STM32的串口中断配置
1.3w人已加入
STM32的串口中断配置,也是很简单的.
首先是配置UART的GPIO口
首先是配置UART的GPIO口
* Name : UART1_GPIO_Configuration
* Deion : Configures the uart1 GPIO ports.
* Input : None
* Output : None
* Return : None
void UART1_GPIO_Configuration(void)
GPIO_InitTypeDef GPIO_InitStructure;
// Configure USART1_Tx as alternate push-pull
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
// Configure USART1_Rx as input floating
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
然后是配置串口参数
* Name : UART1_Configuration
* Input : None
* Output : None
* Return : None
void USART_Configuration(void)
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
Uart1_GPIO_Configuration();
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
/* Configure the USART1 synchronous paramters */
USART_ClockInit(USART1, &USART_ClockInitStructure);
USART_InitStructure.USART_BaudRate = 9600;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No ;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
/* Configure USART1 basic and asynchronous paramters */
USART_Init(USART1, &USART_InitStructure);
/* Enable USART1 Receive interrupts */
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
/* Enable USART1 */
USART_Cmd(USART1, ENABLE);
然后是在中断设置,需要修改stm32f10x_it.c 中的串口中断函数 并且需要修改void NVIC_Configuration(void)函数
修改NVIC_Configuration函数
* Name : NVIC_Configuration
* Deion : Configures NVIC and Vector Table base location.
* Input : None
* Output : None
* Return : None
NVIC_InitTypeDef NVIC_InitStructure;
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
/* Configure the NVIC Preemption Priority Bits */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
/* Enable the USART1 Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
//串口中断
void USART1_IRQHandler(void)
//处理接收到的数据
if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
/* Clear the USART1 Receive interrupt */
USART_ClearITPendingBit(USART1, USART_IT_RXNE);
//发送中断
if (USART_GetITStatus(USART1, USART_IT_TXE) != RESET)
USART_SendData(USART1, Send_Data[Send_Length++]);
if (Send_Length==SEND_LENGTH)
//发送字节结束
USART_ClearITPendingBit(USART1,USART_IT_TXE);
USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
USART_ITConfig(USART1, USART_IT_TC, ENABLE);
//发送完成
if (USART_GetITStatus(USART1, USART_IT_TC) != RESET)
USART_ClearITPendingBit(USART1,USART_IT_TC);
USART_ITConfig(USART1, USART_IT_TC, DISABLE);
在需要发送的程序里Send_Data[SEND_LENGTH]和发送长度设置好,
void Send_to_PC(void)
//设置好Send_Data[SEND_LENGTH]数组
//打开发送中断
USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
至此 串口就可以工作起来了!~
  • 相关推荐
  • S
