iMOTION™ IMC100系列主要特性的介绍
嵌入式技术
1418人已加入
摘要:infineon公司的iMOTION™ IMC100系列是可变速率控制的高集成度的IC,集成了用来控制永磁同步马达(PMSM)所需的硬件和算法,缩短马达系统面市时间,降低系统成本和开发成本,具有现场控制PMSM,用于马达控制指令如UART, PWM或模拟输入信号的灵活主接口,支持IEC 60335 (‘Class B’),集成了脚本引擎以便灵活应用,主要用在电冰箱,家用电器,马达控制,泵和风扇以及其它PMSM驱动.本文介绍了iMOTION™ IMC100系列主要特性,框图和应用框图,以及评估板EVAL-M1-101T 主要特性,框图,电路图,材料清单和PCB设计图.
iMOTION™ IMC100 is a series of highly integrated ICs for the control of variable speed drives. By integrating both the required hardware and algorithm to perform control of a Permanent Magnet Synchronous Motor (PMSM) they provide the shortest time to market for any motor system at the lowest system and development cost.
Infineon’s patented and field-proven Motion Control Engine (MCE) implements Field Oriented Control (FOC) using single or leg shunt current feedback and uses space vector PWM with sinusoidal signals to achieve highest energy efficiency. It also integrates multiple protection features like over- and undervoltage, overcurrent, rotor lock etc. Powerful tools like MCEWizard and MCEDesigner reduce the implementation effort for a variable speed drive to a simple configuration of the MCE for the respective motor.
The IMC100 series takes advantage of a new hardware platform that brings a comprehensive set of innovative analog and motor control peripherals.
The next generation of the MCE not only further improves the performance of the control algorithm but also adds functionality like sensor support for accurate rotor positioning, ready-to-use PFC algorithms as well as more and faster host interface options.
The IMC100 series is offered in several device variants ranging from single motor control to motor control plus PFC. All devices can be used in applications requiring functional safety acc. to IEC 60335 (‘Class B’). With this wide application scope the IMC100 series is the perfect choice for any highly efficient variable speed drive.
iMOTION™ IMC100主要特性:
• Motion Control Engine (MCE) as ready-to-use solution for variable speed drives
• Field oriented control (FOC) for permanent magnet synchronous motor (PMSM)
• Space vector PWM with sinusoidal commutation and integrated protection features
• Current sensing via single or leg shunt
• Sensorless operation
• Optional support for hall sensors (analog or digital)
• Optional boost or totem pole PFC control integrated
• Flexible host interface options for motor control commands: UART, PWM or analog input signal
• Support for IEC 60335 (‘Class B’)
• Integrated scripting engine for application flexibility
• Multiple package options
iMOTION™ IMC100应用:
• Refrigerators
• Home appliances
• Pumps, fans
• ...any other PMSM drive
IMC100
图1. iMOTION™ IMC100框图
IMC100
图2. iMOTION™ IMC100应用框图
IMC100
图3. iMOTION™ IMC101单分路配置图
IMC100
图4. iMOTION™ IMC101并联配置图
评估板EVAL-M1-101T
EVAL-M1-101T is an evaluation-board as part of the iMOTION™ Modular Application Design Kit. This board features and demonstrates Infineon’s Advanced Motion Control Engine (MCE 2.0) technology for permanent magnet motors drive over the full speed range.
The evaluation board EVAL-M1-101T was developed to support customers during their first steps designing applications with running any permanent magnet motor via sensorless sinusoidal control.
The EVAL-M1-101T evaluation board is a part of the iMOTION™ Modular Application Design Kit for drives (iMOTION™ MADK). In order to run a motor, the mating power board is required to interface this evaluation board.
The MADK platform is intended to use various power stages with different control boards. These boards can easily be interfaced through the 20-pin iMOTION™ MADK M1, or the 30-pin iMOTION™ MADK M3 interface connector. This board is equipped with 20-pin M1 connector and is intended for single motor control only.
This evaluation board is designed to give comprehensible solutions of sensorless control of permanent magnet motors over the full speed range. It provides a capable of 3-phase and type 3 of 2-phase modulation, a micro- USB connector and on board debugger isolated by digital isolator, and UART interface.
The EVAL-M1-101T evaluation board is available from Infineon. The features of this board are described in the main features chapter of this document, whereas the remaining paragraphs provide information to enable the customers to copy, modify and qualify the design for production according to their own specific requirements.
Environmental conditions were considered in the design of the EVAL-M1-101T, but it is not qualified regarding safety requirements or manufacturing and operation over the whole operating temperature range or lifetime. The boards provided by Infineon are subject to functional testing only.
Evaluation boards are not subject to the same procedures as regular products regarding Returned Material Analysis (RMA), Process Change Notification (PCN) and Product Discontinuation (PD). Evaluation boards are intended to be used under laboratory conditions by technical specialists only.
IMC100
图5. 评估板EVAL-M1-101T外形图
评估板EVAL-M1-101T 主要特性:
· Complete kit for running any permanent magnet motor via sensorless sinusoidal control
· 3.3V (default) or 5V VDD power supply
· Micro-USB connector and on-board debugger isolated by digital isolator
· Capable of 3-phase and type 3 of 2-phase modulation
· RoHS complaint
· PCB size is 65 x 45 mm
IMC100
图6. 采用IMC101T-T038的应用框图
评估板EVAL-M1-101T主要指标:
IMC100
IMC100
图7. 评估板EVAL-M1-101T功能顶层分布图表
IMC100
图8.采用评估板EVAL-M1-101T和EVAL-M1-05-650系统连接图
IMC100
图9.评估板EVAL-M1-101T电路图
评估板EVAL-M1-101T材料清单:
IMC100
IMC100
IMC100
图10.评估板EVAL-M1-101T PCB设计图(1)
IMC100
图11.评估板EVAL-M1-101T PCB设计图(2)
IMC100
图12.评估板EVAL-M1-101T PCB设计图(3)
图13.评估板EVAL-M1-101T PCB设计图(4)
  • 相关推荐
  • 热点推荐
  • IMC100
