PowerInt SID1183K单路1700V IGBT和MOSFET驱动方案
PowerInt公司的SID1183K是采用eSOP封装的单路1700V IGBT和MOSFET驱动器,栅极峰值驱动电流高达8A,集成的FluxLink™在初级和次级间提供电隔离,高达75kHz开关频率,传输时延260ns,传输时延抖动±5 ns,工作温度-40℃ 到125℃,主要用在通用和伺服驱动,UPS,太阳能,焊接逆变器和电能源。本文介绍了SID1183K产品亮点,功能框图,应用电路以及采用scaLE™- iDriver SID1183K通用基板参考设计RDHP-1702主要特性,电路图,材料清单和PCB设计图。
The SID1183K is a single channel IGBT and MOSFET driver in an eSOP package. Galvanic isolation is provided by Power Integrations’ innovative solid insulator FluxLink technology. The up to 8 A peak output drive current enables the product to drive devices up to 600 A without requiring any additional active components. For gate drive requirements that exceed the stand-alone capability of the SID1183K, an external booster may be added. Stable positive and negative voltages for gate control are provided by one unipolar isolated voltage source.
Additional features are short-circuit protection (DESAT) with Advanced Soft Shut Down (ASSD), undervoltage lock-out (UVLO) for primary-side and secondary-side and rail-to-rail output with temperature and process compensated output impedance guarantee safe operation even in harsh conditions.
Controller (PWM and fault) signals are compatible with 5 V CMOS logic, which may also be adjusted to 15 V levels by using external resistor divider.
SID1183K产品亮点:
Highly Integrated, Compact Footprint
Split outputs providing up to 8 A peak drive current
Integrated FluxLink™ technology providing galvanic isolation between primary-side and secondary-side
Rail-to-rail stabilized output voltage
Unipolar supply voltage for secondary-side
Suitable for 1700 V IGBT and MOSFET switches
Up to 75 kHz switching frequency
Low propagation delay time 260 ns
Propagation delay jitter ±5 ns
-40℃ to 125℃ operating ambient temperature
High common-mode transient immunity
eSOP package with 9.5 mm creepage and clearance distances
Advanced Protection / Safety Features
Undervoltage lock-out protection for primary and secondary-side (UVLO) and fault feedback
Short-circuit protection using VCE SAT monitoring and fault feedback
Full Safety and Regulatory Compliance
100% production partial discharge test
100% production HIPOT compliance testing at 6 kV RMS 1 s
Basic insulation meets VDE 0884-10
Green Package
Halogen free and RoHS compliant
SID1183K应用:
General purpose and servo drives
UPS, solar, welding inverters and power supplies
MOSFET驱动器
图1.SID1183K功能框图
MOSFET驱动器
图2.SID1183K典型应用电路图
MOSFET驱动器
图3.SID1183K应用电路图:采用电阻网络去饱和检测
MOSFET驱动器
图4.SID1183K应用电路图:采用二极管去饱和检测
采用SCALE™- iDriver SID1183K通用基板参考设计RDHP-1702
This application proposal provides a circuit design for a general purpose base board for driving various IGBTpower modules.
The design is proposed for the following application conditions:
 General purpose applications and IGBT power modules
 Adaptations such as adjustment of gate resistors can easily be done
 Up to 8 A peak gate current
 Up to 1 W per channel
通用基板参考设计RDHP-1702主要特性:
 Suitable for IGBT power modules in various housings such as 17 mm dual, 17 mm six-pack,
 62 mm, PrimePACK™, etc. with a maximum blocking voltage of 1700 V
 Short-circuit detection with Advanced Soft Shut Down (ASSD)
 Electrical command inputs and status outputs
 0 V / 5 V command input logic
 0 V / 5 V status output logic
 Minimum pulse suppression
 Interlock of command inputs
 5 V supply voltage
 Single PCB solution with soldered-in gate driver IC
Summary and Features
 Up to 1200 V DC-link voltage
 Electrical interfaces
 Basic Active Clamping
图5.通用基板参考设计RDHP-1702外形图
MOSFET驱动器
图6.通用基板参考设计RDHP-1702电路形图
通用基板参考设计RDHP-1702材料清单:
MOSFET驱动器
MOSFET驱动器
图7.通用基板参考设计RDHP-1702PCB设计图(顶层)
图8.通用基板参考设计RDHP-1702PCB设计图(装配图)
MOSFET驱动器
图9.通用基板参考设计RDHP-1702PCB设计图(元件装配图)
