| 应用领域 | 产品型号 | 处理器核心架构与频率 | 主要特性 | 支持操作系统 |
| Vision AI | RZ/V2M | 1.0GHz Dual-core Cortex-A55 | DRP-AI (576-MAC), OpenCV Accelerator | Linux/Android™/RTOS |
| RZ/V2H | 1.8GHz Quad-core Cortex-A55 | DRP-AI3 (4K-MAC), 4K-ISP, 3D-GPU | ||
| RZ/V2L | 1.2GHz Dual-core Cortex-A55 | DRP-AI (576-MAC), 3D-GPU | ||
| Industrial Network | RZ/N1D | 500MHz Dual-core Cortex-A7 + 125MHz Cortex-M3 | Industrial Ethernet | RTOS |
| RZ/N1S | 500MHz Cortex-A7 + 125MHz Cortex-M3 | Industrial Ethernet | ||
| RZ/N1L | 125MHz Cortex-M3 | Industrial Ethernet | ||
| Real-time Control | RZ/T1 | 600MHz Cortex-R4 + 150MHz Cortex-M3 | 1-axis motor control, Industrial Ethernet | |
| RZ/T2M | 800MHz Dual-core Cortex-R52 | 2-axis motor control, Industrial Ethernet | ||
| RZ/T2L | 800MHz Cortex-R52 | 2-axis motor control, EtherCAT | ||
| IoT Edge | RZ/G3S | 1.1GHz Cortex-A55 + 250MHz Dual Cortex-M3 | LPDDR4/DDR4 | Linux/Android™/RTOS |
| RZ/Five | 1.0GHz RISC-V (AX45MP) | DDR4/3L, GbE Ethernet, CAN-FD | ||
| HMI | RZ/G2H | 1.5GHz Quad A57 + Cortex-A53 | LPDDR4, 3D-GPU, H.264/5 | |
| RZ/G2M | 1.5GHz Dual A57 + Cortex-A53 | LPDDR4, 3D-GPU, H.264/5 | ||
| RZ/G2E | 1.2GHz Dual-core Cortex-A53 | DDR3, 3D-GPU, H.264/5 | ||
| RZ/G2L | 1.2GHz Dual-core Cortex-A55 | DDR4/3L, 3D-GPU, H.264, CAN-FD | ||
| RZ/G2LC | 1.2GHz Dual-core Cortex-A55 | DDR4/3L, 3D-GPU, CAN-FD | ||
| RZ/G2UL | 1.0GHz Cortex-A55 | DDR4/3L, CAN-FD, ADC | ||
| RZ/A3UL | 1.0GHz Cortex-A55 | DDR4/3L, LCDC, GbE Ethernet, USB | ||
| RZ/G1H | 1.4GHz Quad A15 + Cortex-A7 | DDR3, 3D-GPU, H.264 | ||
| RZ/G1M | 1.5GHz Dual-core Cortex-A15 | DDR3, 3D-GPU, H.264 | ||
| RZ/A2M | 528MHz Cortex-A9 | 4MB RAM, MIPI-CSI, Ethernet, USB | ||
| RZ/A1H | 400MHz Cortex-A9 | 10MB RAM, JPEG, Ethernet, USB | ||
| RZ/A1L | 400MHz Cortex-A9 | 3MB RAM, Ethernet, USB | ||
| RZ/A1LU | 400MHz Cortex-A9 | 3MB RAM, JPEG, Ethernet, USB |
注:
- 颜色对应:表格行背景色遵循原图设计(Vision AI-青绿/Industrial-橙/Real-time-黄/IoT-蓝/HMI-紫)
- 关键特性缩写:
- DRP-AI:专用AI加速引擎(MAC数量标注)
- ISP:图像信号处理器(4K指分辨率支持)
- 3D-GPU:三维图形处理单元
- CAN-FD:增强型控制器局域网
- 架构说明:
- RZ/Five 为唯一采用 RISC-V 架构的型号
- RZ/T 系列主打实时控制(Cortex-R 核)
- 封装共性:全系支持工业级温度范围与硬件安全特性
此表格已按应用领域横向分类整理,保留原图关键参数并优化可读性,工程师可快速对比型号差异定位需求方案。
