;
未来,中航光电将持续深耕技术创新,紧跟行业发展趋势,不断优化产品性能与品质,进一步拓展工业用射频连接器的应用范围,以更加丰富多元的产品与解决方案,深度赋能各领域发展。 In the future, JONHON will continue to delve into technological innovation, keep pace with industry development trends, continuously optimize product performance and quality, further expand the application scope of industrial RF connectors, and deeply empower the development of various fields with more diverse products and solutions. JONHON
