Diodes AP3302AQC4/4+ 27W Class A充电器解决方案详解
Diodes公司的AP3302A是峰值电流控制准谐振(QR)PWM控制器,具有非常低的起动电流,起动过程软起动,准谐振控制不会产生可听见噪音,频率折返可得到高的平均效率,是高性能低待机功率和成本效率的离线反激转换器,主要用在开关AC/DC适配器/充电器,ATX/BTX辅助电源,机顶盒(STB)电源以及开架开关电源。本文介绍了AP3302A主要特性,框图,应用电路以及QC4/4+ 27W Class A充电器EV1板主要特性和测试结果,电路图,材料清单和PCB设计图。
The AP3302 is a Peak-Current control, Quasi-Resonant (QR) PWM controller which is optimized for high performance, low standby power and cost effective offline flyback converters.
At no load or light load, the IC will enter the burst mode to minimize standby power consumption. The minimum switching frequency (about 22kHz) is set to avoid the audible noise. When the load increases, the IC will enter valley lock QR mode with frequency foldback to improve system efficiency and EMI performance. The maximum switching frequency (about 120kHz) is set to clamp the QR frequency to reduce switching power loss. Furthermore, the frequency dithering function is built in to reduce EMI emission. Internal piecewise linear line compensation ensures constant output power limit over entire universal line voltage range.
Comprehensive protection features are included, such as brown out protection, cycle-by-cycle current limit (OCP), VCC Over Voltage Protection (VOVP), Secondary-side Output OVP (SOVP) and UVP (SUVP), internal OTP, Over Load Protection (OLP) and pins’ fault protection.
AP3302A主要特性:
 Very Low Start-Up Current
 Quasi-Resonant Operation with Valley Lock under All Line and Load Condition
 Non-Audible-Noise Quasi-Resonant Control
 Soft Start During Startup Process
 Frequency Fold Back for High Average Efficiency
 Constant Over Current Protection
 Secondary Winding Short Protection with FOCP
 Frequency Dithering for Reducing EMI
 VCC Maintain Mode
 Useful Pin Fault Protection:
SENSE Pin Floating
FB/Opto-Coupler Open/Short
 Comprehensive System Protection Feature:
 Brown Out Protection (BNO)
 Secondary Side OVP (SOVP) and UVP (SUVP)
 Mini Size Package of SOT26
 Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2)
 Halogen and Antimony Free. “Green” Device (Note 3)
AP3302A应用:
 Switching AC-DC Adapter/Charger
 ATX/BTX Auxiliary Power
 Set -Top Box (STB) Power Supply
 Open Frame Switching Power Supply
Diodes
图1.AP3302A框图
Diodes
图2. AP3302A应用电路图
The 27W QC4/4+ Class A charger Evaluation Board EV1 is composed of three main parts, AP3302A offers the QR PWM switching control & working under the DCM mode with peak current controlling, APR345 is a Synchronous Rectification Controller, and the WT6615F is USB PD and Qualcomm Quick Charge 4/4+ Controller for implementing quick charger decoder functions. Based on monitoring D+ & D- and CC1 & CC2 signals, WT6615F will interprets desired voltage and current setting, and then feedback information to primary side AP3302A controller for providing well regulated voltage and current as well as related power protections.
QC4/4+ 27W Class A充电器EV1板主要特性:
1)。系统主要特性:
 SSR Topology Implementation with an Opto-coupler for Accurate Step Voltage Controlling
 QC4+ Offers QC3.0/QC2.0 Backward Compliance
 Supports the USB PD3.0 Function and PPS (3V-11V@20mV)
 Meet DOE6 and CoC Tier 2 Efficiency Requirements
 《75mW No-Load Standby Power
2)。 AP3302A主要特性:
 Quasi-Resonant Operation with Valley Lock under all Lines and Load Conditions
 Switching Frequency: 22kHz-120kHz
 Non-audible-noise QR Controlling
 Soft Start Process during the Start-up Turn-on Moment
 During the burst mode operation and Low start-up operating quiescent currents, 75mW standby power can be achieved
 Built-in Jittering Frequency Function which is the EMI emission can be improved
 Internal Auto Recovery OCP, OVP, OLP, OTP Power Protection, cycle by cycle current limit, also with DC polarity & transformer short and Brown out Protection
3)。 APR345主要特性:
 Synchronous Rectification Working at DCM, CCM and QR Flyback
 Eliminate Resonant Ringing Interference
 Fewest External Components used
4)。 WT6615F主要特性:
 Type-C Source
 USB PD 3.0 v1.1 (PPS)
 BC1.2 DCP
 Qualcomm Quick Charge 4/4+
 Built in Shunt Regulator for Constant Voltage and Constant Current
 Programmable OVP/UVP/OCP/OTP
 Internal Discharge MOS
 Internal Vbus Load Switch Driver
 3V- 30V Operation Voltage without External Regulator
QC4/4+ 27W Class A充电器EV1板应用:
 QC4/4+ Wall Chargers
主要电源指标(CV和CC模式)
Diodes
Diodes
图3.QC4/4+ 27W Class A充电器EV1板外形图(背视图)
图4.QC4/4+ 27W Class A充电器EV1板外形图(正视图)
电源指标和测试结果:
Diodes
Diodes
图5.QC4/4+ 27W Class A充电器EV1板电路图
QC4/4+ 27W Class A充电器EV1板材料清单:
Diodes
Diodes
图6.QC4/4+ 27W Class A充电器EV1板PCB设计图:左:顶层;右:底层
