TCAN1051HGV-Q1主要特性及TCAN10xx系列CAN评估模块主要特性
汽车电子
2452人已加入
  TI公司的TCAN1051HGV-Q1是满足ISO11898-2 (2016)高速CAN物理层标准的收发器,满足汽车应用AEC Q100,数据速率高达5Mbps,I/O电压范围支持3.5V和5V MCU,HBM ESD 保护电压±16 kV, IEC ESD保护电压高达 ±15 kV,主要用在所有的CAN网络,重型机械ISO11783应用,和汽车与交通。本文介绍了TCAN1051HGV-Q1主要特性,框图以及TCAN10xx系列CAN评估模块主要特性和电路图。
  This CAN transceiver family meets the ISO11898-2 (2016) High Speed CAN (Controller Area Network) physical layer standard. All devices are designed for use in CAN FD networks up to 2 Mbps (megabits per second)。 Devices with part numbers that include the “G” suffix are designed for data rates up to 5 Mbps, and versions with the “V” have a secondary power supply input for I/O level shifting the input pin thresholds and RXD output level. This family of devices comes with silent mode which is also commonly referred to as listen-only mode. Additionally, all devices include many protection features to enhance device and network robustness.
  TCAN1051HGV-Q1主要特性:
  AECQ100: Qualified for Automotive Applications
  Meets the Requirements of ISO11898-2 (2016)
  ‘Turbo’ CAN:
  All devices support 2 Mbps CAN FD (Flexible Data Rate) and “G” options support 5 Mbps
  Short and Symmetrical Propagation Delay Times and Fast Loop Times for Enhanced Timing Margin
  Higher Data Rates in Loaded CAN Networks
  I/O Voltage Range Supports 3.3 V and 5 V MCUs
  Ideal Passive Behavior When Unpowered
  Bus and Logic Terminals are High Impedance (no load)
  Power Up/Down With Glitch Free Operation On Bus and RXD Output
  Protection Features
  HBM ESD Protection: ±16 kV
  IEC ESD Protection up to ±15 kV
  Bus Fault Protection: ±58 V (non-H variants) and ±70 V (H variants)
  Undervoltage Protection on VCC and VIO (V variants only) Supply Terminals
  Driver Dominant Time Out (TXD DTO) - Data rates down to 10 kbps
  Thermal Shutdown Protection (TSD)
  Receiver Common Mode Input Voltage: ±30 V
  Typical Loop Delay: 110 ns
  Junction Temperatures from –55℃ to 150℃
  TCAN1051HGV-Q1应用:
  All devices support highly loaded CAN networks
  Heavy Machinery ISO11783 Applications
  Automotive and Transportation
CAN
图1.TCAN1051HGV-Q1框图
CAN
图2.TCAN1051HGV-Q1典型CAN总线应用框图
CAN
图3.TCAN1051HGV-Q1采用5V CAN控制器的典型CAN总线应用框图
CAN
  图4.TCAN1051HGV-Q1采用3.3V CAN控制器的典型CAN总线应用框图
  TCAN10xx系列CAN评估模块
  This user guide details the TCAN10xx CAN (Controller Area Network) EVM transceiver operation. TheTCAN10xx CAN EVM is configurable for use with all TI CAN transceiver families: TCAN10xx, TCAN33x,SN65HVD23x, SN65HVD25x, SN65HVD10x0, and SN65HVDA54x by replacing the transceiver andsetting jumpers on the EVM as outlined in this document. This user guide explains the EVM configurationsfor basic CAN evaluation, various load and termination settings.
  The EVM comes with the TCAN1042D CAN transceiver factory installed. The CAN EVM may be reconfigured by a user for use with all TI CAN transceiver families: TCAN33x, SN65HVD23x, SN65HVD25x, SN65HVD10x0 and SN65HVDA54x by replacing the transceiver and setting jumpers on the EVM. The EVM has configurations for basic CAN evaluation, various load and termination settings necessary to evaluate CAN transceiver performance.
  TCAN10xx系列CAN评估模块主要特性:
  Meets the requirements of ISO11898-2
  I/O Voltage Range Support 3.3V and 5V MCUs
  Ideal passive behavior when unpowered
  Bus pins are high impedance (no load to operating bus)
  Logic pins are high impedance
  Power up/down with glitch free operation on bus
  Protection Features
  ESD protection of bus pins
  HBM ESD ±25kV
  IEC ESD ±12kV
  Bus Fault Protection ±14V
  Under voltage protection on supply pins
  TXD (Driver) dominant time out (DTO)
  RXD (Receiver) dominant time out (DTO)
  Thermal shutdown protection
Characterized for -40℃ to 125℃ operation
图5.TCAN10xx系列CAN评估模块外形图
CAN
图6.TCAN10xx系列CAN评估模块电路图
