精密0.04,0.05mm单丝线径铜编织网,编织软铜线定制
今日头条
1184人已加入
Features:
1. Anti-acid, anti-oil, antisepsis and moisture
2. Flammability VW-1, FT-1, -F-
3. Excellent abrasion resistance and mechanical strength.
Copper braid / wire type:
    (1)Purple copper braid / wire Purple copper braid / wire (TZ), the material is purple copper round wire, the regular line diameter is 0.12mm and 0.15mm, the product surface is smooth, the resistance is small, the color is golden yellow, also called copper color. DC resistivity of purple copper braided wire (20 Centigrade) is no more than 0.022 Ohm mm2/m.
    (2)Tinned copper braid / wire (TZX), the material is tinned round wire, the regular monofilament line diameter is 0.12mm and 0.15mm, the product surface is smooth and anti oxidation, the color is silver gray. DC resistivity of tinned copper braided wire (20 Centigrade) is no more than 0.022 Ohm mm2/m.Copper braid / wire
  • 相关推荐
  • 热点推荐
