亚斯莱特低功耗LDO-AX117
消耗积分:3 | 格式:rar | 大小:444 | 2010-03-01
张静
分享资料个
AX1117 is a low dropout positive adjustable or fixed-mode regulator with minimum of 1A output current capability. The product is specifically designed to provide well-regulated supply for low voltage IC applications such as high-speed bus termination and low current 3.3V logic supply. AX1117 is also well suited for other applications such as VGA cards. AX1117 is guaranteed to have lower than 1.4V dropout at full load current making it ideal to provide well-regulated outputs of 1.25 to 5.0 with 6.4V to 12V input supply.
评论(0)
发评论
下载排行榜
