升技 AS8 系列主板使用手册说明书.pdf
To reach the optimum performance in dual-channel configurations, install identical DDR2 DIMM pairs for each channel.
• Install DIMMs with the same CAS latency. To reach the optimum compatibility, obtain memory modules from the same vendor.
• Due to chipset resource allocation, the system may detect less than 4GB of system memory in the installation of four 1GB DDR2 memory modules.
• Due to chipset limitation, 128MB DIMM modules or double-sided x16 memory chips are not supported.
