在Vivado调用MIG产生DDR3的问题解析
1.[Place 30-51] IDELAYCTRL elements have been found to be associated with IODELAY_GROUP ‘DDR3_IODELAY_MIG0’, but the design does not contain IODELAY elements associated with this IODELAY_GROUP.
问题解析:这个问题很简单,就是DDR3 module 的输入时钟与所需要的时钟不匹配,例如配置所需的时钟为200MHz
DDR3
下面是调用的DDR3模块的,模块的倒数第二行是,模块的时钟输入,时钟源来自PLL产生的系统时钟的倍频。
ddr3 ddr3_1 ( // Memory interface ports .ddr3_addr                      (ddr3_addr),  .ddr3_ba                        (ddr3_ba),  .ddr3_cas_n                     (ddr3_cas_n),  .ddr3_ck_n                      (ddr3_ck_n),  .ddr3_ck_p                      (ddr3_ck_p),.ddr3_cke                       (ddr3_cke),   .ddr3_ras_n                     (ddr3_ras_n),  .ddr3_reset_n                   (ddr3_reset_n),  .ddr3_we_n                      (ddr3_we_n),   .ddr3_dq                        (ddr3_dq),   .ddr3_dqs_n                     (ddr3_dqs_n),   .ddr3_dqs_p                     (ddr3_dqs_p),   .init_calib_complete            (init_calib_complete),   .ddr3_cs_n                      (ddr3_cs_n),   .ddr3_dm                        (ddr3_dm),   .ddr3_odt                       (ddr3_odt),   // Application interface ports.ui_clk                         (ui_clk),  .ui_clk_sync_rst                (ui_clk_sync_rst),  // outputui_clk_sync_rst.mmcm_locked                    (),  // outputmmcm_locked.aresetn                        (1'b1),  // inputaresetn.app_sr_req                     (1'b0),  // inputapp_sr_req.app_ref_req                    (1'b0),  // inputapp_ref_req.app_zq_req                     (1'b0),  // inputapp_zq_req.app_sr_active                  (),  // outputapp_sr_active.app_ref_ack                    (),  // outputapp_ref_ack.app_zq_ack                     (),  // outputapp_zq_ack// Slave Interface Write Address Ports.s_axi_awid                     (s00_axi_awid),  // input [0:0]s_axi_awid.s_axi_awaddr                   (s00_axi_awaddr),  // input [29:0]s_axi_awaddr.s_axi_awlen                    (s00_axi_awlen),  // input [7:0]s_axi_awlen.s_axi_awsize                   (s00_axi_awsize),  // input [2:0]s_axi_awsize.s_axi_awburst                  (s00_axi_awburst),  // input [1:0]s_axi_awburst.s_axi_awlock                   (s00_axi_awlock),  // input [0:0]s_axi_awlock.s_axi_awcache                  (s00_axi_awcache),  // input [3:0]s_axi_awcache.s_axi_awprot                   (s00_axi_awprot),  // input [2:0]s_axi_awprot.s_axi_awqos                    (s00_axi_awqos),  // input [3:0]s_axi_awqos.s_axi_awvalid                  (s00_axi_awvalid),  // inputs_axi_awvalid.s_axi_awready                  (s00_axi_awready),  // outputs_axi_awready// Slave Interface Write Data Ports.s_axi_wdata                    (s00_axi_wdata),  // input [63:0]s_axi_wdata.s_axi_wstrb                    (s00_axi_wstrb),  // input [7:0]s_axi_wstrb.s_axi_wlast                    (s00_axi_wlast),  // inputs_axi_wlast.s_axi_wvalid                   (s00_axi_wvalid),  // inputs_axi_wvalid.s_axi_wready                   (s00_axi_wready),  // outputs_axi_wready// Slave Interface Write Response Ports.s_axi_bid                      (s00_axi_bid),  // output [0:0]s_axi_bid.s_axi_bresp                    (s00_axi_bresp),  // output [1:0]s_axi_bresp.s_axi_bvalid                   (s00_axi_bvalid),  // outputs_axi_bvalid.s_axi_bready                   (s00_axi_bready),  // inputs_axi_bready// Slave Interface Read Address Ports.s_axi_arid                     (s00_axi_arid),  // input [0:0]s_axi_arid.s_axi_araddr                   (s00_axi_araddr),  // input [29:0]s_axi_araddr.s_axi_arlen                    (s00_axi_arlen),  // input [7:0]s_axi_arlen.s_axi_arsize                   (s00_axi_arsize),  // input [2:0]s_axi_arsize.s_axi_arburst                  (s00_axi_arburst),  // input [1:0]s_axi_arburst.s_axi_arlock                   (s00_axi_arlock),  // input [0:0]s_axi_arlock.s_axi_arcache                  (s00_axi_arcache),  // input [3:0]s_axi_arcache.s_axi_arprot                   (s00_axi_arprot),  // input [2:0]s_axi_arprot.s_axi_arqos                    (s00_axi_arqos),  // input [3:0]s_axi_arqos.s_axi_arvalid                  (s00_axi_arvalid),  // inputs_axi_arvalid.s_axi_arready                  (s00_axi_arready),  // outputs_axi_arready// Slave Interface Read Data Ports.s_axi_rid                      (s00_axi_rid),  // output [0:0]s_axi_rid.s_axi_rdata                    (s00_axi_rdata),  // output [63:0]s_axi_rdata.s_axi_rresp                    (s00_axi_rresp),  // output [1:0]s_axi_rresp.s_axi_rlast                    (s00_axi_rlast),  // outputs_axi_rlast.s_axi_rvalid                   (s00_axi_rvalid),  // outputs_axi_rvalid.s_axi_rready                   (s00_axi_rready),  // inputs_axi_rready// System Clock Ports.sys_clk_i                      (clk_DDR       ),// input DDR3 CLK,DDR3模块的输入时钟.sys_rst                        (rst_n         )); // input sys_rst
下面是系统时钟缓冲模块IBUFG module,和时钟倍频PLL module,如果这个时候的clk_DDR时钟不是DRR3模块所需要的200MHz,那么就会产生上面的错误。
IBUFGIBUFG_U(    .O(clk_bufg), .I(sys_clk) ); //generate the video and CMOS sensor clocksys_pllvideo    (    // Clock out ports     .clk_out1(clk_video),     // output clk_out1,40M .clk_out2(clk_40m),     // output clk_out2     .clk_out3(adc_clk),     // output clk_out3,125M .clk_out4(clk_DDR),     // output clk_out3,125M// Status and control signals     .locked(          ),       // output locked// Clock in ports     .clk_in1(clk_bufg));      // input clk_in1
解决方法:把PLL部分的clk_DDR的时钟输出为200MHz就可以了,或者把MIG中的DDR3的输入时钟改成你想要的时钟大小即可,反正时钟匹配上就可以了。
DDR3
