电源管理集成电路(PMIC)_S6BP401A主要特性
汽车电子
2433人已加入
  Cypress公司的S6BP401A是电源管理集成电路(PMIC),包含有四个内置了开关FET的降压2.1MHz DC/DC转换器,两个低压降(LDO)的稳压器和数字窗口看门狗计时器.VIN输入电压4.5V-5.5V,内置开关FET的电流高达3A,主要用在汽车应用,先进驾驶辅助系统(ADAS),照相机系统如安全照相机和工业应用。本文介绍了S6BP401A主要特性,框图和架构框图,典型应用电路,以及评估板S6SBP401AJ0SA1001主要指标,电路图,材料清单和PCB设计图。
  S6BP401A is a power management IC, consists of quad buck 2.1 MHz DC/DC converter with built-in switching FETs, dual LowDrop-out regulator (LDOs) and a digital windowed watchdog timer. Having the switching FETs built-in, S6BP401A realizes highpower conversion efficiency and high switching frequency up to 2.4 MHz. The internal FETs are capable to handle up to 3A load. AsS6BP401A employs the current mode architecture, it has fast load transient response. Built-in output voltage setting resistors andcompensation circuits reduce BOM cost and component area.
  S6BP401A主要特性:
  Quad Buck DC/DC Converter (DD1 to DD4)
  VIN Input Range: 4.5V to 5.5V
  Switching Frequency
  External clock mode: 1.8 MHz to 2.4 MHz
  Internal clock mode: 2.0 MHz to 2.2 MHz
  Built-in Switching FETs up to 3A
  Built-in Output Voltage Setting Resistors
  Built-in Compensation Circuits
  Dual LDO (LD1, LD2)
  VIN Input Voltage Range: 2.97V to 5.5V
  Built-in Output Voltage Setting resistors
  Power Good Monitor Output for each DC/DC Converters,LDOs
  Built-in Windowed Watchdog Timer (WDT)
 DC转换器
   图1.S6BP401A框图
DC转换器
DC转换器
    图2.S6BP401A架构框图
DC转换器
  图3.S6BP401A典型应用电路
  S6SBP401AJ0SA1001 and S6SBP401AM2SA1001 are the evaluation kit for power block of automotive ADAS platform.
  The board implements power management IC S6BP401A.
DC转换器
图4.评估板S6SBP401AJ0SA1001外形图
DC转换器
图5.评估板S6SBP401AJ0SA1001略图
评估板S6SBP401AJ0SA1001主要指标:
DC转换器
DC转换器
  图6.评估板S6SBP401AJ0SA1001电路图
  评估板S6SBP401AJ0SA1001材料清单:
DC转换器
DC转换器
DC转换器
图7.评估板S6SBP401AJ0SA1001 PCB设计图(1)
DC转换器
     图8.评估板S6SBP401AJ0SA1001 PCB设计图(2)
