SRC4382 2 通道采样率转换器,具有数字音频接口接收器和发送器
KANA 发表于 2018-11-02 19:34:06
数据: Two-Channel, Asynchronous Sample Rate Converter with Integrated Digital Audio 数据表
SRC4382是一款高度集成的CMOS器件,专为专业和广播数字音频系统而设计。 SRC4382将高性能双通道异步采样率转换器(SRC)与数字音频接口接收器(DIR)和发送器(DIT),两个音频串行端口以及用于互连功能块数据的灵活分配逻辑相结合和时钟。
DIR和DIT兼容AES3,S /PDIF,IEC 60958和EIAJ CP-1201接口标准。音频串行端口,DIT和SRC可以以高达216kHz的采样率运行。 DIR锁定范围包括20kHz至216kHz的采样率。
SRC4382采用片上控制寄存器和数据缓冲器配置,可通过4线串行外设接口(SPI)端口访问,或2线Philips I 2 C总线接口。状态寄存器提供对各种标志和错误位的访问,这些位从各种功能块派生而来。提供开漏中断输出引脚,并通过控制寄存器设置灵活的中断报告和屏蔽选项提供支持。主复位输入引脚用于由主处理器或监控功能进行初始化。
SRC4382需要一个+ 1.8V核心逻辑电源,此外还有+ 3.3V电源为DIR部分供电, DIT,以及线路驱动器和接收器功能。独立的逻辑I /O电源支持+ 1.65V至+ 3.6V的操作,提供与数字信号处理器和可编程逻辑器件上常见的低电压逻辑接口的兼容性。 SRC4382采用无铅TQFP-48封装,与德州仪器(TI)SRC4392和DIX4192产品引脚和寄存器兼容。
特性
  • Two-Channel Asynchronous Sample Rate Converter (SRC)
    • Dynamic Range with -60dB Input (A-Weighted): 128dB typical
    • Total Harmonic Distortion and Noise (THD+N) with Full-Scale Input: -125dB typical
    • Supports Audio Input and Output Data Word Lengths Up to 24 Bits
    • Supports Input and Output Sampling Frequencies Up to 216kHz
    • Automatic Detection of the Input-to-Output Sampling Ratio
    • Wide Input-to-Output Conversion Range: 16:1 to 1:16 Continuous
    • Excellent Jitter Attenuation Characteristics
    • Digital De-Emphasis Filtering for 32kHz, 44.1kHz, and 48kHz Input Sampling Rates
    • Digital Output Attenuation and Mute Functions
    • Output Word Length Reduction
    • Status Registers and Interrupt Generation for Sampling Ratio and Ready Flags
  • Digital Audio Interface Transmitter (DIT)
    • Supports Sampling Rates Up to 216kHz
    • Includes Differential Line Driver and CMOS Buffered Outputs
    • Block-Sized Data Buffers for Both Channel Status and User Data
    • Status Registers and Interrupt Generation for Flag and Error Conditions
  • User-Selectable Serial Host Interface: SPI or Philips I2C™
    • Provides Access to On-Chip Registers and Data Buffers
  • Digital Audio Interface Receiver (DIR)
    • PLL Lock Range Includes Sampling Rates from 20kHz to 216kHz
    • Includes Four Differential Input Line Receivers and an Input Multiplexer
    • Bypass Multiplexer Routes Line Receiver Outputs to Line Driver and Buffer Outputs
    • Automatic Detection of Non-PCM Audio Streams (DTS CD/LD and IEC 61937 formats)
    • Audio CD Q-Channel Sub-Code Decoding and Data Buffer
    • Low Jitter Recovered Clock Output
  • Two Audio Serial Ports (Ports A and B)
    • Synchronous Serial Interface to External Signal Processors, Data Converters, and Logic
    • Slave or Master Mode Operation with Sampling Rates up to 216kHz
    • Supports Left-Justified, Right-Justified, and Philips I2S™ Data Formats
    • Supports Audio Data Word Lengths Up to 24 Bits
  • Four General-Purpose Digital Outputs
    • Multifunction Programmable Via Control Registers
  • Extensive Power-Down Support
    • Functional Blocks May Be Disabled Individually When Not In Use
  • Operates From +1.8V Core and +3.3V I/O Power Supplies
  • Small TQFP-48 Package, Compatible with the SRC4392 and DIX4192
  • APPLICATIONS
    • DIGITAL AUDIO RECORDERS AND MIXING DESKS
    • DIGITAL AUDIO INTERFACES FOR COMPUTERS
    • DIGITAL AUDIO ROUTERS AND DISTRIBUTION SYSTEMS
    • BROADCAST STUDIO EQUIPMENT
    • DVD/CD RECORDERS
    • SURROUND SOUND DECODERS AND A/V RECEIVERS
    • CAR AUDIO SYSTEMS
U.S. Patent No. 7,262,716
Dolby is a registered trademark of Dolby Laboratories.
I2C, I2S are trademarks of Koninklijke Philips Electronics N.V.
All other trademarks are the property of their respective owners.
参数 与其它产品相比 采样速率转换器
# SRC Channels
Control Mode
Audio Data Format
Dynamic Range (dB)
THD+N (dB)
Control Interface
Digital Supply (up to 5 V) (V)
Power Supply (V)
Operating Temperature Range (C)
Pin/Package
Rating
SRC4382
2
SW (SPI)
H/W
Normal
I2S
128
-125
AES/EBU
S/PDIF
SPI
I2C
1.65 - 1.95
3 - 3.6
1.8
3.3
-40 to 85
48TQFP
Catalog
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
