本实验将演示如何在小凌派-RK2206开发板上使用IOT库的UART接口,进行UART编程开发。
例程将创建一个任务,通过配置UART引脚,实现UART读写操作。
例程源代码:https://gitee.com/Lockzhiner-Electronics/lockzhiner-rk2206-openharmony3.0lts/tree/master/vendor/lockzhiner/rk2206/samples/b20_iot_uart
UART在日常设备中非常常见,以下我们将演示IOT库的UART接口如何进行UART口配置,以及UART口读写操作。
base/iot_hardware/peripheral/interfaces/kits/iot_uart.h
unsignedintIoTUartInit(unsignedintid, constIotUartAttribute*param);
描述:
UART设备初始化。
参数:
| 参数 | 类型 | 描述 |
| id | unsigned int | UART ID |
| param | const IotUartAttribute * | UART配置参数 |
UART ID配置和IO复用如下表:
| 串口 | id | TX | RX |
| UART0 | EUART0_M0 | GPIO0_PB7 | GPIO0_PB6 |
| UART0 | EUART0_M1 | GPIO0_PC7 | GPIO0_PC6 |
| UART1 | EUART1_M0 | GPIO0_PC3 | GPIO0_PC2 |
| UART1 | EUART1_M1 | GPIO0_PA7 | GPIO0_PA6 |
| UART2 | EUART2_M1 | GPIO0_PB3 | GPIO0_PB2 |
返回值:
| 返回值 | 描述 |
| IOT_SUCCESS | 成功 |
| IOT_FAILURE | 失败 |
实现:
hal_iot_uart.c文件在device/rockchip/rk2206/adapter/hals/iot_hardware/wifiiot_lite目录下。
unsignedintret=0;
UartAttribute*temp_prt= (constUartAttribute*)param;
if (id>=EUARTDEV_MAX)
PRINT_ERR("id(%d) >= EUARTDEV_MAX(%d)\n", id, EUARTDEV_MAX);
returnIOT_FAILURE;
PinctrlSet(m_uart_bus_info[id].uart_bus.rx.gpio, m_uart_bus_info[id].uart_bus.rx.func, m_uart_bus_info[id].uart_bus.rx.type, m_uart_bus_info[id].uart_bus.rx.drv);
PinctrlSet(m_uart_bus_info[id].uart_bus.tx.gpio, m_uart_bus_info[id].uart_bus.tx.func, m_uart_bus_info[id].uart_bus.tx.type, m_uart_bus_info[id].uart_bus.tx.drv);
if (param->parity==IOT_UART_PARITY_NONE)
temp_prt->parity=UART_PARITY_NONE;
elseif (param->parity==IOT_UART_PARITY_EVEN)
temp_prt->parity=UART_PARITY_EVEN;
elseif (param->parity==IOT_UART_PARITY_ODD)
temp_prt->parity=UART_PARITY_ODD;
if (m_uart_bus_info[id].id==0)
LzUartDeinit(m_uart_bus_info[id].id);
uint32_t*pUart0= (uint32_t*)(0x40070000U);
HAL_UART_DeInit(pUart0);
ret=LzUartInit(m_uart_bus_info[id].id, temp_prt);
if (ret!=LZ_HARDWARE_SUCCESS)
returnIOT_FAILURE;
returnIOT_SUCCESS;
unsignedintIoTUartDeinit(unsignedintid);
描述:
取消初始化UART设备。
参数:
| 参数 | 类型 | 描述 |
UART ID配置和IO复用如下表:
| 串口 | id | TX | RX |
返回值:
| 返回值 | 描述 |
| IOT_SUCCESS | 成功 |
| IOT_FAILURE | 失败 |
实现:
unsignedintret=0;
returnIOT_FAILURE;
ret=LzUartDeinit(m_uart_bus_info[id].id);
returnIOT_FAILURE;
returnIOT_SUCCESS;
intIoTUartRead(unsignedintid, unsignedchar*data, unsignedintdataLen);
描述:
UART设备读取指定长度的数据。
参数:
| 参数 | 类型 | 描述 |
| data | unsigned char * | 数据指针 |
| dataLen | unsigned int | 数据长度 |
UART ID配置和IO复用如下表:
| 串口 | id | TX | RX |
返回值:
| 返回值 | 描述 |
| IOT_SUCCESS | 成功 |
| IOT_FAILURE | 失败 |
实现:
unsignedintret=0;
returnIOT_FAILURE;
ret=LzUartRead(m_uart_bus_info[id].id, data, dataLen);
returnret;
intIoTUartWrite(unsignedintid, constunsignedchar*data, unsignedintdataLen);
描述:
UART设备读取指定长度的数据。
参数:
| 参数 | 类型 | 描述 |
| data | const unsigned char * | 数据指针 |
UART ID配置和IO复用如下表:
| 串口 | id | TX | RX |
返回值:
| 返回值 | 描述 |
| IOT_SUCCESS | 成功 |
| IOT_FAILURE | 失败 |
实现:
unsignedintret=0;
returnIOT_FAILURE;
ret=LzUartWrite(m_uart_bus_info[id].id, data, dataLen);
returnIOT_FAILURE;
returnIOT_SUCCESS;
主要代码分析
在uart_example函数中,创建一个任务。
voiduart_example()
unsignedintthread_id;
TSK_INIT_PARAM_Stask= {0};
unsignedintret =LOS_OK;
task.pfnTaskEntry= (TSK_ENTRY_FUNC)uart_thread;
task.uwStackSize =2048;
task.pcName ="uart_thread";
task.usTaskPrio =24;
ret =LOS_TaskCreate(&thread_id, &task);
if (ret!=LOS_OK) {
printf("Falied to create uart_thread ret:0x%x\n", ret);
return;
uart_thread任务中调用IOT库的UART接口配置、读写UART。
voiduart_thread()
unsignedintret;
IotUartAttributeattr;
unsignedcharstr[] ="HelloWorld!";
unsignedcharrecv_buffer[STRING_MAXSIZE] = {0};
unsignedintrecv_length =0;
IoTUartDeinit(UART_ID);
attr.baudRate=115200;
attr.dataBits=IOT_UART_DATA_BIT_8;
attr.pad =IOT_FLOW_CTRL_NONE;
attr.parity =IOT_UART_PARITY_NONE;
attr.rxBlock =IOT_UART_BLOCK_STATE_NONE_BLOCK;
attr.stopBits=IOT_UART_STOP_BIT_1;
attr.txBlock =IOT_UART_BLOCK_STATE_NONE_BLOCK;
/* 初始化串口 */
ret=IoTUartInit(UART_ID, &attr);
if (ret!=IOT_SUCCESS) {
printf("%s, %d: IoTUartInit(%d) failed!\n", __FILE__, __LINE__, ret);
return;
/* 休眠1秒 */
LOS_Msleep(1000);
while (1) {
printf("%s, %d: uart write and str(%s), len(%d)!\n", __FILE__, __LINE__, str, strlen(str));
// IoTUartWrite是异步发送,非阻塞发送
IoTUartWrite(UART_ID, str, strlen(str));
// 等待发送完毕
LOS_Msleep(1000);
recv_length=0;
memset(recv_buffer, 0, sizeof(recv_buffer));
recv_length=IoTUartRead(UART_ID, recv_buffer, sizeof(recv_buffer));
printf("%s, %d: uart recv and str(%s), len(%d)\n", __FILE__, __LINE__, recv_buffer, recv_length);
/* 休眠1秒 */
LOS_Msleep(1000);
修改 vendor/lockzhiner/rk2206/sample 路径下 BUILD.gn 文件,指定 iot_uart_example 参与编译。
"./b20_iot_uart:iot_uart_example",
修改 device/lockzhiner/rk2206/sdk_liteos 路径下 Makefile 文件,添加 -liot_uart_example 参与编译。
hardware_LIBS=-lhal_iothardware-lhardware-lshellcmd-liot_uart_example
示例代码编译烧录代码后,按下开发板的RESET按键,使用杜邦线连接TX和RX,通过串口助手查看日志,显示如下:
enteringkernelinit...
hilogwillinit.
[MAIN:D]Main:LOS_Start...
Enteringscheduler
OHOS# hiview init success.[UART:E]LzUartDeinit: id 0, controller has NOT been initialized
[UART:E]LzUartDeinit:id0, controllerhasNOTbeeninitialized
../../../vendor/lockzhiner/rk2206/samples/b20_iot_uart/iot_uart_example.c, 63:uartwriteandstr(HelloWorld!), len(11)!
../../../vendor/lockzhiner/rk2206/samples/b20_iot_uart/iot_uart_example.c, 72:uartrecvandstr(HelloWorld!), len(11)
