这个闹钟有点皮!Clocky一款会跑的闹钟
Mike HanlonMarch 8, 2007Clocky – the alarm clock that runs away
Image Gallery (7 images)
March 9, 2007 For people who have trouble dealing with an alarm clock telling them it’s time to get up, here’s one potential solution – it’s an alarm clock that runs away and torments you until you get up. When Clocky was just a design concept it received a lot of attention, but now it’s a real product. When the alarm sounds, Clocky will start beeping. You can set him to run away immediately the alarm sounds, or you can set it to snooze once for your chosen number of snooze minutes and if you don't get up, Clocky will start beeping again and run away. His aim is to jump off your bedside table first, so he won’t be easy to catch once, he’s hit the floor. He then scurries away and beeps at you until you get up and catch the little critter.
Created by Boston-based designer Gauri Nanda, the Clocky is available in three colours – almond, aqua and mint – and sells for US$50.
Clocky – 会跑的闹钟 clocky–运行away
形象画廊的闹钟(7幅)
2007年3月9日曾处理一个闹钟告诉他们该起床了麻烦的人,这是一个潜在的解决方案,它是一–逃跑折磨你直到你起床的闹钟。当“Clocky”只是一个设计概念,它收到了很多的关注,但现在这是一个真正的产品。当警报响起,“Clocky”将开始哔哔。你能让他逃跑,立即报警的声音,或者你可以将它设置为贪睡一旦你选择小睡分钟数如果你不起床,“Clocky”将开始哔哔的又跑了。他的目的是要先从床上跳下来,这样他就不容易抓住一次,他在地板上。然后他急忙走开,嘟嘟你直到你起床和捕捉小动物。
由总部位于波士顿的设计师Gauri Nanda,Clocky三种颜色–杏仁是可用的,水和薄荷50美元–销售。
  • 相关推荐
  • 热点推荐
  • 闹钟
