EP94M3 正品原装 代理微驱 QFP64 只售原装正品 自家现货库存 详情欢迎咨询
今日头条
1184人已加入
Overview
EP94M3 is a 3-Port MHL/HDMI Dual Mode Switcher. The chip supports 3 MHL/HDMI input ports working in dual mode and 1 HDMI output port. The chip supports the resolution up to 720p 60 Hz, 1080p 30 Hz or 1080p 60Hz in PackedPixel Mode.
The chip also supports 3 ports of on-chip EDID RAM and programmable passive/active DDC switches to lower down system cost.
Feature
•Supports 3 MHL/HDMI input ports with dual mode capability
•Supports 1 HDMI output port
•On-chip MHL/HDMI Receiver and HDMI Transmitter core which are compliant with MHL 2.0 and HDMI 1.4b specification
•On-chip Equalizer
•Support wide Frequency Range TMDS Output: 25MHz - 225 MHz TMDS clock
•Support up to 75 Mhz Pixel clock rate (8-bit 1080i/720p 60 Hz) in 24-bit mode and up to 150 Mhz Pixel clock rate (8-bit 1080p 60Hz YCC422) in Packed Pixel mode for MHL input
•Support up to 297 Mhz TMDS clock rate (4Kx2K) for HDMI input
•Support 3 ports on-chip EDID RAM
•Support on-chip programmable passive/active DDC switches
•Register-programmable via slave IIC interface
•Low stand-by current (< 100 uA) at power down mode
•64-pin LQFP package
来源:深圳市凌晔科技有限公司
地址:广东省深圳市福田区华强广场C座13L
电话:0755-83660559
传真:0755-83660559
手机:13544017528  陈小君 QQ:869030400
Email:869030400@qq.com
  • 相关推荐
  • 热点推荐
