OpenVINO C#如何运行YOLO11实例分割模型
来源:OpenCV学堂
OpenVINO2025 C#支持
开源的支持项目来自颜国进老师贡献,已经被OpenVINO官方收录,项目网址:
https://gitee.com/linbei_cht/OpenVINO-CSharp-API
模型
安装非常容易,只要在VS2022里面点击一下即可安装。最新版本已经是OpenVINO2025支持。
YOLO11实例分割
YOLO11是YOLOv5跟YOLOv8作者推出最新升级版本模型,支持分类、检测、分割、姿态评估、OBB。这里以YOLO11实例分割模型为例,演示OpenVINO C#如何运行,YOLO11-seg模型的输入与输出。
模型
代码是我在OpenVINO-CSharp-API作者开源的YOLOv8对象检测的代码基础上修改而成。调用检测代码如下:
public void Detect()
    // Set the video path and model path
    string video_path = "D:/images/video/play_scoers.mp4";
    string model_path = "D:/python/yolov5-7.0/yolo11n-seg.onnx";
    // Create a new Core object and read the model
    Core core = new Core();
    Model model = core.read_model(model_path);
    CompiledModel compiled_model = core.compile_model(model, "GPU");
    // Create a list of InferRequest objects
    Listrequests = new List{ compiled_model.create_infer_request(), compiled_model.create_infer_request() };
    // Create a new VideoCapture object and read the video
    VideoCapture capture = new VideoCapture(video_path);
    if (!capture.IsOpened())
        Console.WriteLine("Error: Video not found!");
        return;
    Mat frame = new Mat();
    Mat next_frame = new Mat();
    capture.Read(frame);
    float scale = 0.0f;
    float[] input_data = preprocess(frame, out scale);
    requests[0].get_input_tensor().set_data(input_data);
    requests[0].start_async();
    Stopwatch sw = new Stopwatch();
    float[] total_infs = new float[3];
    ListclassList = File.ReadAllLines("D:/python/yolov5-7.0/classes.txt").Select(line => line.Trim()).ToList();
    while (true)
        if (!capture.Read(next_frame))
            break;
        sw.Restart();
        requests[1].get_input_tensor().set_data(input_data);
        requests[1].start_async();
        requests[0].wait();
        float[] det_data = requests[0].get_tensor("output0").get_data(8400 * 116);
        float[] seg_data = requests[0].get_tensor("output1").get_data(32 * 160*160);
        Mat rgb_mask = new Mat(frame.Size(), frame.Type());
        DetResult result = postprocess(det_data, seg_data, scale, rgb_mask);
        sw.Stop();
        total_infs[0] = sw.ElapsedMilliseconds;
        Cv2.PutText(frame, "Inference: " + (1000.0 / total_infs[0]).ToString("0.00") + "FPS " + (total_infs[0]).ToString("0.00") + "ms", new OpenCvSharp.Point(20, 40), HersheyFonts.HersheyPlain, 2, new Scalar(255, 0, 255), 2);
        result.update_lable(classList);
        Visualize.draw_det_result(result, frame);
        Cv2.AddWeighted(frame, 0.5, rgb_mask, 0.5, 0, frame);
        Cv2.ImShow("C# YOLO11-OpenVINO-Seg演示 - OpenCV学堂", frame);
        // Press 'ESC' to exit the program
        if (Cv2.WaitKey(1) == 27)
            break;
        swap(requests);
        frame = next_frame;
        rgb_mask.Release();
后处理实现细节
这个实现最大的坑在后处理部分,要基于全局编码信息乘以每个检测BOX区域的编码信息,才可以解码得到每个BOX对象的掩膜。实现的代码如下:
Mat roi_mask = roi_masks[index];
Mat m = roi_mask * mask_info;
for (int col = 0; col < m.Cols; col++)
    m.At(0, col) = sigmoid_function(m.At(0, col));
最后根据得到掩膜直接设置BOX区域的颜色即可,代码如下:
rgb_mask[box].SetTo(new Scalar(0, 0, 255), box_m);
re.add(classIds[index], confidences[index], positionBoxes[index]);
然后把得到RGB彩色掩膜图像跟BOX框绘制图像相加记得到最终输出结果图像。
