ADSP-SC57xSHARC双核处理器解决方案(特性,框图,电路图)
处理器/DSP
899人已加入
ADI公司的ADSP-SC57x/2157x系列处理器集成了两个增强型SHARC+®内核和先进的DSP加速器(FIR,IIR),功耗低于2W,功效比以前的SHARC产品高5倍以上,专为需要DSP协处理器并包括两个SHARC+内核和一个匹配DSP内核的外设集的应用而设计,主要用在汽车,消费电子和专业音频,多轴电机控制和能源分配系统.本文介绍了ADSP-SC57x/ADSP-2157x系统特性,处理器框图,ARM Cortex-A5处理器器框图,SHARC处理器框图,SHARC+SIMD处理器核框图以及评估板ADSP-SC573 EZ-KIT主要特性,框图,电路图和材料清单.
The ADSP-SC57x/ADSP-2157x processors are members of theSHARC® family of products. The ADSP-SC57x processor isbased on the SHARC+® dual-core and the ARM® Cortex®-A5core. The ADSP-SC57x/ADSP-2157x SHARC processors aremembers of the single-instruction, multiple data (SIMD)SHARC family of digital signal processors (DSPs) that featureAnalog Devices Super Harvard Architecture. These 32-bit/40-bit/64-bit floating-point processors are optimized for high performanceaudio/floating-point applications with large on-chipstatic random-access memory (SRAM), multiple internal busesthat eliminate input/output (I/O) bottlenecks, and innovativedigital audio interfaces (DAI). New additions to the SHARC+core include cache enhancements and branch prediction, whilemaintaining instruction set compatibility to previous SHARC products.
By integrating a set of industry leading system peripherals andmemory, the ARM Cortex-A5 and SHARC processor is the platform of choice for applicationsthat require programmability similar to reducedinstruction set computing (RISC), multimedia support, andleading edge signal processing in one integrated package. Theseapplications span a wide array of markets, including automotive,professional audio, and industrial-based applications thatrequire high floating-point performance.
ADSP-SC57x/ADSP-2157x系统特性:
Dual-enhanced SHARC+ high performance floating-pointcores
Up to 450 MHz per SHARC+ core
Up to 3 Mb (384 kB) L1 SRAM memory per core with parity(optional ability to configure as cache)
32-bit, 40-bit, and 64-bit floating-point support32-bit fixed point
Byte, short word, word, long word addressed
ARM Cortex-A5 core
450 MHz/720 DMIPS with NEON/VFPv4-D16/Jazelle
32 kB L1 instruction cache with parity/32 kB L1 data cachewith parity
256 kB L2 cache with parity
Powerful DMA system
On-chip memory protection
双核处理器
图1.ADSP-SC57x/ADSP-2157x处理器框图
双核处理器
图2.ADSP-SC57x/ADSP-2157xARM Cortex-A5处理器器框图
双核处理器
图3.SHARC处理器框图
双核处理器
图4.SHARC+SIMD处理器核框图
Thank you for purchasing the Analog Devices, Inc. ADSP-SC573 EZ-KITevaluation system.
The ADSP-SC573 processor is a members of the SHARC® family of products. The ADSP-SC573 processor isbased on the SHARC+ dual-core and the ARM® Cortex-A5TM core. The ADSP-SC573SHARC processor is amembers of the SIMD SHARC family of DSPs that feature Analog Devices Super Harvard Architecture. These 32-bit/40- bit/64-bit floating-point processors are optimized for high performance audio/floating-point applicationswith their large onchip SRAM, multiple internal buses to eliminate I/O bottlenecks, and innovative digital audiointerfaces (DAI). New enhancements to the SHARC+ core add cache enhancements, branch prediction, and otherinstruction set improvements—all while maintaining instruction set compatibility to previous SHARC products.
The EZ-KIT ships with all of the necessary hardware to get you up and running and start the evaluation immediately.
The EZ-KIT contains an expansion interface 3 (EI3). This interface provides for connecting with daughter boardsto expand on the functionality of the EZ-KIT.
The evaluation board is designed to be used in conjunction with the CrossCore Embedded Studio® developmentenvironment for advanced application code development and debug such as:
• Create, compile, assemble, and link application programs written in C++, C, and assembly
• Load, run, step, halt, and set breakpoints in application programs
• Read and write data and program memory
• Read and write core and peripheral registers
图4.评估板ADSP-SC573 EZ-KIT外形图
评估板ADSP-SC573 EZ-KIT主要特性:
• Analog Devices ADSP-SC573 processor
• 400 ball BGA
• 25 MHz oscillator
• DDR3 Memory
• 128Mx16 bit (2Gbit )
• Micron MT41J128M16JT-125
• 1.5V
• SPI Flash (SPI2) Memory
• 128Mbit
• Windbond32M-bit Serial Flash Memory with Dual and Quad SPI (W25Q32)
• Single/Dual/Quad SPI
• SPI EEPROM
• Microchip 4K I2C Serial EEPROM (24AA04)
• Ethernet
• Texas Instruments 10/100/1000 Ethernet Physical Layer (DP83865)
• Broadcom BroadR-Reach® Single Port Automotive Ethernet Transceiver (BCM89810)
• Cirrus Logic Fractional-N Clock Multiplier (CS2100)
• Two RJ45 connectors
• Audio
• Analog Devices 12 Channel, High Performance, 192kHz, 24-Bit DAC (ADAU1962A)
• Analog Devices Quad ADC with Diagnostics (ADAU1977)
• Analog Devices Quad Analog-to-Digital Converter (ADAU1979)
• 12 RCA connectors. 12 outputs or 8 outputs/4 inputs
• Universal Asynchronous Receiver/Transmitter (UART3)
• FTDI USB to UART (FT232R)
• USB micro-B
• CAN
• NXP Enhanced fault-tolerant CAN transceiver (TJA1055)
• NXP High-speed CAN transceiver for partial networking (TJA1145)
• Two RJ11connectors
• A2B
• Analog Devices Automotive Audio Bus A2B Transceiver (AD2410)
• Two DuraClik connectors
• Debug Interface (JTAG and Trace)
• ICE-1000 emulator
• JTAG 10-pin 0.05” header
• JTAG and Trace 38-pin Mictor connector
• LEDs
• Eleven LEDs: one power (green), one board reset (red), eight general-purpose (amber) and one fault (red)
• Pushbuttons
• Four pushbuttons: one reset and three IRQ/Flag
• EI3 connector
• SMC
• EPPI
• SPORT
• SPI
• UART
• TWI
• TMR
• GPIO
• RESET
• GND/3.3V/5V output
• External power supply
• CE compliant
• 12V @1.5 Amps
• Power measurement
• 0.051-ohm resistors for measuring current draw
Your ADSP-SC573 EZ-KIT package contains the following items.
• ADSP-SC573 EZ-KIT board
• Universal 12V DC power supply
• USB 2.0 type A to micro-B cable
• USB A receptacle to micro A plug
• Ethernet Cable
• SD Memory Card
• ICE-1000 emulator
双核处理器
图5.评估板ADSP-SC573 EZ-KIT硬件建立图
双核处理器
图6.评估板ADSP-SC573 EZ-KIT框图
双核处理器
图7.评估板ADSP-SC573 EZ-KIT电路图(1)
双核处理器
图8.评估板ADSP-SC573 EZ-KIT电路图(2)
双核处理器
图9.评估板ADSP-SC573 EZ-KIT电路图(3)
双核处理器
图10.评估板ADSP-SC573 EZ-KIT电路图(4)
双核处理器
图11.评估板ADSP-SC573 EZ-KIT电路图(5)
双核处理器
图12.评估板ADSP-SC573 EZ-KIT电路图(6)
双核处理器
图13.评估板ADSP-SC573 EZ-KIT电路图(7)
双核处理器
图14.评估板ADSP-SC573 EZ-KIT电路图(8)
双核处理器
图15.评估板ADSP-SC573 EZ-KIT电路图(9)
双核处理器
图16.评估板ADSP-SC573 EZ-KIT电路图(10)
双核处理器
图17.评估板ADSP-SC573 EZ-KIT电路图(11)
双核处理器
图18.评估板ADSP-SC573 EZ-KIT电路图(12)
双核处理器
图19.评估板ADSP-SC573 EZ-KIT电路图(13)
双核处理器
图20.评估板ADSP-SC573 EZ-KIT电路图(14)
双核处理器
图21.评估板ADSP-SC573 EZ-KIT电路图(15)
双核处理器
图22.评估板ADSP-SC573 EZ-KIT电路图(16)
双核处理器
图23.评估板ADSP-SC573 EZ-KIT电路图(17)
双核处理器
图24.评估板ADSP-SC573 EZ-KIT电路图(18)
双核处理器
图25.评估板ADSP-SC573 EZ-KIT电路图(19)
双核处理器
图26.评估板ADSP-SC573 EZ-KIT电路图(20)
双核处理器
图27.评估板ADSP-SC573 EZ-KIT电路图(21)
双核处理器
图28.评估板ADSP-SC573 EZ-KIT电路图(22)
双核处理器
图29.评估板ADSP-SC573 EZ-KIT电路图(23)
双核处理器
图30.评估板ADSP-SC573 EZ-KIT电路图(24)
双核处理器
图31.评估板ADSP-SC573 EZ-KIT电路图(25)
双核处理器
图32.评估板ADSP-SC573 EZ-KIT电路图(26)
评估板ADSP-SC573 EZ-KIT材料清单:
双核处理器
双核处理器
双核处理器
双核处理器
双核处理器
双核处理器
双核处理器
双核处理器
双核处理器
双核处理器
双核处理器
双核处理器
