PIC12C508读写93LC46范例程式
控制/MCU
1931人已加入
  * Processer : MICroChip PIC12C508 *
  * Compiler : Hi-TECH PICC 8.00 PL2 *
  * Writer : Jason Kuo *
  * Description : It CAN read/write 93LC46 (64 x 16-bit organization) *
  static volatile unsigned char RTCC @ 0x01;
  static volatile unsigned char TMR0 @ 0x01;
  static volatile unsigned char PCL @ 0x02;
  static volatile unsigned char STATUS @ 0x03;
  static unsigned char FSR @ 0x04;
  static volatile unsigned char OSCCAL @ 0x05;
  static volatile unsigned char GPIO @ 0x06;
  static unsigned char control OPTION @ 0x00;
  static volatile unsigned char control TRIS @ 0x06;
  /* STATUS bits */
  static bit GPWUF @ (unsigned)&STATUS*8+7;
  static bit PA0 @ (unsigned)&STATUS*8+5;
  static bit TO @ (unsigned)&STATUS*8+4;
  static bit PD @ (unsigned)&STATUS*8+3;
  static bit ZERO @ (unsigned)&STATUS*8+2;
  static bit DC @ (unsigned)&STATUS*8+1;
  static bit CARRY @ (unsigned)&STATUS*8+0;
  /* OPTION bits */
  #define GPWU (1《《7)
  #define GPPU (1《《6)
  #define T0CS (1《《5)
  #define T0SE (1《《4)
  #define PSA (1《《3)
  #define PS2 (1《《2)
  #define PS1 (1《《1)
  #define PS0 (1《《0)
  /* OSCCAL bits */
  static volatile bit CAL3 @ (unsigned)&OSCCAL*8+7;
  static volatile bit CAL2 @ (unsigned)&OSCCAL*8+6;
  static volatile bit CAL1 @ (unsigned)&OSCCAL*8+5;
  static volatile bit CAL0 @ (unsigned)&OSCCAL*8+4;
  static volatile bit GP5 @ (unsigned)&GPIO*8+5;
  static volatile bit GP4 @ (unsigned)&GPIO*8+4;
  static volatile bit GP3 @ (unsigned)&GPIO*8+3;
  static volatile bit GP2 @ (unsigned)&GPIO*8+2;
  static volatile bit GP1 @ (unsigned)&GPIO*8+1;
  static volatile bit GP0 @ (unsigned)&GPIO*8+0;
  #define CONFIG_ADDR 0xFFF
  /* code protection */
  #define MCLREN 0xFFFF // memory clear enable
  #define MCLRDIS 0xFFEF // memory clear dISAble
  /*watchdog*/
  #define WDTEN 0xFFFF // watchdog timer enable
  #define WDTDIS 0xFFFB // watchdog timer disable
  #define PROTECT 0xFFF7 // protect the program code
  #define UNPROTECT 0xFFFF // do not protect the program code
  /*osc configurations*/
  #define EXTRC 0xFFFF // external resistor/caPACitor
  #define INTRC 0xFFFE // internal
  #define XT 0xFFFD // crystal/resonator
  #define LP 0xFFFC // low power crystal/resonator
  /* 93LC46 I/O PIN define */
  #define CS GP0 //Chip Select
  #define CLK GP1 //Serial Data CLOCk
  #define DI GP2 //Serial Data Input
  #define DO GP4 //Serial Data Output
  void Delay(unsigned int counter);
  void Pulse(void);
  void StartBit(void);
  void EWEN(void);
  void EWDS(void);
  extern void Write93LC46(unsigned char Offset_Addr, unsigned int tx_data);
  extern unsigned int Read93LC46(unsigned char Offset_Addr);
  void InitPIC(void);
  #define CLRWDT() asm(“ clrwdt”)
  #define SLEEP() asm(“ sleep”)
  #define ___mkstr1(x) #x
  #define ___mkstr(x) ___mkstr1(x)
  #define __CONFIG(x) asm(“tpsect config,class=CONFIG,delta=2”);
  asm(“tglobaltconfig_word”);
  asm(“config_word”);
  asm(“tdw ”___mkstr(x))
  #define __IDLOC(w) asm(“tpsect idloc,class=IDLOC,delta=2”);
  asm(“tglobaltidloc_word”);
  asm(“idloc_word”);
  asm(“tirpct__arg,” ___mkstr(w));
  asm(“tdw 0&__arg&h”);
  asm(“tendm”)
  __CONFIG(MCLRDIS & WDTDIS & EXTRC & PROTECT);
  Function : Delay
  Input : unsigned int (counter)
  Output : None
  Description : Delay routine
  if counter=1 delay 35us , if counter=10 delay 134us,
  if counter=100 delay 1.12ms,
  These delay is base on internal 4MHz
  while(counter》0) counter--;
  Function : Pulse
  Input : None
  Output : None
  Description : Send a pulse (10) to Serial Data Clock(CLK)
  void Pulse(void)
  CLK = 1;
  Delay(25);
  CLK = 0;
