使用DRBD和keepalived实现文件实时同步和双机热备
DRBD + keepalived实现文件实时同步和双机热备
安装DRBD
系统初始化设置
注意: 需要有数据盘或者多的分区
  yum update -y
关闭防火墙
  systemctl stop firewalld
  systemctl disable firewalld
修改host文件
  vim /etc/hosts
  192.168.1.240 Primary kylin-01
  192.168.1.241 Secondary kylin-02
关闭SELINUX
  vim /etc/sysconfig/selinux
  SELINUX=disabled
安装依赖
  yum install gcc libxslt-devel libxslt perl keyutils-libs-devel net-tools -y
下载源码编译安装
drbd需要两个安装报:drbd drbd-utils
drbd 安装
  wget https://pkg.linbit.com//downloads/drbd/9/drbd-9.2.8.tar.gz
  tar -zxvf drbd-9.2.8.tar.gz
  cd drbd-9.2.8
  make && make install
drbd-utils 安装
  wget https://pkg.linbit.com//downloads/drbd/utils/drbd-utils-9.27.0.tar.gz
  tar -zxvf drbd-utils-9.27.0.tar.gz
  cd drbd-utils-9.27.0
  ./configure --prefix=/usr/local/drbd --without-83support --with-udev --with-initscripttype=systemd --without-manual
安装配置路径:/usr/local/drbd/etc/drbd.d 安装路径: /usr/sbin/drbdsetup /usr/sbin/drbdmeta /usr/sbin/drbdadm
配置drbd
磁盘分区 此处不要格式化磁盘 fdisk /dev/sdb
全局配置
global_common.conf内容如下:
  # DRBD is the result of over a decade of development by LINBIT.
  # In case you need professional services for DRBD or have
  # feature requests visit http://www.linbit.com
  global {
  usage-count yes;
  # Decide what kind of udev symlinks you want for "implicit" volumes
  # (those without explicit volume {} block, implied vnr=0):
  # /dev/drbd/by-resource// (explicit volumes)
  # /dev/drbd/by-resource/ (default for implict)
  udev-always-use-vnr; # treat implicit the same as explicit volumes
  # minor-count dialog-refresh disable-ip-verification
  # cmd-timeout-short 5; cmd-timeout-medium 121; cmd-timeout-long 600;
  common {
  handlers {
  # These are EXAMPLE handlers only.
  # They may have severe implications,
  # like hard resetting the node under certain circumstances.
  # Be careful when choosing your poison.
  # IMPORTANT: most of the following scripts symlink to "notify.sh" which tries to send mail via "mail".
  # If you intend to use this notify.sh script make sure that "mail" is installed.
  pri-on-incon-degr "/usr/lib/drbd/notify-pri-on-incon-degr.sh; /usr/lib/drbd/notify-emergency-reboot.sh; echo b > /proc/sysrq-trigger ; reboot -f";
  pri-lost-after-sb "/usr/lib/drbd/notify-pri-lost-after-sb.sh; /usr/lib/drbd/notify-emergency-reboot.sh; echo b > /proc/sysrq-trigger ; reboot -f";
  local-io-error "/usr/lib/drbd/notify-io-error.sh; /usr/lib/drbd/notify-emergency-shutdown.sh; echo o > /proc/sysrq-trigger ; halt -f";
  # fence-peer "/usr/lib/drbd/crm-fence-peer.sh";
  # split-brain "/usr/lib/drbd/notify-split-brain.sh root";
  # out-of-sync "/usr/lib/drbd/notify-out-of-sync.sh root";
  # before-resync-target "/usr/lib/drbd/snapshot-resync-target-lvm.sh -p 15 -- -c 16k";
  # after-resync-target /usr/lib/drbd/unsnapshot-resync-target-lvm.sh;
  # quorum-lost "/usr/lib/drbd/notify-quorum-lost.sh root";
  # disconnected /bin/true;
  startup {
  # wfc-timeout degr-wfc-timeout outdated-wfc-timeout wait-after-sb
  options {
  # cpu-mask on-no-data-accessible
  # RECOMMENDED for three or more storage nodes with DRBD 9:
  # quorum majority;
  # on-no-quorum suspend-io | io-error;
  disk {
  on-io-error detach; #配置I/O错误处理策略为分离
  # size on-io-error fencing disk-barrier disk-flushes
  # disk-drain md-flushes resync-rate resync-after al-extents
  # c-plan-ahead c-delay-target c-fill-target c-max-rate
  # c-min-rate disk-timeout
  net {
  # protocol timeout max-epoch-size max-buffers
  # connect-int ping-int sndbuf-size rcvbuf-size ko-count
  # allow-two-primaries cram-hmac-alg shared-secret after-sb-0pri
  # after-sb-1pri after-sb-2pri always-asbp rr-conflict
  # ping-timeout data-integrity-alg tcp-cork on-congestion
  # congestion-fill congestion-extents csums-alg verify-alg
  # use-rle
资源配置
在node1、node2 上分别建立drbd.res: drbd.d目录下新建资源文件(drbd.res) vim /usr/local/drbd/etc/drbd.d/drbd.res
  resource r1 { #这个r1是定义资源的名字
  protocol C;
  on kylin-01 { #on开头,后面是主机名称
  device /dev/drbd0; #drbd设备名称
  disk /dev/sdb1; #drbd0使用的磁盘分区为sdb1
  address 192.168.1.240:7789; #设置drbd监听地址与端口
  meta-disk internal;
  on kylin-02 { #on开头,后面是主机名称
  address 192.168.1.241:7789; #设置drbd监听地址与端口
  meta-disk internal;
在node1、node2 上初始化资源、启动drbd:
  [root@kylin-01 drbd.d]# drbdadm create-md r1
  initializing activity log
  initializing bitmap (640 KB) to all zero
  Writing meta data...
  New drbd meta data block successfully created.
  #启动 两个节点需要同时启动才生效
  [root@kylin-01 drbd.d]# systemctl start drbd
  # 开机启动
  [root@kylin-01 drbd.d]# systemctl enable drbd
  # 查看状态
  [root@kylin-01 drbd.d]# systemctl status drbd
  # 查看状态
  netstat -anput|grep 7789
  tcp 0 0 192.168.1.240:33015 192.168.1.241:7789 ESTABLISHED -
  tcp 0 0 192.168.1.240:40897 192.168.1.241:7789 ESTABLISHED -
检查资源状态:
  #查看节点角色状态:
  drbdadm role r1
  注:第一次启动drbd时,两个drbd节点默认都处于Secondary状态
主节点执行设置主节点:
  #初始化资源
  drbdadm primary --force r1
  #查看资源状态
  drbdadm status r1
  r1 role:Primary
  disk:UpToDate
  kylin-02 role:Secondary
  replication:SyncSource peer-disk:Inconsistent done:6.16
  #查看同步状态
  cat /proc/drbd
  version: 9.2.8 (api:2/proto:86-122)
  GIT-hash: e163b05a76254c0f51f999970e861d72bb16409a build by root@kylin-01, 2024-04-08 1556
  Transports (api tcp (9.2.8)
  会把主机上的数据传到备机,开始会显示同步进度,过一会显示状态都是”实时”,表示数据同步完成了。接下来就可以使用DRBD了。
DRBD使用(测试)
你现在可以把主机上的DRBD设备挂载到一个目录上进行使用,备机的DRBD设备无法被挂载,因为它是用来接收主机数据的,由DRBD负责操作.
格式化文件系统(文件格式根据自己的系统环境选择)
  mkfs.ext4 /dev/drbd0
挂载此文件系统
  mkdir /data
  mount /dev/drbd0 /data/
在挂载data目录中创建一个测试文件,然后卸载挂载目录,然后切换主备节点,在备用节点上查看刚刚建立的测试文件还是否存在
node1:
  [root@node1 ~]# mkdir /data/test
  将node1变为备用节点
  [root@node1 ~]# umount /data/
  [root@node1 ~]# drbdadm secondary r1
  [root@node1 ~]# drbdadm role r1
  Secondary
node2:
  将node2变为主节点
  [root@node2 ~]# drbdadm primary r1
  [root@node2 ~]# drbdadm role r1
  Primary/Secondary
  挂载设备,然后看文件是否存在
  [root@node2 ~]# mount /dev/drbd0 /data
  [root@node2 ~]# cd /data/
  [root@node2 mnt]# ls
  test
  OK! 到这里已经算是完成了!
同样,在Node2上建立文件,然后
卸载/mnt/:umount /mnt/
将Node2降级成备用节点:drbdadm secondary r1
在Node1上升级为主机节点:drbdadm primary r1
在Node1上挂载:mount /dev/drbd0 /data
会发现Node2上的文件也同步到了Node1上。
问题
1、umount时,如果提示device is busy,使用下面方法解决: fuser -m /data 显示:/data: 25023c 然后kill -9 25023 即可
2、"Split-Brain"(脑裂)的情况:
假设把Primary主机的的eth0设备宕掉,然后直接在Secondary主机上进行提权升级为DRBD的主节点,并且mount挂载DRBD,这时会发现之前在Primary主机上写入的数据文件确实同步过来了。 接着再把Primary主机的eth0设备恢复,看看有没有自动恢复 主从关系。经过查看,发现DRBD检测出了Split-Brain的状况,也就是两个节点都处于standalone状态, 故障描述如下:Split-Brain detected,dropping connection! 这就是传说中的“脑裂”。
DRBD官方推荐的手动恢复方案:
Secondary主机上的操作
  drbdadm secondary r0
  drbdadm disconnect all
  drbdadm --discard-my-data connect r0 //或者"drbdadm -- --discard-my-data connect r0"
Primary主机上的操作
  drbdadm connect r0
  drbdsetup /dev/drbd0 primary
检查drdb状态
  [root@kylin-01 ~]# drbdadm status r1
  r1 role:Primary
  disk:UpToDate
  peer-disk:UpToDate
安装keepalived
直接采用yum安装
  yum install -y keepalived
查看keepalived版本
  [root@kylin-02 keepalived]# keepalived -v
  Keepalived v2.0.20 (01/22,2020)
  Copyright(C) 2001-2020 Alexandre Cassen,
  Built with kernel headers for Linux 4.19.90
  Running on Linux 4.19.90-52.25.v2207.ky10.x86_64 #1 SMP Fri Jun 2 1228 CST 2023
更改keepalived配置
注:本处采用pgsql测试两个机器数据同步
pg docker-compose的文件(docker的配置安装请自行百度)
  version: "3"
  services:
  postgresql:
  image: postgres:11.8
  container_name: postgres
  hostname: postgres
  ports:
  - "5432:5432"
  volumes:
  - "/data/pgsql:/var/lib/postgresql/data"
  - "/etc/localtime:/etc/localtime"
  restart: on-failure
  logging:
  driver: "json-file"
  options:
  tag: postgres
  cap_add:
  - ALL
  environment:
  POSTGRES_USER: "root"
  POSTGRES_PASSWORD: "123456"
  ALLOW_IP_RANGE: "0.0.0.0/0"
  cd /etc/keepalived
  vim keepalived.conf
主节点keepalived.conf 文件内容如下:
注意:再执行stop脚本时不能直接执行,需要采用脚本调用脚本的方式执行,否则执行不完就会被kill掉(原因暂时没弄清楚)
  ! Configuration File for keepalived
  global_defs {
  #notification_email {
  # acassen@firewall.loc
  # failover@firewall.loc
  # sysadmin@firewall.loc
  #notification_email_from Alexandre.Cassen@firewall.loc
  #smtp_server 192.168.200.1
  #smtp_connect_timeout 30
  router_id kylin-02 # 节点标识,主机名
  vrrp_skip_check_adv_addr
  vrrp_strict
  vrrp_garp_interval 0
  vrrp_gna_interval 0
  vrrp_instance VI_1 {
  state BACKUP
  interface ens32 # 网卡
  virtual_router_id 51
  priority 100 # 节点权重,主节点100 备节点小于100,数字越大优先级越高
  mcast_src_ip 192.168.1.240 # 本机IP
  advert_int 1
  authentication {
  auth_type PASS
  auth_pass 1111
  virtual_ipaddress {
  192.168.1.239 # 绑定的虚拟IP
  notify_master "/etc/keepalived/notify.sh" # 节点为master时执行脚本
  notify_backup "/etc/keepalived/notify_back.sh" # 切换为备节点时执行脚本
  notify_stop "/etc/keepalived/notify_back.sh" # stop keepalived时执行的脚本
备节点keepalived.conf 文件内容如下:
  global_defs {
  vrrp_strict
  vrrp_gna_interval 0
  state BACKUP
  interface ens32
  priority 99 # 节点权重,主节点100 备节点小于100,数字越大优先级越高
  mcast_src_ip 192.168.1.241 # 本机IP
  advert_int 1
  authentication {
  auth_type PASS
  auth_pass 1111
  virtual_ipaddress {
  192.168.1.239
notify.sh
  #!/bin/bash
  drbdadm primary r1
  while true
  do
  drdbs=$(drbdadm role r1)
  echo "drbd status is $drdbs"
  if [[ "$drdbs" == "Primary" ]];then
  break
  else
  drbdadm primary r1
  sleep 3
  fi
  done
  docker-compose -f /opt/pgsql/docker-compose.yml up -d
stop.sh
  #!/bin/bash
  docker stop postgres
  umount /data/
  while true
  do
  if [[ "$drdbs"=="Secondary" ]];then
  break
  else
  sleep 3
  fi
  done
notify_back.sh
  #!/bin/bash
  /etc/keepalived/stop.sh
启动keepalived
  systemctl start keepalived
开机启动
  systemctl enable keepalived
验证
在数据库里面执行创建删除,切换keepalived节点后查看数据是否同步
链接:https://www.cnblogs.com/pgyLang/p/18124303
