使用nRFF54L15初始化一个SPI
【NCS随笔】
NCS使用了Zyphyr操作系统,以及设备树的概念,所以有许多客户对于不了解,今天copy一个SPI初始化的例程,给读者看
Nordic官方课程
官方已经写了一个SPI的课程,写的挺详细的可以,也可以看这个课程
https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-5-serial-peripheral-interface-spi/topic/exercise-1-10/
配置宏定义
在 prj.conf 使能SPI
CONFIG_SPI=y
添加overlay
新建一个nrf5l15dk_nrf54l15_cpuapp.overlay
添加需要的内容
&pinctrl {
	spi22_default_alt: spi22_default_alt {
		group1 {
			psels = < NRF_PSEL(SPIM_SCK, 1, 12) >,
				 NRF_PSEL(SPIM_MISO, 1, 10) >,
				 NRF_PSEL(SPIM_MOSI, 1, 8) >;
	spi22_sleep_alt: spi22_sleep_alt {
		group1 {
			low-power-enable;
&gpio2 {
	status = "okay";
&spi22 {
	status = "okay";
	pinctrl-0 = < &spi22_default_alt >;
	pinctrl-1 = < &spi22_sleep_alt >;
	pinctrl-names = "default", "sleep";
	overrun-character = < 0x00 >;
	cs-gpios = < &gpio1 14 GPIO_ACTIVE_LOW >;
	easydma-maxcnt-bits = < 0x400 >;
	dut_spi_dt: test-spi-dev@0 {
		compatible = "vnd,spi-device";
		reg = < 0 >;
		spi-max-frequency = < 8000000 >;
main函数
/* SPI 描述结构体 */
#define SPI_OP	(SPI_WORD_SET(8)|SPI_TRANSFER_MSB)
#define SPIM_OP	 (SPI_OP_MODE_MASTER | SPI_TRANSFER_MSB |SPI_WORD_SET(8))
static struct spi_dt_spec spim = SPI_DT_SPEC_GET(DT_NODELABEL(dut_spi_dt), SPIM_OP, 0);
 * @brief st7735发送命令
static void st7735_send_command(uint8_t command)
   // TFT_DC_COMMAND;
    struct spi_buf tx_spi_buf = { .buf = (void *)&command, .len = 1 };
    struct spi_buf_set tx_spi_buf_set = {.buffers = &tx_spi_buf, .count = 1 };
    int ret = spi_write_dt(&spim, &tx_spi_buf_set);
    if (ret < 0) {
        LOG_ERR("SPI write data failed: %d", ret);
int main(void)
	printf("Hello World! %sn", CONFIG_BOARD_TARGET);
	/* 检查设备是否准备好 */
    if (!spi_is_ready_dt(&spim)) {
        LOG_ERR("spi is not ready");
        return false;
	while (1)
		st7735_send_command(0x55);
		k_sleep(K_MSEC(500));
		printf("mr_st7735_send_command:0x55n");
	return 0;
逻辑分析仪显示数据没有问题
SDK
使用nRFX库
还有一个使用旧的nRF52_SDK库的办法,可以绕过zephyr的设备树和API,其实zephyr底层也是调用nRF库
宏配置
CONFIG_NRFX_SPIM22=y
&spi22 {
    status = "okay";
    compatible = "nordic,nrf-spim";
    pinctrl-0 = < &spi_dummy >;
最后一如既往的到了臭不要脸环节,作为一名精通Nordic硬件设计和软件开发的FAE,你的点赞、收藏和评论是对我最大的支持,有问题多多指教,如果有需要Nordic开发板、Nordic的芯片以及Nordic技术支持的可以在个人资料获取我的联系方式,感谢读者支持!
