升技 KU8主板使用手册说明书
消耗积分:2 | 格式:rar | 大小:2995 | 2010-02-06
分享资料个
升技 KU8主板使用手册说明书.pdf
To reach the optimum performance in dual-channel configurations, install identical DDR2 DIMM pairs for each channel.
• Install DIMMs with the same CAS latency. To reach the optimum compatibility, obtain memory modules from the same vendor.
• Due to chipset resource allocation, the system may detect less than 4GB of system memory in the installation of four 1GB DDR2 memory modules.
• Due to chipset limitation, 128MB DIMM modules or double-sided x16 memory chips are not supported.
评论(0)
发评论
下载排行榜
